跳转到主内容
加入维修社区 - 创建账户
Logitech G522 Lightspeed Ear Pads Replacement
    1. Logitech G522 Lightspeed Ear Pads Replacement, Prepare the headset for disassembly: 步骤 1 中的图像 1,2 Logitech G522 Lightspeed Ear Pads Replacement, Prepare the headset for disassembly: 步骤 1 中的图像 2,2
      • Power off the headset and unplug all cables.
      询问修复机器人
      添加评论
    1. Logitech G522 Lightspeed Ear Pads Replacement, Remove the ear pads: 步骤 2 中的图像 1,3 Logitech G522 Lightspeed Ear Pads Replacement, Remove the ear pads: 步骤 2 中的图像 2,3 Logitech G522 Lightspeed Ear Pads Replacement, Remove the ear pads: 步骤 2 中的图像 3,3
      • With one hand, firmly hold an ear cup steady.
      • With your free hand, slowly pull the ear pad away from the cup until it slides completely off its plastic lip.
      • Repeat the process to remove the other ear pad.
      询问修复机器人
      添加评论
    2. Logitech G522 Lightspeed Ear Pads Replacement, Install an ear pad: 步骤 3 中的图像 1,3 Logitech G522 Lightspeed Ear Pads Replacement, Install an ear pad: 步骤 3 中的图像 2,3 Logitech G522 Lightspeed Ear Pads Replacement, Install an ear pad: 步骤 3 中的图像 3,3
      • Installing an ear pad onto the cup can be tricky. Be patient and work slowly—it may take a couple tries.
      • To put an ear pad onto its cup:
      • With your free hand, place the pad over the top of the cup, so the fabric flap slips over the cup's plastic lip.
      • Thread the rest of the flap over the lip, working your way around the entire cup. Gently stretch the pad as necessary.
      • Check the entire perimeter of the cup to make sure the ear pad is fully on. If any of the fabric flap is sticking out, try to push it over the lip or remove the ear pad and try again.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Arthur Shi
于01/03/18注册
345,183 声望
创作了915篇指南
1指南评论
Where can you buy the earpad replacement for the G522 Lightspeed Headset? Can't seem to find it anywhere! Thanks!
kingjulian - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 40
过去 30 天: 160
总计 1,945
