跳转到主内容
Google Pixel Tablet Rear Camera Replacement
你所需要的
  1. Google Pixel Tablet Rear Camera Replacement, Prepare your tablet for disassembly: 步骤 1 中的图像 1,2 Google Pixel Tablet Rear Camera Replacement, Prepare your tablet for disassembly: 步骤 1 中的图像 2,2
    • Allow your battery to fully drain before starting this repair. A charged battery may catch fire if damaged.
    • Unplug any cables from your tablet and fully power it down.
    • Hold the power and volume up buttons at the same time to bring up the power off menu.
  2. Google Pixel Tablet Rear Camera Replacement: 步骤 2 中的图像 1,1
    • If your screen is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
  3. Google Pixel Tablet Rear Camera Replacement, Secure the Anti-Clamp: 步骤 3 中的图像 1,3 Google Pixel Tablet Rear Camera Replacement, Secure the Anti-Clamp: 步骤 3 中的图像 2,3 Google Pixel Tablet Rear Camera Replacement, Secure the Anti-Clamp: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    Anti-Clamp
    $24.95
    购买
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backward to unlock the Anti-Clamp's arms.
    • Slide the arms over the top left corner, with one suction cup on the back cover and one on the screen.
    • Place an object under your tablet so it rests level between the Anti-Clamp's arms.
    • Squeeze the cups together to create suction.
  4. Google Pixel Tablet Rear Camera Replacement, Use the Anti-Clamp to create a gap: 步骤 4 中的图像 1,3 Google Pixel Tablet Rear Camera Replacement, Use the Anti-Clamp to create a gap: 步骤 4 中的图像 2,3 Google Pixel Tablet Rear Camera Replacement, Use the Anti-Clamp to create a gap: 步骤 4 中的图像 3,3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise two full turns, or until the suction cups begin to stretch.
    • As the cups stretch, make sure they stay vertically aligned with each other. If they keep slipping, remove the Anti-Clamp and apply tape for the cups to stick to.
  5. Google Pixel Tablet Rear Camera Replacement, Insert an opening pick: 步骤 5 中的图像 1,3 Google Pixel Tablet Rear Camera Replacement, Insert an opening pick: 步骤 5 中的图像 2,3 Google Pixel Tablet Rear Camera Replacement, Insert an opening pick: 步骤 5 中的图像 3,3
    • Use a hair dryer or heat gun to heat the top left corner of the screen until a gap forms between the glass and the frame.
    • Be careful not to overheat the tablet—the screen and battery are susceptible to heat damage.
    • Insert an opening pick into the gap.
    • Remove the Anti-Clamp using the pull tabs on the suction cups.
  6. Google Pixel Tablet Rear Camera Replacement, Heat the top left corner: 步骤 6 中的图像 1,1
    • If you've already inserted an opening pick using the Anti-Clamp, skip down two steps.
    • Rotate your tablet so the front camera is closest to you.
    • Apply a heated iOpener to the top left corner of the screen (now your bottom right, since the tablet is flipped around) for three minutes.
    • You can also use a hair dryer, heat gun, or hot plate, but be careful not to overheat the screen or battery—only heat the tablet so it's warm to the touch.
  7. Google Pixel Tablet Rear Camera Replacement, Insert an opening pick: 步骤 7 中的图像 1,3 Google Pixel Tablet Rear Camera Replacement, Insert an opening pick: 步骤 7 中的图像 2,3 Google Pixel Tablet Rear Camera Replacement, Insert an opening pick: 步骤 7 中的图像 3,3
    • Apply a suction handle to the top left corner of the screen, as close to the top edge as possible.
    • Pull up on the suction handle with a strong, steady force until a gap forms between the glass and the frame.
    • Insert the tip of an opening pick into the gap.
    • Remove the suction handle.
  8. Google Pixel Tablet Rear Camera Replacement, Adhesive information: 步骤 8 中的图像 1,3 Google Pixel Tablet Rear Camera Replacement, Adhesive information: 步骤 8 中的图像 2,3 Google Pixel Tablet Rear Camera Replacement, Adhesive information: 步骤 8 中的图像 3,3
    • The screen is secured with adhesive all around the perimeter. Note the following areas as you separate the adhesive:
    • The top, bottom, and left edges have the thickest adhesive.
    • The right edge has slightly thinner adhesive.
    • At the top, near the front camera, the adhesive is very thin and delicate cables connect the screen to the frame.
  9. Google Pixel Tablet Rear Camera Replacement, Reposition your opening pick: 步骤 9 中的图像 1,2 Google Pixel Tablet Rear Camera Replacement, Reposition your opening pick: 步骤 9 中的图像 2,2
    • Don't insert your pick deeper than 7 mm, or about halfway between the tip of the pick and the iFixit logo.
    • Slide your opening pick to the top left corner of the tablet.
    • Leave this pick inserted to prevent the adhesive from resealing.
  10. Google Pixel Tablet Rear Camera Replacement, Heat the left edge: 步骤 10 中的图像 1,1
    • Apply a heated iOpener to the left edge of the screen for two minutes.
    • You can also use a hair dryer, heat gun, or hot plate, but be careful not to overheat the screen or battery.
  11. Google Pixel Tablet Rear Camera Replacement, Separate the left edge adhesive: 步骤 11 中的图像 1,2 Google Pixel Tablet Rear Camera Replacement, Separate the left edge adhesive: 步骤 11 中的图像 2,2
    • Insert a second opening pick in the top left corner of the screen.
    • Slide your pick to the bottom left corner of the screen to separate the left edge adhesive.
  12. Google Pixel Tablet Rear Camera Replacement, Heat the bottom edge: 步骤 12 中的图像 1,1
    • Apply a heated iOpener to the bottom edge of the screen for two minutes.
  13. Google Pixel Tablet Rear Camera Replacement, Separate the bottom edge adhesive: 步骤 13 中的图像 1,3 Google Pixel Tablet Rear Camera Replacement, Separate the bottom edge adhesive: 步骤 13 中的图像 2,3 Google Pixel Tablet Rear Camera Replacement, Separate the bottom edge adhesive: 步骤 13 中的图像 3,3
    • Insert a third opening pick in the bottom left corner.
    • Slide your pick to the bottom right corner of the screen to separate the bottom edge adhesive.
    • If your pick becomes stuck, repeatedly twist it as you slide to help separate the adhesive.
  14. Google Pixel Tablet Rear Camera Replacement, Heat the right edge: 步骤 14 中的图像 1,1
    • Apply a heated iOpener to the right edge of the screen for two minutes.
  15. Google Pixel Tablet Rear Camera Replacement, Separate the right edge adhesive: 步骤 15 中的图像 1,2 Google Pixel Tablet Rear Camera Replacement, Separate the right edge adhesive: 步骤 15 中的图像 2,2
    • Don't insert your pick deeper than 5 mm along the right edge.
    • For a visual reference, you can measure 5 mm from the tip and mark your pick with a permanent marker.
    • Insert a fourth opening pick in the bottom right corner.
    • Slide your pick to the top right corner to separate the right edge adhesive.
  16. Google Pixel Tablet Rear Camera Replacement, Heat the top edge: 步骤 16 中的图像 1,1
    • Apply a heated iOpener to the top edge of the screen for two minutes.
  17. Google Pixel Tablet Rear Camera Replacement, Top edge information: 步骤 17 中的图像 1,1
    • The front camera and sensor are along the middle of the top edge. Be very careful not to insert your opening pick deeper than 3 mm (1/8 in) here.
    • For a visual reference, you can measure 3 mm from the tip and mark your pick with a permanent marker.
    • To mark where to avoid slicing too deep, it can be helpful to put a 6.3 cm (2.5 in) long strip of masking tape on the top edge, centered over the front camera.
  18. Google Pixel Tablet Rear Camera Replacement, Separate the top edge adhesive: 步骤 18 中的图像 1,3 Google Pixel Tablet Rear Camera Replacement, Separate the top edge adhesive: 步骤 18 中的图像 2,3 Google Pixel Tablet Rear Camera Replacement, Separate the top edge adhesive: 步骤 18 中的图像 3,3
    • Insert a fifth opening pick in the top right corner of the screen.
    • Slide your pick toward the front camera. Stop when your pick is 3 cm (1.25 in) from the front camera.
    • Pull your pick out to a depth of 3 mm (1/8 inch) and slide it past the front camera.
    • When your pick is 3 cm past the front camera, insert it up to 6 mm deep, or about halfway between the tip and the iFixit logo, and slide it to the first pick you left in the top left corner.
  19. Google Pixel Tablet Rear Camera Replacement, Tilt the screen open: 步骤 19 中的图像 1,3 Google Pixel Tablet Rear Camera Replacement, Tilt the screen open: 步骤 19 中的图像 2,3 Google Pixel Tablet Rear Camera Replacement, Tilt the screen open: 步骤 19 中的图像 3,3
    • Don't tilt the screen open beyond 90 degrees. The front camera and sensor cables are very short and may tear.
    • Grab and lift the bottom corners of the screen.
    • If the screen feels stuck, check around the perimeter for any missed sections of adhesive and slice them with an opening pick.
    • Tilt the screen open just enough to access the cables connecting the screen to the frame.
    • During reassembly, remove the adhesive liners from the perimeter of the screen before firmly pressing it into place in the frame.
  20. Google Pixel Tablet Rear Camera Replacement, Remove the screen cable tape: 步骤 20 中的图像 1,3 Google Pixel Tablet Rear Camera Replacement, Remove the screen cable tape: 步骤 20 中的图像 2,3 Google Pixel Tablet Rear Camera Replacement, Remove the screen cable tape: 步骤 20 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • For the next three steps, hold the screen tilted open with one hand while you work with your other hand.
    • If you have difficulty holding up the screen, place the tablet's dock on the frame to prop up the screen or ask someone to hold it up while you work.
    • Use tweezers to peel and remove the black tape off of the screen cable connector.
    • During reassembly:
    • Install new tape if the old piece is damaged and you have a replacement from your repair kit.
    • Now is a good time to test your tablet before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
  21. Google Pixel Tablet Rear Camera Replacement, Disconnect the screen: 步骤 21 中的图像 1,3 Google Pixel Tablet Rear Camera Replacement, Disconnect the screen: 步骤 21 中的图像 2,3 Google Pixel Tablet Rear Camera Replacement, Disconnect the screen: 步骤 21 中的图像 3,3
    • Use the point of a spudger or a clean fingernail to flip up the small locking flap on the inside edge (same side as the cable) of the screen cable ZIF connector.
    • Use tweezers or your fingers to pull the screen cable straight out of its socket.
  22. Google Pixel Tablet Rear Camera Replacement, Disconnect the front camera: 步骤 22 中的图像 1,3 Google Pixel Tablet Rear Camera Replacement, Disconnect the front camera: 步骤 22 中的图像 2,3 Google Pixel Tablet Rear Camera Replacement, Disconnect the front camera: 步骤 22 中的图像 3,3
    • Use an opening pick to flip up the small locking flap on the outside edge (opposite the cable) of the front camera ZIF connector.
    • Use tweezers to pull the cable straight out of its socket.
    • During reassembly, be careful not to tear this cable, since it doesn't have much room to bend. Guide the connector into its socket with tweezers and lock the ZIF connector flap at the same time.
  23. Google Pixel Tablet Rear Camera Replacement, Disconnect the front sensor: 步骤 23 中的图像 1,3 Google Pixel Tablet Rear Camera Replacement, Disconnect the front sensor: 步骤 23 中的图像 2,3 Google Pixel Tablet Rear Camera Replacement, Disconnect the front sensor: 步骤 23 中的图像 3,3
    • Use the point of your spudger or a clean fingernail to flip up the small locking flap on the inside edge of the front sensor connector.
  24. Google Pixel Tablet Rear Camera Replacement, Remove the screen: 步骤 24 中的图像 1,1
    • Remove the screen.
  25. Google Pixel Tablet Rear Camera Replacement, Prepare your frame for reassembly: 步骤 25 中的图像 1,3 Google Pixel Tablet Rear Camera Replacement, Prepare your frame for reassembly: 步骤 25 中的图像 2,3 Google Pixel Tablet Rear Camera Replacement, Prepare your frame for reassembly: 步骤 25 中的图像 3,3
    • Follow the next two steps to clean your frame and prepare it for reassembly.
    • Use the flat end of your spudger or a clean fingernail to scrape up an edge of the leftover frame adhesive until you can grip it.
    • Use tweezers or your fingers to peel off large pieces of adhesive from the frame.
    • Repeat this process around the entire perimeter of the frame until there are no large pieces are left.
    • If you're reusing your screen, remove the old adhesive from it as well as the frame.
  26. Google Pixel Tablet Rear Camera Replacement: 步骤 26 中的图像 1,3 Google Pixel Tablet Rear Camera Replacement: 步骤 26 中的图像 2,3 Google Pixel Tablet Rear Camera Replacement: 步骤 26 中的图像 3,3
    在这个步骤中使用的工具:
    Microfiber Cleaning Cloths
    $3.99
    购买
    • Fill a pipette or syringe with highly-concentrated isopropyl alcohol (over 90%) and apply a few drops to the edge of the frame.
    • Wrap a microfiber or lint free cloth around the flat end of your spudger and scrub the frame until it's clean. Use more isopropyl alcohol as you go.
    • If you're reusing your screen, clean its perimeter as well as the frame.
  27. Google Pixel Tablet Rear Camera Replacement, Remove the cable cover: 步骤 27 中的图像 1,3 Google Pixel Tablet Rear Camera Replacement, Remove the cable cover: 步骤 27 中的图像 2,3 Google Pixel Tablet Rear Camera Replacement, Remove the cable cover: 步骤 27 中的图像 3,3
    • While the Pixel Tablet uses Torx Plus screws, standard Torx bits work in a pinch. Make sure to apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP driver to remove the two 2.6 mm screws securing the battery, USB-C, and speakers connectors cover.
    • If you're using standard Torx bits, a T3 Torx will work best for these screws. If it feels too loose, you may need a T4 Torx bit.
    • Remove the cover.
  28. Google Pixel Tablet Rear Camera Replacement, Disconnect the battery: 步骤 28 中的图像 1,2 Google Pixel Tablet Rear Camera Replacement, Disconnect the battery: 步骤 28 中的图像 2,2
    • Use the flat end of your spudger to pry up and disconnect the battery press connector.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side.
  29. Google Pixel Tablet Rear Camera Replacement, Reassembly information: 步骤 29 中的图像 1,3 Google Pixel Tablet Rear Camera Replacement, Reassembly information: 步骤 29 中的图像 2,3 Google Pixel Tablet Rear Camera Replacement, Reassembly information: 步骤 29 中的图像 3,3
    • Connecting the screen cable with the battery connected risks shorting the connector and poses a fire hazard.
    • Follow this step during reassembly to safely reconnect the screen and battery.
    • Prop up the bottom edge of the tablet on a box or similar object. Tilt the screen open and lean it against something so that it's angled up to 90 degrees.
    • Reconnect the small front sensor cable ZIF connector.
    • Reconnect the large screen cable ZIF connector.
    • Reconnect the battery press connector.
    • Use your Torx Plus 3IP driver to install the two 2.6 mm screws and fasten the connector cover.
    • Continue reassembly with these cables connected.
  30. Google Pixel Tablet Rear Camera Replacement, Disconnect the rear camera: 步骤 30 中的图像 1,3 Google Pixel Tablet Rear Camera Replacement, Disconnect the rear camera: 步骤 30 中的图像 2,3 Google Pixel Tablet Rear Camera Replacement, Disconnect the rear camera: 步骤 30 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use the point of your spudger or a clean fingernail to flip up the small locking flap on the outside edge of the rear camera ZIF connector.
    • Use blunt nose tweezers to pull the cable straight out of its socket.
  31. Google Pixel Tablet Rear Camera Replacement, Unfasten the rear camera bracket: 步骤 31 中的图像 1,1
    • Use your Torx Plus 3IP driver to remove the two 2.2 mm screws securing the rear camera bracket.
  32. Google Pixel Tablet Rear Camera Replacement, Remove the rear camera: 步骤 32 中的图像 1,2 Google Pixel Tablet Rear Camera Replacement, Remove the rear camera: 步骤 32 中的图像 2,2
    • Remove the rear camera.
  33. Google Pixel Tablet Rear Camera Replacement, Remove the rear camera bracket: 步骤 33 中的图像 1,3 Google Pixel Tablet Rear Camera Replacement, Remove the rear camera bracket: 步骤 33 中的图像 2,3 Google Pixel Tablet Rear Camera Replacement, Remove the rear camera bracket: 步骤 33 中的图像 3,3
    • Peel the rear camera bracket from the rear camera.
    • During reassembly, place this bracket over the rear camera before laying the camera in its recess in the frame.
结论
Clay Eickemeyer
于09/19/22注册
67,507 声望
创作了453篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,449篇指南
一条评论
Having more Android tablets in the house and staying within the Google ecosystem would be seamless if they standardized Android tablet connectivity to the dock, which is something I don't think will happen. The coolest thing would be to finally just grab any Android tablet and place it on your dock.
Idlecrown - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 13
总计 243
