跳转到主内容
JBL Xtreme 3 Battery Replacement
Maria
Maria9 其他贡献者
最后更新于 July 26, 2023
20 - 40 分钟
中等
需要更好的图片
If the battery in your JBL Xtreme 3 (JBLXTREME3BLKAM) portable Bluetooth speaker is failing or has completely died, this guide will instruct you on replacing the battery.
Please review information about proper battery disposal.
Warning: Please take precautions if you suspect a swollen battery.
你所需要的
配件
工具
查看更多...
  1. JBL Xtreme 3 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Begin by placing the speaker with the grooves on the bottom of the device facing towards you.
    • Use a spudger to carefully pry around the seams of the speaker to open and unlatch the outer shell.
    • Use your hands to finish removing the outer case of the device.
  2. JBL Xtreme 3 Battery Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the two 10 mm screws.
  3. JBL Xtreme 3 Battery Replacement: 步骤 3 中的图像 1,2 JBL Xtreme 3 Battery Replacement: 步骤 3 中的图像 2,2
    • Use a spudger to carefully pry open the latch located above the control button as shown in the photo. Please be careful!!!
    • Remove the speaker from the shell.
    II have found today it is easier to pop the latches for the back half and then remove the two screws holding the front half.
    Then proceed to pry the front half off instead of prying near the control buttons at the hinge.
    Nicholaschristianson - 回复
  4. JBL Xtreme 3 Battery Replacement: 步骤 4 中的图像 1,2 JBL Xtreme 3 Battery Replacement: 步骤 4 中的图像 2,2
    • Turn the device so that the control buttons are facing down.
    • Use a Phillips #1 screwdriver to remove the eight 10 mm screws from the panel.
    • Carefully remove the panel.
  5. JBL Xtreme 3 Battery Replacement: 步骤 5 中的图像 1,2 JBL Xtreme 3 Battery Replacement: 步骤 5 中的图像 2,2
    • The battery is connected to a cable. Use gentle force.
    • Use the spudger to carefully pry the battery out.
  6. JBL Xtreme 3 Battery Replacement: 步骤 6 中的图像 1,3 JBL Xtreme 3 Battery Replacement: 步骤 6 中的图像 2,3 JBL Xtreme 3 Battery Replacement: 步骤 6 中的图像 3,3
    • Use the plastic opening tool to press the white notch while simultaneously unplugging the battery connector.
    • Plug in the replacement.
    • Make sure the new battery is secure. Turn on the device to ensure that the battery is connected properly.
结论
5等其他人完成本指南。
一条评论
Great guide! Thank you!
dam damo - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 49
过去 30 天: 171
总计 4,201
