跳转到主内容
Lenovo ThinkPad T16 Gen 3 Smart Card Reader Replacement
Nick Schultz
Nick Schultz
最后更新于 August 7, 2024
20 - 30 分钟
中等
Follow this guide to replace a damaged or malfunctioning smart card reader in your Lenovo ThinkPad T16 Gen 3 laptop. You can also use this guide to replace a "dummy" smart card reader with a real one.
If your smart card reader is not being detected or is no longer reading smart cards properly, it may need to be replaced.
The Lenovo part number for the smart card reader is 5C61B41060 or 5C61B41061. This guide features the former, but the process is equivalent for the latter.
你所需要的
工具
查看更多...
  1. Lenovo ThinkPad T16 Gen 3 Smart Card Reader Replacement, Prepare your laptop for disassembly: 步骤 1 中的图像 1,3 Lenovo ThinkPad T16 Gen 3 Smart Card Reader Replacement, Prepare your laptop for disassembly: 步骤 1 中的图像 2,3 Lenovo ThinkPad T16 Gen 3 Smart Card Reader Replacement, Prepare your laptop for disassembly: 步骤 1 中的图像 3,3
    • For your safety, discharge your battery below 25% before disassembling your laptop. A charged battery may catch fire if damaged. If your battery is swollen, take appropriate precautions.
    • Completely shut down your laptop (don't just put it in sleep mode) and disconnect all cables.
    • Flip the laptop upside-down, and rotate it so the screen hinge faces towards you.
  2. Lenovo ThinkPad T16 Gen 3 Smart Card Reader Replacement, Loosen the base cover screws: 步骤 2 中的图像 1,2 Lenovo ThinkPad T16 Gen 3 Smart Card Reader Replacement, Loosen the base cover screws: 步骤 2 中的图像 2,2
    • Use a Phillips screwdriver to fully loosen the seven captive screws securing the base cover.
  3. Lenovo ThinkPad T16 Gen 3 Smart Card Reader Replacement, Pry up the base cover: 步骤 3 中的图像 1,3 Lenovo ThinkPad T16 Gen 3 Smart Card Reader Replacement, Pry up the base cover: 步骤 3 中的图像 2,3 Lenovo ThinkPad T16 Gen 3 Smart Card Reader Replacement, Pry up the base cover: 步骤 3 中的图像 3,3
    • Insert your fingernail or an opening pick into the gap between the base cover and keyboard deck, next to one of the screen hinges.
    • Pry up the base cover until the clips unfasten.
  4. Lenovo ThinkPad T16 Gen 3 Smart Card Reader Replacement, Remove the base cover: 步骤 4 中的图像 1,2 Lenovo ThinkPad T16 Gen 3 Smart Card Reader Replacement, Remove the base cover: 步骤 4 中的图像 2,2
    • Grasp the base cover along the screen hinge edge and lift slowly to unfasten the remaining clips.
    • Lift and remove the base cover.
    • During reassembly, lay the base cover into the frame, inserting it into the tabs along the battery edge. Press down firmly around the perimeter to reengage all the clips.
  5. Lenovo ThinkPad T16 Gen 3 Smart Card Reader Replacement, Loosen the battery screws: 步骤 5 中的图像 1,2 Lenovo ThinkPad T16 Gen 3 Smart Card Reader Replacement, Loosen the battery screws: 步骤 5 中的图像 2,2
    • Because of the battery connector's design, the only way to disconnect the battery is by physically removing it.
    • Use a Phillips screwdriver to fully loosen the two captive screws securing the battery connector.
  6. Lenovo ThinkPad T16 Gen 3 Smart Card Reader Replacement, Remove the battery: 步骤 6 中的图像 1,3 Lenovo ThinkPad T16 Gen 3 Smart Card Reader Replacement, Remove the battery: 步骤 6 中的图像 2,3 Lenovo ThinkPad T16 Gen 3 Smart Card Reader Replacement, Remove the battery: 步骤 6 中的图像 3,3
    • Lift the edge of the battery with the connector to disconnect it.
    • You may feel a little resistance from the battery connector as it disconnects—that's normal.
    • Remove the battery
    • During reassembly:
    • Slide the plastic tabs on the long edge of the battery into their recesses in the frame.
    • Lower the battery into place so the connector goes over its socket.
  7. Lenovo ThinkPad T16 Gen 3 Smart Card Reader Replacement, Disconnect the smart card reader cable: 步骤 7 中的图像 1,3 Lenovo ThinkPad T16 Gen 3 Smart Card Reader Replacement, Disconnect the smart card reader cable: 步骤 7 中的图像 2,3 Lenovo ThinkPad T16 Gen 3 Smart Card Reader Replacement, Disconnect the smart card reader cable: 步骤 7 中的图像 3,3
    • Use the flat end of a spudger or your fingernail to flip up the locking flap on the smart card cable ZIF connector.
    • Use your fingers or tweezers to pull the cable straight out of its socket.
  8. Lenovo ThinkPad T16 Gen 3 Smart Card Reader Replacement, Remove the smart card reader screws: 步骤 8 中的图像 1,2 Lenovo ThinkPad T16 Gen 3 Smart Card Reader Replacement, Remove the smart card reader screws: 步骤 8 中的图像 2,2
    • Use a Phillips screwdriver to remove the two 2.5 mm‑long screws securing the smart card reader to the frame.
  9. Lenovo ThinkPad T16 Gen 3 Smart Card Reader Replacement, Remove the smart card reader: 步骤 9 中的图像 1,3 Lenovo ThinkPad T16 Gen 3 Smart Card Reader Replacement, Remove the smart card reader: 步骤 9 中的图像 2,3 Lenovo ThinkPad T16 Gen 3 Smart Card Reader Replacement, Remove the smart card reader: 步骤 9 中的图像 3,3
    • Slide the smart card reader straight back towards its disconnected ribbon cable, and then pull it straight up to remove it.
结论
Compare your new replacement part to the original part—you may need to transfer remaining components from the new part before you install it.
Nick Schultz
于03/24/24注册
19,546 声望
创作了114篇指南
团队
iFixit iFixit 的会员
Staff
121 名成员
创作了19,763篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 42
总计 345
