跳转到主内容
加入维修社区 - 创建账户
JBL Go 4 Battery Replacement
你所需要的
    1. JBL Go 4 Battery Replacement, Battery: 步骤 1 中的图像 1,3 JBL Go 4 Battery Replacement, Battery: 步骤 1 中的图像 2,3 JBL Go 4 Battery Replacement, Battery: 步骤 1 中的图像 3,3
      • Insert an opening tool into the seam in between the grille and chassis, in the top corner opposite the strap.
      • Slide the tool along the edge of the housing until the grille releases.
      • Remove the grille.
      • Be sure that the battery has been drained completely before attempting this replacement.
      询问修复机器人
      添加评论
    2. JBL Go 4 Battery Replacement: 步骤 2 中的图像 1,3 JBL Go 4 Battery Replacement: 步骤 2 中的图像 2,3 JBL Go 4 Battery Replacement: 步骤 2 中的图像 3,3
      • Insert an opening tool in the opposite corner, lifting carefully.
      • Slide the tool along the edge until the cover pops off.
      • Gently pull the housing up and to the side.
      • When the plate becomes loose, be incredibly gentle to avoid damaging the cable that connects the battery to the housing.
      添加评论
    3. JBL Go 4 Battery Replacement: 步骤 3 中的图像 1,2 JBL Go 4 Battery Replacement: 步骤 3 中的图像 2,2
      • Find the connection between the motherboard and the battery cable as labeled.
      • Gently depress the plastic tabs and slowly wiggle the connector until it comes free.
      • Be incredibly gentle with this connector as any excessive force can damage the motherboard.
      询问修复机器人
      添加评论
    4. JBL Go 4 Battery Replacement: 步骤 4 中的图像 1,2 JBL Go 4 Battery Replacement: 步骤 4 中的图像 2,2
      • Insert an opening tool beneath the battery, on the side opposite to the battery cable.
      • Using a lever motion, pry the battery out slowly, sliding it further under to break the adhesive up.
      • It's important to note that the battery is held on with a small adhesive pad, so more force than should feel necessary will be needed.
      询问修复机器人
      添加评论
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
取消:我没有完成这个指南。
Jackosn Caron
于03/20/25注册
255 声望
创作了2篇指南
团队
UMass Dartmouth, Team 4-1, Konn Spring 2025 UMass Dartmouth, Team 4-1, Konn Spring 2025 的会员
UMASSD-KONN-S25S4G1
4 名成员
创作了18篇指南
2指南评论
Great guide, thanks! Small point -
Typo - “Insert an opening into the seam”. I think you’re missing ‘tool’.
Alexander Dyas - 回复 分享
Thanks for pointing that out, @alexanderdyas. We took care of the typo. In the future, feel free to go ahead and make the edit!
Connor Bassolino - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 34
过去 30 天: 147
总计 1,588
