简介
用这条指导来更换上部机身(C壳)。
交换上部机身的一些步骤可能同时包含触摸板和电池。如果有这种情况,跳过步骤18到步骤44。
这条指导要求拆除散热铁。在你重新安装散热铁之前不要忘了依照我们的涂散热膏指导来涂散热膏。
你所需要的
在锅或平底锅里装满足够的水来完全淹没iOpener。
把水加热到沸腾。关火。
将iOpener放入热水中2-3分钟。确保iOpener完全浸入水中。
用钳子从热水中提取加热的iOpener。
用毛巾彻底擦干iOpener。
你的iOpener已准备好使用!如果你需要重新加热iOpener,请将水加热到沸点,关火,并将iOpener放入水中2-3分钟。
若要重新组装你的设备,以逆序方式执行这些说明。
18等其他人完成本指南。
由衷感谢以下译者:
97%
Yiyang Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
2条评论
This is fantastic. I had no difficulty taking my machine apart. I would suggest, however, that we also start doing reassembly guides. I'm pretty good at taking things apart. Putting them back together is a different matter entirely. I'd do one myself if I were able. Many thanks ! Sara
I’m just finished this guide/procedure for the very first time. I didn’t remove the heat sink (step 55 to 57) with a lot of patience and with extreme caution, I remove the logic board with the heat sink attached on a single part, very carefully with the fan and the I/O board, so, it’s possible but not recommend, before this steps remove the MagSafe board first, the full procedure took 3 hours.
thank for this amazing guide!
