跳转到主内容
LG G Pad 8.3 Battery Replacement
Mario Salguero
Mario Salguero7 其他贡献者
最后更新于 February 21, 2020
20分钟
困难
缺少的步骤
更好的介绍
If your LG G Pad 8.3 battery isn't working, it may be time to replace it. This guide will show you how to replace the battery.
你所需要的
工具
查看更多...
  1. LG G Pad 8.3 Battery Replacement, Back Panel: 步骤 1 中的图像 1,2 LG G Pad 8.3 Battery Replacement, Back Panel: 步骤 1 中的图像 2,2
    • With the tablet face down, pull the SD card slot cover out.
    • Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
  2. LG G Pad 8.3 Battery Replacement: 步骤 2 中的图像 1,3 LG G Pad 8.3 Battery Replacement: 步骤 2 中的图像 2,3 LG G Pad 8.3 Battery Replacement: 步骤 2 中的图像 3,3
    • Insert a plastic opening tool in the small crevasse between the screen and the back panel.
    • Pry the screen away from the back panel.
    • Repeat this on each edge of the device.
    • We found it helpful to leave multiple plastic opening tools wedged in the crevasse to prevent it from closing.
    • This requires heavy force. The back of the device is attached with an adhesive. If the back panel is too hard to remove, use the iOpener.
    My old G-Pad had its screen separated from the rest of the front part and the back panel, so if you have just a slim glass come off, do not pull that off. Use a flat spudger to loosen those hooks and help the rest of the front part come out with the screen attached.
    George - 回复
  3. LG G Pad 8.3 Battery Replacement: 步骤 3 中的图像 1,2 LG G Pad 8.3 Battery Replacement: 步骤 3 中的图像 2,2
    • After using the plastic opening tools, pry the device open with your hands.
    • Remove the back panel from the screen.
  4. LG G Pad 8.3 Battery Replacement, Speaker: 步骤 4 中的图像 1,2 LG G Pad 8.3 Battery Replacement, Speaker: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    • Remove the four 3 mm Phillips #000 screws that are attached to the speaker.
    • These screws are very small so make sure to keep track of them. You can use iFixit's Pro Magnetic Project Mat to help.
    On the VK810 Model you have to watch out for the antenna wire that runs along and is attached to the speaker by the means of a metal wire clip.
    What I would recommend is detaching the antenna wire from the top of the device then gently remove it from the clip.
    Then remove the speaker.
    On a side note does anyone know where to buy the little ant wire that runs across the speaker?
    Kyle - 回复
  5. LG G Pad 8.3 Battery Replacement: 步骤 5 中的图像 1,1
    • Use your fingers to remove the speaker.
  6. LG G Pad 8.3 Battery Replacement, Battery: 步骤 6 中的图像 1,2 LG G Pad 8.3 Battery Replacement, Battery: 步骤 6 中的图像 2,2
    • Remove the 3mm Phillips #000 screws from the corners of the battery.
  7. LG G Pad 8.3 Battery Replacement: 步骤 7 中的图像 1,3 LG G Pad 8.3 Battery Replacement: 步骤 7 中的图像 2,3 LG G Pad 8.3 Battery Replacement: 步骤 7 中的图像 3,3
    • Using a spudger or a plastic opening tool, disconnect the ribbon cable from the right side of the device.
    • The cable is attached with an adhesive.
    • These images use a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
  8. LG G Pad 8.3 Battery Replacement: 步骤 8 中的图像 1,2 LG G Pad 8.3 Battery Replacement: 步骤 8 中的图像 2,2
    • Using the Phillips #000 screwdriver, remove the two 3mm screws located at the bottom of the ribbon cable.
    • Remove the ribbon cable from the device.
  9. LG G Pad 8.3 Battery Replacement: 步骤 9 中的图像 1,2 LG G Pad 8.3 Battery Replacement: 步骤 9 中的图像 2,2
    • Unhook the battery from the top of the device.
    Watch out: I had to remove the mainboard first, before being able to lift the battery with its attached hook on top.
    Sven Meier - 回复
    The screen on my device separated from the main board which is still in the back of the device. I can’t get to the under side to remove the speakers and battery.
    Chris C - 回复
结论
18等其他人完成本指南。
Mario Salguero
于09/14/15注册
781 声望
创作了6篇指南
团队
CSU Fullerton, Team 1-6, Bruce Fall 2015 CSU Fullerton, Team 1-6, Bruce Fall 2015 的会员
CSUF-BRUCE-F15S1G6
4 名成员
创作了14篇指南
9指南评论
Every teardown I can find on this tablet has that darn screw in the sd card slot, but mine does not!! Does ANYBODY have teardown for mine? I can send pics, it's Verizon Gpad 8.3 LTE, slot holds sd and sim but NO screw. Son spilled water on it so screen is all dark and haptic stays on, I'd like to attempt the rice trick if I can open it.
Wesley Krasko - 回复
The other models have a sponge adhesive on the back of the battery.
Completely disregard the first screw.
supramaster2099 -
Wesley - Me too. I have no idea why Android released two different models with the same freaking model name. I thought they had more common sense than that. If anyone has the teardown for the new model, holler.
Slavelike Constructs - 回复
Same here. No screw
jon - 回复
sorry this teardown is not for the 8.3
krackeddude - 回复
I have the VK810, can't find instructions anywhere.
I also have no screw, but I got it open by starting on the right side and fitting a flat spudger between the frame and the screen and pressing the tool deeper towards the back. This unlocks the snap. There are 5 of these plastic snaps built into the body of the frame on the long sides and a few along the top and bottom. Once I got the right side slightly separated, I worked on the top, then the bottom (used 2 spudgers, one kept the gap open on the side while I worked the top and bottom), then continued inserting the tool along the left side until all the lock tabs were released. The internals look the same as these pics once I got it open. I need to replace the charger plug and will swap the battery as well while I'm at it.
Barrett Abney - 回复
so, where can I get a replacement battery from?
dalemcginnis - 回复
This is not the vk810. Its the v500. It is wifi only
Justin Jantzen - 回复
There is a difference that was notice in my comparison between this Guide and the LG G Pad X 8.3 Guide. This guide has only three (3) screws holding the battery and much more removal of parts than the X 8.3. The X 8.3 also has four (4) screws holding it in. Is the X 8.3 shown on this site the same as the one used by Verizon ? I do Not know, if there is a difference, currently.
This looks to be a helpful Guide, but there is no help in WHERE to purchase a battery and if there could be a different battery with higher capacity and a longer life as a choice. As a Consumer, this type of information would be helpful. Can anyone assist ?
Harvey Rothenberg - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 54
总计 44,923
