跳转到主内容
Mainboard Assembly
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Mainboard Assembly, Unfasten the back cover screws: 步骤 1 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the four 11 mm-long screws securing the back cover.
  2. Mainboard Assembly, Insert an opening pick: 步骤 2 中的图像 1,2 Mainboard Assembly, Insert an opening pick: 步骤 2 中的图像 2,2
    • The back cover of the GuliKit Kingkong 2 Pro is held in place by plastic clips.
    • Insert an opening pick into the gap between the front assembly and the back cover at the bottom edge of the controller.
    • Tilt your opening pick downwards to widen the gap.
  3. Mainboard Assembly, Separate the front assembly and back cover: 步骤 3 中的图像 1,2 Mainboard Assembly, Separate the front assembly and back cover: 步骤 3 中的图像 2,2
    • Insert an opening pick into the gap between the front assembly and the back cover at the outside of the right controller handle.
    • Slide the opening pick along the gap to separate the front assembly from the back cover.
  4. Mainboard Assembly: 步骤 4 中的图像 1,2 Mainboard Assembly: 步骤 4 中的图像 2,2
    • Insert an opening pick into the gap between the front assembly and the back cover at the outside of the left controller handle.
  5. Mainboard Assembly, Remove the back cover: 步骤 5 中的图像 1,2 Mainboard Assembly, Remove the back cover: 步骤 5 中的图像 2,2
    • Separate the back cover from the front assembly and remove it.
  6. Mainboard Assembly, Disconnect the right vibration motor: 步骤 6 中的图像 1,3 Mainboard Assembly, Disconnect the right vibration motor: 步骤 6 中的图像 2,3 Mainboard Assembly, Disconnect the right vibration motor: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    • It's not mandatory to remove the two vibration motors to remove the mainboard assembly. However, other repairs become much easier with the motors removed. If you want to leave the motors in place, you can jump straight to step 9.
    • Pull on the connectors themselves and not the cables to avoid damaging them.
    • Use the point of a spudger to disconnect the right vibration motor by pushing the connector straight out of its socket.
    • If you can't disconnect the vibration motor with a spudger, use a pair of blunt nose tweezers to pull the connector out of its socket.
  7. Mainboard Assembly, Disconnect the left vibration motor: 步骤 7 中的图像 1,3 Mainboard Assembly, Disconnect the left vibration motor: 步骤 7 中的图像 2,3 Mainboard Assembly, Disconnect the left vibration motor: 步骤 7 中的图像 3,3
    • Use the point of a spudger to disconnect the left vibration motor by pushing the connector straight out of its socket.
  8. Mainboard Assembly, Remove the vibration motors: 步骤 8 中的图像 1,1
    • Remove the vibration motors by lifting them out of the controller housing.
  9. Mainboard Assembly, Release the interconnect cable ZIF connector: 步骤 9 中的图像 1,2 Mainboard Assembly, Release the interconnect cable ZIF connector: 步骤 9 中的图像 2,2
    • Use a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the interconnect cable's ZIF connector.
  10. Mainboard Assembly, Disconnect the interconnect cable: 步骤 10 中的图像 1,2 Mainboard Assembly, Disconnect the interconnect cable: 步骤 10 中的图像 2,2
    • Use a pair of blunt nose tweezers to disconnect the interconnect cable by pulling the cable straight out of the connector.
  11. Mainboard Assembly, Unfasten the mainboard assembly screws: 步骤 11 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the screws securing the mainboard assembly:
    • Four 7.8 mm-long screws.
    • Two 11 mm-long screws.
  12. Mainboard Assembly, Remove the mainboard shield: 步骤 12 中的图像 1,2 Mainboard Assembly, Remove the mainboard shield: 步骤 12 中的图像 2,2
    • Use a pair of blunt nose tweezers to remove the metal shield from the mainboard assembly.
  13. Mainboard Assembly, Remove the mainboard assembly: 步骤 13 中的图像 1,3 Mainboard Assembly, Remove the mainboard assembly: 步骤 13 中的图像 2,3 Mainboard Assembly, Remove the mainboard assembly: 步骤 13 中的图像 3,3
    • Remove the mainboard assembly by lifting it out of the controller housing.
结论
Dominik Schnabelrauch
于11/23/16注册
247,205 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,735篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 9
总计 342
