跳转到主内容
加入维修社区 - 创建账户
MacBook Air 2022 (M2) Screen Replacement
你所需要的
    1. MacBook Air 2022 (M2) Screen Replacement, Prepare your Macbook Air for disassembly: 步骤 1 中的图像 1,3 MacBook Air 2022 (M2) Screen Replacement, Prepare your Macbook Air for disassembly: 步骤 1 中的图像 2,3 MacBook Air 2022 (M2) Screen Replacement, Prepare your Macbook Air for disassembly: 步骤 1 中的图像 3,3
      • Before you begin, discharge your battery below 25%, as a charged lithium-ion battery can be dangerous if accidentally punctured.
      • Power off your MacBook Air and unplug all cables.
      • Close the display and flip the laptop upside down. Keep the lid closed until you've physically disconnected the battery.
      询问修复机器人
      添加评论
    2. MacBook Air 2022 (M2) Screen Replacement, Unfasten the lower case: 步骤 2 中的图像 1,2 MacBook Air 2022 (M2) Screen Replacement, Unfasten the lower case: 步骤 2 中的图像 2,2
      在这个步骤中使用的工具:
      FixMat
      $36.95
      • Use a P5 Pentalobe driver to remove the four 6.4 mm screws securing the lower case:
      • Two screws with a short threaded portion near the hinges
      • Two screws with a long threaded portion near the front of the MacBook
      询问修复机器人
      添加评论
    3. MacBook Air 2022 (M2) Screen Replacement, Insert an opening pick: 步骤 3 中的图像 1,3 MacBook Air 2022 (M2) Screen Replacement, Insert an opening pick: 步骤 3 中的图像 2,3 MacBook Air 2022 (M2) Screen Replacement, Insert an opening pick: 步骤 3 中的图像 3,3
      • Apply a suction handle to the center of the lower case's front edge.
      • Pull up on the suction handle with strong, steady force to create a small gap between the lower case and the frame.
      • Insert an opening pick into the gap.
      询问修复机器人
      添加评论
    4. MacBook Air 2022 (M2) Screen Replacement, Release the snapping clips: 步骤 4 中的图像 1,3 MacBook Air 2022 (M2) Screen Replacement, Release the snapping clips: 步骤 4 中的图像 2,3 MacBook Air 2022 (M2) Screen Replacement, Release the snapping clips: 步骤 4 中的图像 3,3
      • During the next two steps you'll feel and hear four snapping clips release. If a clip doesn't release, insert your opening pick farther and try again.
      • Slide the pick to the bottom right corner to release the first clip.
      • Slide the pick around the corner and up the right edge to release the next clip.
      询问修复机器人
      添加评论
    5. MacBook Air 2022 (M2) Screen Replacement: 步骤 5 中的图像 1,3 MacBook Air 2022 (M2) Screen Replacement: 步骤 5 中的图像 2,3 MacBook Air 2022 (M2) Screen Replacement: 步骤 5 中的图像 3,3
      • Insert the opening pick in the original gap created with the suction handle.
      • Slide the opening pick to the bottom left corner and up the left edge to release the two remaining snapping clips.
      询问修复机器人
      添加评论
    6. MacBook Air 2022 (M2) Screen Replacement, Release the sliding tabs: 步骤 6 中的图像 1,3 MacBook Air 2022 (M2) Screen Replacement, Release the sliding tabs: 步骤 6 中的图像 2,3 MacBook Air 2022 (M2) Screen Replacement, Release the sliding tabs: 步骤 6 中的图像 3,3
      • Four sliding tabs along the back edge of the MacBook firmly secure the lower case. Separating these tabs requires a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
      • Keep the lower case flat and firmly pull it straight away from the back edge, one corner at a time, to disengage the sliding tabs.
      • Don't pull up until the cover is completely separated.
      添加评论
    7. MacBook Air 2022 (M2) Screen Replacement, Remove the lower case: 步骤 7 中的图像 1,3 MacBook Air 2022 (M2) Screen Replacement, Remove the lower case: 步骤 7 中的图像 2,3 MacBook Air 2022 (M2) Screen Replacement, Remove the lower case: 步骤 7 中的图像 3,3
      • Remove the lower case.
      • During reassembly:
      • Set the lower case in place and align the sliding tabs with the screw heads they slide over. Press down and slide the lower case toward the back edge to engage the tabs—it'll stop sliding as the tabs engage.
      • When one side is engaged, it may push the other out of alignment. Check both sides as you push, there should be no gap along the back edge.
      • Once the lower case is flush with the frame, press down firmly along the perimeter to engage the four snapping clips.
      • You'll hear and feel a distinct click as each clip snaps into place.
      添加评论
    1. MacBook Air 2022 (M2) Screen Replacement, Remove the battery connector cover: 步骤 8 中的图像 1,1
      • Use a T3 Torx driver to remove the two 1.5 mm screws securing the battery connector cover.
      询问修复机器人
      添加评论
    2. MacBook Air 2022 (M2) Screen Replacement: 步骤 9 中的图像 1,2 MacBook Air 2022 (M2) Screen Replacement: 步骤 9 中的图像 2,2
      • Remove the battery connector cover.
      询问修复机器人
      添加评论
    3. MacBook Air 2022 (M2) Screen Replacement, Disconnect the battery: 步骤 10 中的图像 1,2 MacBook Air 2022 (M2) Screen Replacement, Disconnect the battery: 步骤 10 中的图像 2,2
      • Use an opening pick to pry up and disconnect the battery press connector.
      • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It might take a few tries to align the connector.
      添加评论
    1. MacBook Air 2022 (M2) Screen Replacement, Remove the display cable cover foam: 步骤 11 中的图像 1,2 MacBook Air 2022 (M2) Screen Replacement, Remove the display cable cover foam: 步骤 11 中的图像 2,2
      • Peel up and remove the foam pad from the lower display cable cover to reveal a hidden screw.
      询问修复机器人
      添加评论
    1. MacBook Air 2022 (M2) Screen Replacement, Remove the cable covers: 步骤 12 中的图像 1,2 MacBook Air 2022 (M2) Screen Replacement, Remove the cable covers: 步骤 12 中的图像 2,2
      • Use a T3 Torx driver to remove the nine 1.5 mm screws securing the four metal covers.
      添加评论
    2. MacBook Air 2022 (M2) Screen Replacement: 步骤 13 中的图像 1,3 MacBook Air 2022 (M2) Screen Replacement: 步骤 13 中的图像 2,3 MacBook Air 2022 (M2) Screen Replacement: 步骤 13 中的图像 3,3
      • Remove the four metal covers:
      • Two speaker cable covers
      • One display cable cover
      • One antenna cable cover
      询问修复机器人
      添加评论
    3. MacBook Air 2022 (M2) Screen Replacement: 步骤 14 中的图像 1,2 MacBook Air 2022 (M2) Screen Replacement: 步骤 14 中的图像 2,2
      • Remove the four screws securing the upper display cable cover:
      • Two 2.5 mm P2 Pentalobe screws
      • Two 2.5 mm 3IP Torx plus screws
      • During reassembly, the Pentalobe screws must thread into the display cable securing bracket.
      添加评论
    4. MacBook Air 2022 (M2) Screen Replacement: 步骤 15 中的图像 1,3 MacBook Air 2022 (M2) Screen Replacement: 步骤 15 中的图像 2,3 MacBook Air 2022 (M2) Screen Replacement: 步骤 15 中的图像 3,3
      • Remove the upper display cable cover and plastic securing bracket.
      • During reassembly, make sure the top edge of the upper display cable cover is under the securing bracket.
      询问修复机器人
      添加评论
    5. MacBook Air 2022 (M2) Screen Replacement, Disconnect the cables: 步骤 16 中的图像 1,3 MacBook Air 2022 (M2) Screen Replacement, Disconnect the cables: 步骤 16 中的图像 2,3 MacBook Air 2022 (M2) Screen Replacement, Disconnect the cables: 步骤 16 中的图像 3,3
      • Use the pointed end of a spudger to pry up and disconnect both display cable press connectors.
      添加评论
    6. MacBook Air 2022 (M2) Screen Replacement: 步骤 17 中的图像 1,3 MacBook Air 2022 (M2) Screen Replacement: 步骤 17 中的图像 2,3 MacBook Air 2022 (M2) Screen Replacement: 步骤 17 中的图像 3,3
      • Disconnect the left and right speaker press connectors.
      添加评论
    7. MacBook Air 2022 (M2) Screen Replacement: 步骤 18 中的图像 1,3 MacBook Air 2022 (M2) Screen Replacement: 步骤 18 中的图像 2,3 MacBook Air 2022 (M2) Screen Replacement: 步骤 18 中的图像 3,3
      在这个步骤中使用的工具:
      • Use a pair of tweezers to grip the first antenna connector, as close to its base as possible.
      • Lift straight up to disconnect the cable.
      • The antenna connectors on the logic board are very fragile. When disconnecting the cables, pull straight up—don’t bend them to the side.
      • Repeat for the second antenna cable.
      • To reattach antenna connectors like these, align the connector over its socket and press down with the flat end of a spudger. The connector should snap into place. This can be tricky and may take a few tries.
      询问修复机器人
      添加评论
    8. MacBook Air 2022 (M2) Screen Replacement, Remove the hinge covers: 步骤 19 中的图像 1,2 MacBook Air 2022 (M2) Screen Replacement, Remove the hinge covers: 步骤 19 中的图像 2,2
      • These screws strip easily. Apply constant, downward force to prevent stripping.
      • Use a 3IP Torx Plus driver to remove the two 2.6 mm screws securing the right and left hinge covers.
      添加评论
    9. MacBook Air 2022 (M2) Screen Replacement: 步骤 20 中的图像 1,3 MacBook Air 2022 (M2) Screen Replacement: 步骤 20 中的图像 2,3 MacBook Air 2022 (M2) Screen Replacement: 步骤 20 中的图像 3,3
      • Grip the left hinge cover with blunt nose tweezers.
      • Pull the cover towards the bottom of the laptop and upwards to free it from its recess.
      • Pull up and remove the hinge cover.
      询问修复机器人
      添加评论
    10. MacBook Air 2022 (M2) Screen Replacement: 步骤 21 中的图像 1,3 MacBook Air 2022 (M2) Screen Replacement: 步骤 21 中的图像 2,3 MacBook Air 2022 (M2) Screen Replacement: 步骤 21 中的图像 3,3
      • Repeat the previous step to remove the right hinge cover.
      询问修复机器人
      添加评论
    11. MacBook Air 2022 (M2) Screen Replacement, Remove the speakers: 步骤 22 中的图像 1,2 MacBook Air 2022 (M2) Screen Replacement, Remove the speakers: 步骤 22 中的图像 2,2
      • Remove the six screws securing the left and right speakers:
      • Four 5.6 mm 4IP Torx Plus screws (two on each speaker)
      • Two 3.5 mm T5 Torx screws (one on each speaker)
      添加评论
    12. MacBook Air 2022 (M2) Screen Replacement: 步骤 23 中的图像 1,3 MacBook Air 2022 (M2) Screen Replacement: 步骤 23 中的图像 2,3 MacBook Air 2022 (M2) Screen Replacement: 步骤 23 中的图像 3,3
      • Lift the speakers straight up and remove them.
      添加评论
    13. MacBook Air 2022 (M2) Screen Replacement, Disconnect the lid-angle sensor: 步骤 24 中的图像 1,2 MacBook Air 2022 (M2) Screen Replacement, Disconnect the lid-angle sensor: 步骤 24 中的图像 2,2
      • Use a T3 Torx screwdriver to remove the two 1.5 mm screws securing the lid-angle sensor connector cover.
      添加评论
    14. MacBook Air 2022 (M2) Screen Replacement: 步骤 25 中的图像 1,2 MacBook Air 2022 (M2) Screen Replacement: 步骤 25 中的图像 2,2
      • Remove the lid-angle sensor connector cover.
      询问修复机器人
      添加评论
    15. MacBook Air 2022 (M2) Screen Replacement: 步骤 26 中的图像 1,2 MacBook Air 2022 (M2) Screen Replacement: 步骤 26 中的图像 2,2
      • Use the pointed end of a spudger to pry up and disconnect lid angle sensor press connector.
      询问修复机器人
      添加评论
    16. MacBook Air 2022 (M2) Screen Replacement: 步骤 27 中的图像 1,2 MacBook Air 2022 (M2) Screen Replacement: 步骤 27 中的图像 2,2
      • Gently peel the lid angle sensor cable from the top of the headphone jack and move it out of the way.
      询问修复机器人
      添加评论
    17. MacBook Air 2022 (M2) Screen Replacement, Check for a lid‑angle sensor: 步骤 28 中的图像 1,3 MacBook Air 2022 (M2) Screen Replacement, Check for a lid‑angle sensor: 步骤 28 中的图像 2,3 MacBook Air 2022 (M2) Screen Replacement, Check for a lid‑angle sensor: 步骤 28 中的图像 3,3
      • Check if your replacement screen has a lid‑angle sensor installed on the hinge. If it does, skip this step. Otherwise, follow this step to remove the sensor—you'll need to transfer it to your replacement screen.
      • Use the point of a spudger to lift the flap covering the lid‑angle sensor screw, located on the left hinge.
      • Use a 1IP Torx Plus driver to remove the screw securing the lid‑angle sensor.
      • Remove the lid‑angle sensor and set it aside for reassembly.
      添加评论
    18. MacBook Air 2022 (M2) Screen Replacement, Loosen the hinge screws: 步骤 29 中的图像 1,2 MacBook Air 2022 (M2) Screen Replacement, Loosen the hinge screws: 步骤 29 中的图像 2,2
      • Use an 8IP Torx Plus driver to loosen (not remove) the six hinge screws.
      询问修复机器人
      添加评论
    19. MacBook Air 2022 (M2) Screen Replacement, Open your MacBook and set it down: 步骤 30 中的图像 1,2 MacBook Air 2022 (M2) Screen Replacement, Open your MacBook and set it down: 步骤 30 中的图像 2,2
      • Fully open your MacBook and gently place it keyboard side down on a table so the screen hangs over the edge.
      添加评论
    20. MacBook Air 2022 (M2) Screen Replacement, Remove the hinge screws: 步骤 31 中的图像 1,3 MacBook Air 2022 (M2) Screen Replacement, Remove the hinge screws: 步骤 31 中的图像 2,3 MacBook Air 2022 (M2) Screen Replacement, Remove the hinge screws: 步骤 31 中的图像 3,3
      • Support the screen with one hand and use your free hand to remove the six 4.3 mm 8IP Torx Plus screws securing the hinges.
      • Keep a firm grip on your laptop, as it can easily fall off the table.
      询问修复机器人
      添加评论
    21. MacBook Air 2022 (M2) Screen Replacement, Remove the screen: 步骤 32 中的图像 1,3 MacBook Air 2022 (M2) Screen Replacement, Remove the screen: 步骤 32 中的图像 2,3 MacBook Air 2022 (M2) Screen Replacement, Remove the screen: 步骤 32 中的图像 3,3
      • Hold the screen with both hands and lift the hinges out of their recesses to remove the screen.
      • Make sure the screen hinges are fully open and guide them into their recesses in the frame.
      • Install and partially tighten the six hinge screws.
      • Close your laptop and make sure the screen is properly aligned. If it clicks or snaps, readjust the alignment.
      • Fully tighten the hinge screws.
      添加评论
结论
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting or check out our Answers community for help.
取消:我没有完成这个指南。
42等其他人完成本指南。
Spencer Day
于09/14/22注册
197,714 声望
创作了1,243篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了42,773篇指南
43指南评论
Does the screen display normally after replacing it with the aftermarket screen? As far as I know, after 2021, MacBooks have problems with screen output when they are replaced with aftermarket screens.
https://www.ifixit.com/News/73288/m2-mac...
wellbinnn - 回复 分享
Hi! We tested swapping screens between two M2 MacBook Airs and didn't find any issues with the screen. The problem is with the MacBook Pros.
Spencer Day - 回复 分享
I checked your comment. Thanks for checking!
wellbinnn - 回复 分享
Is this doable without scratching or chipping the body if done using the ifixit tool kit?
John Mashconzone - 回复 分享
Hello! It's definitely doable! If you're worried, I would take extra care when standing the laptop up to make sure you set it on a surface that won't scratch the body. Also, be careful when guiding the hinges out of the frame to avoid brushing against the frame.
Spencer Day - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 134
过去 7 天: 835
过去 30 天: 3,893
总计 136,940
