跳转到主内容
LG V20 Earpiece Speaker Replacement
Caroline Cullen
Caroline Cullen6 其他贡献者
最后更新于 May 7, 2024
15 - 20 分钟
中等
Use this guide to replace the earpiece speaker in your LG V20.
你所需要的
工具
查看更多...
  1. LG V20 Earpiece Speaker Replacement, Battery: 步骤 1 中的图像 1,3 LG V20 Earpiece Speaker Replacement, Battery: 步骤 1 中的图像 2,3 LG V20 Earpiece Speaker Replacement, Battery: 步骤 1 中的图像 3,3
    • Before disassembling your phone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Insert a spudger or your fingernail under the battery at the small recess on the lower edge.
    • Be careful not to deform or puncture the battery.
    • Pry up and remove the battery.
  2. LG V20 Earpiece Speaker Replacement, Midframe Assembly: 步骤 2 中的图像 1,1
    • Remove the sixteen 4mm Phillips #00 screws attaching the back cover to the motherboard.
  3. LG V20 Earpiece Speaker Replacement: 步骤 3 中的图像 1,2 LG V20 Earpiece Speaker Replacement: 步骤 3 中的图像 2,2
    • The top and bottom frame section hold very tight to the mid frame. It is possible to pull them off with your hands. If you're not able to do so, use the following removal procedure:
    • Use the flat end of a spudger and apply pressure to one of the corners of the frame section until you create a small gap.
  4. LG V20 Earpiece Speaker Replacement: 步骤 4 中的图像 1,2 LG V20 Earpiece Speaker Replacement: 步骤 4 中的图像 2,2
    • Flip the phone and insert an opening pick in the gap you created.
    • Slide the opening pick along the gap until the frame section pops out of its plastic clamps.
    People on Reddit are reporting that the V20's antennas are contained in this top piece, and removing it too forcefully can damage the 2G antenna's contacts, resulting in a loss of ability to make calls. Details and a suggested fix if this happens to you:
    https://old.reddit.com/r/lgv20/comments/...
    databasebloat - 回复
  5. LG V20 Earpiece Speaker Replacement: 步骤 5 中的图像 1,1
    • Remove the frame section.
    • Repeat this procedure with the frame section on the other end of the phone.
    • Within the top frame section there's a small silver grating that covers the speaker. This may fall out, so be careful not to lose it.
  6. LG V20 Earpiece Speaker Replacement: 步骤 6 中的图像 1,2 LG V20 Earpiece Speaker Replacement: 步骤 6 中的图像 2,2
    • The loudspeaker is attached to the cover of the motherboard. Use an opening pick to pry it up.
    Be very careful with prying up the speaker or else it will break the connection to the cover.
    Peter Halenbeck - 回复
  7. LG V20 Earpiece Speaker Replacement: 步骤 7 中的图像 1,2 LG V20 Earpiece Speaker Replacement: 步骤 7 中的图像 2,2
    • The cover of the motherboard is held in its place by several plastic clamps.
    • Use an opening pick to pry up the motherboard cover at the right corner at the bottom of your phone until it pops out of the plastic clamp.
    Bonjour, en placant le médiator à l’intérieur de l’emplacement de la batterie le démontage est plus facile de l’intérieur vers l’extérieur…
    pat pat - 回复
    Merci pour l’info!
    Nicolas Pierret -
    In English: it is easier work your way around the inside of the battery compartment rather than around the outside. Also, the clip below the power button (i.e., top of the battery compartment) will release the whole top edge.
    Joseph Morris - 回复
  8. LG V20 Earpiece Speaker Replacement: 步骤 8 中的图像 1,2 LG V20 Earpiece Speaker Replacement: 步骤 8 中的图像 2,2
    • Slide the opening pick along the mid frame and flip it sideways to open the plastic clamps holding the motherboard cover in its place.
  9. LG V20 Earpiece Speaker Replacement: 步骤 9 中的图像 1,1
    • Remove the motherboard cover.
  10. LG V20 Earpiece Speaker Replacement, Front-Facing Camera: 步骤 10 中的图像 1,2 LG V20 Earpiece Speaker Replacement, Front-Facing Camera: 步骤 10 中的图像 2,2
    在这个步骤中使用的工具:
    • Use the flat end of a spudger to disconnect the front camera flex cable.
    • If you want to go on and remove the motherboard assembly, there is no need to remove the front facing camera after disconnecting it. However if you feel uncertain, carefully remove it with a pair of tweezers.
    • Use a pair of tweezers to carefully remove the front facing camera. Be careful to only grip the body of the camera, as the top is the sensor pcb and is only held on with glue (removal will ruin the sensor).
  11. LG V20 Earpiece Speaker Replacement, Motherboard Assembly: 步骤 11 中的图像 1,1
    在这个步骤中使用的工具:
    • Use the flat end of a spudger to disconnect the flex cable of the left rear camera.
    • The second rear camera will come out with the motherboard since it is connected on the other side.
    • You can leave the front facing camera in its place as long as you're careful while removing the motherboard assembly. However if you feel uncertain, carefully remove it with a pair of tweezers.
    Anyone have a picture of the back of the board by the charge port
    DANIEL HOCH - 回复
  12. LG V20 Earpiece Speaker Replacement: 步骤 12 中的图像 1,1
    • Disconnect the display flex cable with the flat end of a spudger.
  13. LG V20 Earpiece Speaker Replacement: 步骤 13 中的图像 1,2 LG V20 Earpiece Speaker Replacement: 步骤 13 中的图像 2,2
    • Use the pointed end of a spudger to lift up the motherboard assembly until you can get a good grip.
    • Carefully lift up the motherboard assembly and remove it.
    Be very careful handling motherboard. The numerous spring-type contact points can be easily bent.
  14. LG V20 Earpiece Speaker Replacement, Earpiece Speaker: 步骤 14 中的图像 1,1
    • Use an iOpener to loosen the adhesive beneath the earpiece speaker and its flex cable.
    What is the module just to the right of the front-facing camera?
    Brian Doherty - 回复
  15. LG V20 Earpiece Speaker Replacement: 步骤 15 中的图像 1,2 LG V20 Earpiece Speaker Replacement: 步骤 15 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to carefully lift the earpiece speaker out of the device and remove it.
    • Take especially care of the small flex cable attached to it.
结论
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where it’s necessary.
6等其他人完成本指南。
团队
Cal Poly, Team S22-G5, Livingston Spring 2017 Cal Poly, Team S22-G5, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S22G5
4 名成员
创作了36篇指南
1指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 32
总计 3,504
