简介
Use this guide to replace a worn out or dead battery in a GuliKit KingKong 2 Pro controller.
For your safety, discharge the battery below 25% before disassembling your controller. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
You’ll need replacement adhesive when reassembling your device.
你所需要的
Use a Phillips #00 screwdriver to remove the four 11 mm-long screws securing the back cover.
Insert an opening pick into the gap between the front assembly and the back cover at the bottom edge of the controller.
Tilt your opening pick downwards to widen the gap.
Insert an opening pick into the gap between the front assembly and the back cover at the outside of the right controller handle.
Slide the opening pick along the gap to separate the front assembly from the back cover.
在这个步骤中使用的工具:Tweezers$4.99
Use the point of a spudger to disconnect the right vibration motor by pushing the connector straight out of its socket.
Use the point of a spudger to disconnect the left vibration motor by pushing the connector straight out of its socket.
Remove the vibration motors by lifting them out of the controller housing.
Use a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the interconnect cable's ZIF connector.
Use a pair of blunt nose tweezers to disconnect the interconnect cable by pulling the cable straight out of the connector.
Use a Phillips #00 screwdriver to remove the screws securing the mainboard assembly:
Four 7.8 mm-long screws.
Two 11 mm-long screws.
Use a pair of blunt nose tweezers to remove the metal shield from the mainboard assembly.
Remove the mainboard assembly by lifting it out of the controller housing.
Use a Phillips #00 screwdriver to remove the single 7.8 mm-long screw securing the battery frame.
Free the battery frame by lifting it off the plastic pins holding it in place.
Apply a heated iOpener to the back of the battery frame for two minutes to loosen the adhesive underneath the battery.
Insert an opening pick into the gap between the battery frame and the battery.
Slide the opening pick underneath the battery to cut the adhesive and pry it up.
Remove the battery.
For optimal performance, calibrate your newly installed battery after completing this guide.
另外一个人完成了本指南。
3条评论
What are the dimensions of the battery so we know which battery to order?
