跳转到主内容
MacBook Unibody Model A1278 Hard Drive Replacement
Andrew Bookholt
Andrew Bookholt8 其他贡献者
最后更新于 December 21, 2023
15 - 30 分钟
简单
特色指南
When replacing your hard drive, you must transfer the Torx screws from the old drive to the new one.
你所需要的
修复工具包
本套装包含完成指南所需的所有零件和工具。
配件
工具
查看更多...
  1. MacBook Unibody Model A1278 Hard Drive Replacement, Access Door: 步骤 1 中的图像 1,1
    • With the case closed, place the Unibody top-side down on a flat surface.
    • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
    This is not a a1278 unibody MacBook Pro. A1278 MacBooks backs are one solid metal piece not two separate pieces. This guide is for a different MacBook Pro.
    Brad Burgeson - 回复
    This guide isn’t for a pro; it’s a MacBook unibody.
    Nicholas -
    So, it turns out that Apple used the model code A1278 for quite a few different Mac models, including both Pro and non-Pro versions! This guide is for the non-Pro Macbooks. There’s also one for the Pro models with the same A1278 identifier.
    tempelmann - 回复
  2. MacBook Unibody Model A1278 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • The access door should now be raised enough to lift it up and out of the Unibody.
  3. MacBook Unibody Model A1278 Hard Drive Replacement, Battery: 步骤 3 中的图像 1,1
    • Be sure the access door release latch is vertical before proceeding.
    • Grab the white plastic tab and pull the battery up and out of the Unibody.
    Great tutorial ! great step !
    Leo Etcheverry - 回复
    Even though it’s specifically stated, you have to make sure the access door latch is vertical or the battery won’t be removable.
    Henry Kim - 回复
  4. MacBook Unibody Model A1278 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,1
    • Remove the single Phillips screw securing the hard drive bracket to the upper case.
    • This screw is captive to the hard drive bracket.
    My Phillips #00 screwdriver does not fit here. In fact, I´ve tried every Phillips screwdriver I have. Nothing fits. I am losing my mind trying to get that screw out.
    Glenn Gukild - 回复
    Turns out I have a stripped screw...
    Glenn Gukild -
    My drive screw head was pre-stripped. I had to drill through it to remove the drive bracket. Any idea what the specification of this screw is? It appears to be around 12mm long and 1.5mm diameter but M1.5 does not appear to exist.
    tim - 回复
    Here my screw head is worn out. Thinking of drilling it myself as well. Not happy ☹️ Any tips to the rescue to solve this without drilling?
    Robin Harleman - 回复
  5. MacBook Unibody Model A1278 Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Lift the hard drive by its pull tab enough to grab and remove the retaining bracket.
    • Lift the hard drive out of the chassis, minding the cable attaching it to the computer.
  6. MacBook Unibody Model A1278 Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Remove the hard drive from its cable by pulling the cable connector straight away from the drive.
    • Hard drive remains.
    Is this SATA 1, 2 or 3? I'm buying a SSD and am wondering if it would take advantage of Sata 3.
    Eugene - 回复
    I'm also considering an SSD, any help with this question?
    bryanlatchford - 回复
    I did some some looking around for specs at everymac.com and I came up with this.
    http://www.everymac.com/systems/apple/ma...
    From the link there it says the SATA interface is 3Gb/s, which would be SATA II.
    As for whether or not an SSD is worth it on SATA II, I found a Tom's Hardware article which explains the problem a little bit more.
    http://www.tomshardware.com/reviews/ssd-...
    Hope this helps!
    Chris Opperwall -
  7. MacBook Unibody Model A1278 Hard Drive Replacement, Hard Drive: 步骤 7 中的图像 1,1
    • Remove the two T6 Torx screws from each side of the hard drive (four screws total).
    • You'll need to transfer these screws to your new hard drive if you're changing drives.
    • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
结论
430等其他人完成本指南。
8指南评论
Radio shack has a small kit with assorted bits that includes all of the t bits
Ryan - 回复
just to be save a quick .. use super duper first on your new hdd to clone the old one... (if possible) and after installing... its like you have the same drive... no loss of files.... easy does it!
Britt - 回复
Very easy and worth the upgrade
Ivan Juarez - 回复
The model A1278 in front of me doesn't look like the above. It has 10 screws holding a single piece base onto the body, and not a single quick-release catch in sight. The battery bay looks different as well, but removing the HDD is just as easy.
StripyDonkey - 回复
That is because you are looking at a MacBook Pro A1278, not the MacBook Unibody. Apple made the regular MacBook in an aluminum enclosure in 2008 and the following aluminum model was changed to be called the MacBook Pro.
Frank Malinowski -
Anyone know where I can get that hard drive bracket? Lost mine
Chris - 回复
My hard drive bracket center screw is damaged. I can’t screw it out. Does anyone know how to get the screw out and where I can buy a new bracket center screw?
Stanley Yang - 回复
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 73
过去 30 天: 370
总计 328,206
