简介
If the battery in your JBL Xtreme 3 (JBLXTREME3BLKAM) portable Bluetooth speaker is failing or has completely died, this guide will instruct you on replacing the battery.
Please review information about proper battery disposal.
Warning: Please take precautions if you suspect a swollen battery.
你所需要的
Begin by placing the speaker with the grooves on the bottom of the device facing towards you.
Use a spudger to carefully pry around the seams of the speaker to open and unlatch the outer shell.
Use your hands to finish removing the outer case of the device.
Use a spudger to carefully pry open the latch located above the control button as shown in the photo. Please be careful!!!
Remove the speaker from the shell.
II have found today it is easier to pop the latches for the back half and then remove the two screws holding the front half.
Then proceed to pry the front half off instead of prying near the control buttons at the hinge. -
5等其他人完成本指南。
