跳转到主内容
How to Replace a Valve Spring on a Trumpet
Isaac Trotta
Isaac Trotta3 其他贡献者
最后更新于 July 22, 2015
5分钟
简单
This guide will teach to how to replace a spring in the valve of the trumpet.
你所需要的
  1. How to Replace a Valve Spring on a Trumpet, valve spring: 步骤 1 中的图像 1,2 How to Replace a Valve Spring on a Trumpet, valve spring: 步骤 1 中的图像 2,2
    • To pull out the valve, first twist the top of the valve open counterclockwise to detach it from the rest of the valve.
    • Pull the valve out of the trumpet.
  2. How to Replace a Valve Spring on a Trumpet: 步骤 2 中的图像 1,2 How to Replace a Valve Spring on a Trumpet: 步骤 2 中的图像 2,2
    • Near the top of the valve, twist the top part of the screw compartment off to access the screw.
    • Pull the old spring out and replace with the new one.
    • Reassemble the valve the same way it came apart.
  3. How to Replace a Valve Spring on a Trumpet: 步骤 3 中的图像 1,2 How to Replace a Valve Spring on a Trumpet: 步骤 3 中的图像 2,2
    • Before inserting the valve back into the trumpet, put enough valve oil on the valve so that that the surface is wet, but not dripping.
    • Insert the valve into the trumpet, and screw in the top clockwise.
    • Be sure to grasp the top of the valve and twist until a clicking sound is heard and the valve locks in place to ensure that the trumpet is ready for playing.
    It won't fit in anymore
    Jerry - 回复
结论
另外一个人完成了本指南。
Isaac Trotta
于02/24/15注册
125 声望
撰写一个指南
团队
Cal Poly, Team 23-4, Green Winter 2015 Cal Poly, Team 23-4, Green Winter 2015 的会员
CPSU-GREEN-W15S23G4
7 名成员
创作了15篇指南
1指南评论
I cannot manage to take out my valve it is so hard It’s a brand new trumpet sound like come out and then I don’t have valve oil
Flavio - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 35
总计 8,601
