跳转到主内容
加入维修社区 - 创建账户
Google Pixel 9 Pro Screen Replacement
你所需要的
  1. Google Pixel 9 Pro Screen Replacement, Safety precautions: 步骤 1 中的图像 1,2 Google Pixel 9 Pro Screen Replacement, Safety precautions: 步骤 1 中的图像 2,2
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables and completely power down your phone.
  2. Google Pixel 9 Pro Screen Replacement, Tape over any cracks: 步骤 2 中的图像 1,2 Google Pixel 9 Pro Screen Replacement, Tape over any cracks: 步骤 2 中的图像 2,2
    • Glass shards can complicate disassembly—or worse, cause injury. If your phone has a cracked screen, follow these steps:
    • Apply overlapping strips of packing tape to the cracked glass until the whole screen is covered—this will allow the suction cup to stick to the screen.
    • Only cover the glass itself—don't stick any tape to the frame.
    • Consider wearing safety glasses to protect your eyes from any glass shaken free during the repair.
  3. Google Pixel 9 Pro Screen Replacement: 步骤 3 中的图像 1,3 Google Pixel 9 Pro Screen Replacement: 步骤 3 中的图像 2,3 Google Pixel 9 Pro Screen Replacement: 步骤 3 中的图像 3,3
    • Adhesive secures the screen to the frame. Heating the screen softens the adhesive, making it easier to separate.
    • Use a hair dryer, heat gun, or hot plate to heat the entire screen until it's almost too hot to touch.
    • Be careful not to overheat the phone—the battery and plastic components are susceptible to heat damage. Stop heating if the frame becomes too hot to touch.
  4. Google Pixel 9 Pro Screen Replacement, Apply a suction handle: 步骤 4 中的图像 1,2 Google Pixel 9 Pro Screen Replacement, Apply a suction handle: 步骤 4 中的图像 2,2
    • Apply a suction handle to the center of the screen's top edge.
  5. Google Pixel 9 Pro Screen Replacement, Screen information: 步骤 5 中的图像 1,3 Google Pixel 9 Pro Screen Replacement, Screen information: 步骤 5 中的图像 2,3 Google Pixel 9 Pro Screen Replacement, Screen information: 步骤 5 中的图像 3,3
    • There are delicate metal spring‑contacts around the perimeter of your device. To prevent damaging them when separating the screen, don't insert your pick more than 3 mm deep.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  6. Google Pixel 9 Pro Screen Replacement, Insert an opening pick: 步骤 6 中的图像 1,3 Google Pixel 9 Pro Screen Replacement, Insert an opening pick: 步骤 6 中的图像 2,3 Google Pixel 9 Pro Screen Replacement, Insert an opening pick: 步骤 6 中的图像 3,3
    • Inserting an opening pick is difficult. Be patient and reheat the screen at any point if it feels stuck.
    • Pull up on the suction handle with strong, steady force to create a gap between the screen and frame.
    • Insert the tip of an opening pick under the screen.
    • A plastic frame is attached to the backside of the display. When inserting your pick, make sure it's underneath this frame, and not between the frame and the display glass.
  7. Google Pixel 9 Pro Screen Replacement, Separate the screen adhesive: 步骤 7 中的图像 1,3 Google Pixel 9 Pro Screen Replacement, Separate the screen adhesive: 步骤 7 中的图像 2,3 Google Pixel 9 Pro Screen Replacement, Separate the screen adhesive: 步骤 7 中的图像 3,3
    • Slide the opening pick along the top edge to separate the adhesive securing it.
  8. Google Pixel 9 Pro Screen Replacement: 步骤 8 中的图像 1,3 Google Pixel 9 Pro Screen Replacement: 步骤 8 中的图像 2,3 Google Pixel 9 Pro Screen Replacement: 步骤 8 中的图像 3,3
    • Continue sliding your opening pick around the perimeter of the screen to separate the remaining adhesive.
  9. Google Pixel 9 Pro Screen Replacement, Prop up the screen: 步骤 9 中的图像 1,3 Google Pixel 9 Pro Screen Replacement, Prop up the screen: 步骤 9 中的图像 2,3 Google Pixel 9 Pro Screen Replacement, Prop up the screen: 步骤 9 中的图像 3,3
    • Flip the screen over the right edge of your phone and prop it up with the suction handle.
    • Be careful not to strain the display cable, located near the bottom right corner.
    • If the screen feels stuck, go back around the perimeter with an opening pick to separate any remaining adhesive.
  10. Google Pixel 9 Pro Screen Replacement, Disconnect the screen: 步骤 10 中的图像 1,3 Google Pixel 9 Pro Screen Replacement, Disconnect the screen: 步骤 10 中的图像 2,3 Google Pixel 9 Pro Screen Replacement, Disconnect the screen: 步骤 10 中的图像 3,3
    • Use angled tweezers to pry up the top edge of the screen cable bracket.
    • Remove the bracket.
  11. Google Pixel 9 Pro Screen Replacement: 步骤 11 中的图像 1,3 Google Pixel 9 Pro Screen Replacement: 步骤 11 中的图像 2,3 Google Pixel 9 Pro Screen Replacement: 步骤 11 中的图像 3,3
    • Be very careful not to damage any of the small, surface‑mounted components around the screen's press connector.
    • Insert the point of a spudger under the left edge of the screen cable press connector and pry up to disconnect it.
    • Remove the screen.
  12. Google Pixel 9 Pro Screen Replacement, Screen information: 步骤 12 中的图像 1,1
    • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
    • To prevent damaging your screen or replacement screen:
    • When handling your screen, grip it by its edges.
    • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
  13. Google Pixel 9 Pro Screen Replacement, Remove all the old screen adhesive: 步骤 13 中的图像 1,3 Google Pixel 9 Pro Screen Replacement, Remove all the old screen adhesive: 步骤 13 中的图像 2,3 Google Pixel 9 Pro Screen Replacement, Remove all the old screen adhesive: 步骤 13 中的图像 3,3
    • When removing the screen adhesive during this step, be very careful not to damage any of the fragile components near the perimeter of the frame.
    • Use a spudger to scrape up and remove all the old screen adhesive from the perimeter of the frame.
    • This will take some time as the adhesive can be tricky to remove. Work slowly and try to roll the adhesive onto itself.
    • Once you've removed all the old adhesive, use isopropyl alcohol and a microfiber cloth to clean up the adhesive residue from the perimeter of the frame.
    • In order for the new adhesive to form a good bond, the frame needs to be completely clean of all adhesive and its residue.
    • Allow the frame to dry completely before continuing.
  14. Google Pixel 9 Pro Screen Replacement, Orient the adhesive: 步骤 14 中的图像 1,3 Google Pixel 9 Pro Screen Replacement, Orient the adhesive: 步骤 14 中的图像 2,3 Google Pixel 9 Pro Screen Replacement, Orient the adhesive: 步骤 14 中的图像 3,3
    • If your replacement screen has adhesive pre‑installed, skip down seven steps. Otherwise, follow the next seven steps to install new screen adhesive.
    • Before applying the adhesive, make sure you know its proper orientation on the frame. Hold the adhesive over your phone to find its proper alignment.
    • The blue liner should be facing up, with the larger clear liner on the bottom.
    • The adhesive has a corresponding groove on the perimeter of the frame.
    • Cutouts in the blue liner correspond to spring contacts on the frame.
  15. Google Pixel 9 Pro Screen Replacement, Apply the screen adhesive: 步骤 15 中的图像 1,1
    • Peel down the top half of the larger, clear liner to expose the adhesive—don't remove the whole liner yet.
  16. Google Pixel 9 Pro Screen Replacement: 步骤 16 中的图像 1,2 Google Pixel 9 Pro Screen Replacement: 步骤 16 中的图像 2,2
    • Take your time aligning the adhesive with the frame—it's very sticky and can't be moved after you apply it.
    • Keep the larger, clear liner folded towards the bottom of the phone during this step.
    • Lay the exposed top edge of the adhesive onto the frame, using the frame's lip to help align it.
    • Once the top edge is properly aligned, gently press down with your fingers to secure it in place.
  17. Google Pixel 9 Pro Screen Replacement: 步骤 17 中的图像 1,3 Google Pixel 9 Pro Screen Replacement: 步骤 17 中的图像 2,3 Google Pixel 9 Pro Screen Replacement: 步骤 17 中的图像 3,3
    • Slowly lay the rest of the adhesive onto the frame, peeling away the larger clear liner as you go.
  18. Google Pixel 9 Pro Screen Replacement, Secure the screen adhesive: 步骤 18 中的图像 1,3 Google Pixel 9 Pro Screen Replacement, Secure the screen adhesive: 步骤 18 中的图像 2,3 Google Pixel 9 Pro Screen Replacement, Secure the screen adhesive: 步骤 18 中的图像 3,3
    • Use the flat end of a spudger to firmly press around the perimeter of the adhesive to secure it to the frame.
  19. Google Pixel 9 Pro Screen Replacement: 步骤 19 中的图像 1,3 Google Pixel 9 Pro Screen Replacement: 步骤 19 中的图像 2,3 Google Pixel 9 Pro Screen Replacement: 步骤 19 中的图像 3,3
    • Use tweezers to grip the top right corner of the blue liner and remove it.
    • If any of the adhesive starts to peel up with the liner, gently lay it back on the frame and use the flat end of a spudger to secure it.
  20. Google Pixel 9 Pro Screen Replacement: 步骤 20 中的图像 1,3 Google Pixel 9 Pro Screen Replacement: 步骤 20 中的图像 2,3 Google Pixel 9 Pro Screen Replacement: 步骤 20 中的图像 3,3
  21. Google Pixel 9 Pro Screen Replacement, Connect the replacement screen: 步骤 21 中的图像 1,1
    • Carefully lay your replacement screen display‑side‑down just to the right of your phone so you can reconnect the cable.
  22. Google Pixel 9 Pro Screen Replacement: 步骤 22 中的图像 1,2 Google Pixel 9 Pro Screen Replacement: 步骤 22 中的图像 2,2
    • Be very careful not to strain the screen cable during this step. You may need to hold the screen up at an angle to help position the cable.
    • Align the screen press connector over its socket and gently press down on one side until it clicks into place, then press down on the other side.
    • Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    • Hook the bottom edge of the screen cable bracket into its cutout and firmly press down on the top edge until the bracket clicks into place.
  23. Google Pixel 9 Pro Screen Replacement: 步骤 23 中的图像 1,3 Google Pixel 9 Pro Screen Replacement: 步骤 23 中的图像 2,3 Google Pixel 9 Pro Screen Replacement: 步骤 23 中的图像 3,3
    • Follow this step only if your screen has adhesive pre‑installed on the underside.
    • Use tweezers or your fingers to remove the two remaining blue liners from the underside of the screen.
    • Skip the next step.
  24. Google Pixel 9 Pro Screen Replacement: 步骤 24 中的图像 1,3 Google Pixel 9 Pro Screen Replacement: 步骤 24 中的图像 2,3 Google Pixel 9 Pro Screen Replacement: 步骤 24 中的图像 3,3
    • Follow this step if you applied screen adhesive directly to the frame.
    • Use tweezers or your fingers to remove the two remaining liners from the frame. You'll need to carefully hold the screen up to remove the right liner.
  25. Google Pixel 9 Pro Screen Replacement: 步骤 25 中的图像 1,1
    • Thoroughly check your replacement screen for any remaining plastic liners (specifically near the front facing camera and screen cable) and use your fingers to remove them—you can identify the liners by their plastic pull tabs.
    • Be very careful not to damage the screen when removing the liners.
  26. Google Pixel 9 Pro Screen Replacement, Secure the screen with its adhesive: 步骤 26 中的图像 1,2 Google Pixel 9 Pro Screen Replacement, Secure the screen with its adhesive: 步骤 26 中的图像 2,2
    • Carefully flip the screen onto the frame.
  27. Google Pixel 9 Pro Screen Replacement: 步骤 27 中的图像 1,3 Google Pixel 9 Pro Screen Replacement: 步骤 27 中的图像 2,3 Google Pixel 9 Pro Screen Replacement: 步骤 27 中的图像 3,3
    • Firmly press around the perimeter of the screen to secure it to the frame.
    • When powering on your Pixel for the first time after your repair, make sure the phone is laying flat and nothing is touching the screen (fingers, plastic liners, screen protectors, cases).
结论
Congratulations on completing your screen repair!
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
To calibrate the display’s fingerprint reader, use Google’s Pixel Update and Software Repair tool.
7等其他人完成本指南。
Spencer Day
于09/14/22注册
156,764 声望
创作了1,033篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,877篇指南
7指南评论
ifixit's instructions that show a suction cup to remove a screen or a glass back always assume your glass is intact. I would assume most often it is shattered so forget using a suction cup. I used some thick shipping tape to cover the broken glass which gives the suction cup a chance to hold.
Scott Z - 回复
Isnt that why Step 2 is there?.....
Andrew Eyring - 回复
Is the screw in the top left corner supposed to stick out? Pulled a screen and the screw in the top left corner sticks out a little.
Travis Brubaker - 回复
Took multiple apart and all were that way so apparently that's how there built. Looks like it's close to hitting the display though.
Travis Brubaker -
Also Googles Pixel Update and Sowftware Repair Tool says "Couldn't find the unique calibration software for this device" when I try to calibrate the fingerprint reader.
添加评论
浏览统计数据:
过去 24 小时: 46
过去 7 天: 272
过去 30 天: 1,061
总计 13,920
