跳转到主内容
加入维修社区 - 创建账户
Logitech Signature Slim Solar+ Battery Replacement
你所需要的
    1. Logitech Signature Slim Solar+ Battery Replacement, Prepare your keyboard for disassembly: 步骤 1 中的图像 1,2 Logitech Signature Slim Solar+ Battery Replacement, Prepare your keyboard for disassembly: 步骤 1 中的图像 2,2
      • Slide the keyboard's power switch into the OFF position.
      • A red indicator should be visible beneath the switch.
      • Lay your keyboard down with the feet facing up on a clean work surface.
      • If your work surface may scratch the keyboard, place a soft towel under it.
      询问修复机器人
      添加评论
    2. Logitech Signature Slim Solar+ Battery Replacement, Remove the feet: 步骤 2 中的图像 1,3 Logitech Signature Slim Solar+ Battery Replacement, Remove the feet: 步骤 2 中的图像 2,3 Logitech Signature Slim Solar+ Battery Replacement, Remove the feet: 步骤 2 中的图像 3,3
      • Insert the point of a spudger under an end of the foot.
      • Push the spudger underneath the foot and lift until you can grip it with your fingers.
      • Peel the foot up and remove it. Keep it for reassembly.
      询问修复机器人
      添加评论
    3. Logitech Signature Slim Solar+ Battery Replacement, Remove the remaining top feet: 步骤 3 中的图像 1,3 Logitech Signature Slim Solar+ Battery Replacement, Remove the remaining top feet: 步骤 3 中的图像 2,3 Logitech Signature Slim Solar+ Battery Replacement, Remove the remaining top feet: 步骤 3 中的图像 3,3
      • Repeat the procedure to remove two remaining feet along the top edge. Keep these for reassembly.
      询问修复机器人
      添加评论
    4. Logitech Signature Slim Solar+ Battery Replacement, Remove the battery cover: 步骤 4 中的图像 1,1
      • Use a Phillips screwdriver to loosen the three captive screws securing the battery cover.
      询问修复机器人
      添加评论
    5. Logitech Signature Slim Solar+ Battery Replacement: 步骤 5 中的图像 1,3 Logitech Signature Slim Solar+ Battery Replacement: 步骤 5 中的图像 2,3 Logitech Signature Slim Solar+ Battery Replacement: 步骤 5 中的图像 3,3
      • Lift and remove the battery cover.
      询问修复机器人
      添加评论
    6. Logitech Signature Slim Solar+ Battery Replacement: 步骤 6 中的图像 1,2 Logitech Signature Slim Solar+ Battery Replacement: 步骤 6 中的图像 2,2
      • Use your fingers or a spudger to lift and remove the battery by its side tabs.
      询问修复机器人
      添加评论
    7. Logitech Signature Slim Solar+ Battery Replacement, Install the replacement battery: 步骤 7 中的图像 1,3 Logitech Signature Slim Solar+ Battery Replacement, Install the replacement battery: 步骤 7 中的图像 2,3 Logitech Signature Slim Solar+ Battery Replacement, Install the replacement battery: 步骤 7 中的图像 3,3
      • Align the battery with its recess and push down firmly with your finger to click it in place.
      询问修复机器人
      添加评论
    8. Logitech Signature Slim Solar+ Battery Replacement, Reassemble the keyboard: 步骤 8 中的图像 1,2 Logitech Signature Slim Solar+ Battery Replacement, Reassemble the keyboard: 步骤 8 中的图像 2,2
      • Lay the battery cover in place and gently press it onto the keyboard to engage the clips.
      询问修复机器人
      添加评论
    9. Logitech Signature Slim Solar+ Battery Replacement: 步骤 9 中的图像 1,1
      • Use a Phillips screwdriver to tighten the three captive screws securing the battery cover.
      询问修复机器人
      添加评论
    10. Logitech Signature Slim Solar+ Battery Replacement: 步骤 10 中的图像 1,3 Logitech Signature Slim Solar+ Battery Replacement: 步骤 10 中的图像 2,3 Logitech Signature Slim Solar+ Battery Replacement: 步骤 10 中的图像 3,3
      在这个步骤中使用的工具:
      Tesa 61395 Tape
      $2.95
      • If you're installing new feet, remove them from their backing and firmly press them into place.
      • If you're reusing the feet, use a strip of double-sided tape to secure them in their recesses.
      询问修复机器人
      添加评论
结论
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
取消:我没有完成这个指南。
Arthur Shi
于01/03/18注册
344,618 声望
创作了915篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 33
过去 30 天: 156
总计 1,174
