跳转到主内容
加入维修社区 - 创建账户
Google Pixel 7a Screen Replacement
你所需要的
  1. Google Pixel 7a Screen Replacement, Prepare your phone for disassembly: 步骤 1 中的图像 1,2 Google Pixel 7a Screen Replacement, Prepare your phone for disassembly: 步骤 1 中的图像 2,2
    • Allow your battery to drain below 25% before starting this repair. A charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone and fully power it down.
  2. Google Pixel 7a Screen Replacement, Protect your screen: 步骤 2 中的图像 1,2 Google Pixel 7a Screen Replacement, Protect your screen: 步骤 2 中的图像 2,2
    • Glass shards can complicate disassembly—or worse, cause injury. If your phone has a cracked screen, follow these steps:
    • Apply overlapping strips of packing tape to the cracked glass until the whole screen is covered.
    • Only cover the glass itself—don't stick any tape to the frame.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    询问修复机器人
  3. Google Pixel 7a Screen Replacement, Soften the top edge adhesive: 步骤 3 中的图像 1,1
    • The screen is strongly adhered to the frame, has no clips, and resists flexing. It requires significant heat to soften the adhesive underneath.
    • Use a hair dryer, heat gun, or hot plate to heat the top edge of the screen until it's almost too hot to touch.
    • Be careful not to overheat the phone—the battery and plastic components are susceptible to heat damage. Stop heating if the frame becomes too hot to touch.
    询问修复机器人
  4. Google Pixel 7a Screen Replacement, Insert an opening pick: 步骤 4 中的图像 1,3 Google Pixel 7a Screen Replacement, Insert an opening pick: 步骤 4 中的图像 2,3 Google Pixel 7a Screen Replacement, Insert an opening pick: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    Jimmy
    $7.95
    • Inserting an opening pick is very difficult. Be patient and reheat the screen at any point if it feels stuck.
    • Apply a suction handle to the center of the top edge of the screen.
    • If you can't apply a suction handle to a broken or uneven screen, try folding a strong piece of tape into a handle.
    • Don't insert your pick deeper than 2 mm, as you risk damaging the front-facing camera.
    • Pull up on the suction handle with a strong, steady force.
    • Insert the tip of an opening pick into the left side of the earpiece speaker cutout.
    • Firmly press the pick into the cutout and lower it flat to the screen until it slides under the glass.
    • If your pick is too thick to slide under the glass, try a thinner object like the flat edge of a Jimmy.
  5. Google Pixel 7a Screen Replacement, Separate the top edge adhesive: 步骤 5 中的图像 1,3 Google Pixel 7a Screen Replacement, Separate the top edge adhesive: 步骤 5 中的图像 2,3 Google Pixel 7a Screen Replacement, Separate the top edge adhesive: 步骤 5 中的图像 3,3
    • Don't insert your pick deeper than 2 mm, as you might damage the front-facing camera.
    • Slide your pick back and forth across the top edge of the screen to separate the adhesive.
    询问修复机器人
  6. Google Pixel 7a Screen Replacement, Separate the right edge adhesive: 步骤 6 中的图像 1,2 Google Pixel 7a Screen Replacement, Separate the right edge adhesive: 步骤 6 中的图像 2,2
    • Don't insert your pick deeper than 3 mm, as you might damage the spacers along the right edge of the frame.
    • For a visual reference, you can measure 3 mm from the tip and mark your pick with a permanent marker.
    • Slide your pick down the right edge to separate the adhesive.
    询问修复机器人
  7. Google Pixel 7a Screen Replacement, Separate the bottom adhesive: 步骤 7 中的图像 1,2 Google Pixel 7a Screen Replacement, Separate the bottom adhesive: 步骤 7 中的图像 2,2
    • If you plan on reusing any components on your screen, don't insert your pick deeper than 3 mm, as you might damage the LCD panel or connectors.
    • Slide your pick to the bottom left corner to separate the bottom edge adhesive.
    询问修复机器人
  8. Google Pixel 7a Screen Replacement, Separate the left edge adhesive: 步骤 8 中的图像 1,2 Google Pixel 7a Screen Replacement, Separate the left edge adhesive: 步骤 8 中的图像 2,2
    • If you plan on reusing any components from your screen, don't insert your pick deeper than 3 mm, as you might damage the connectors.
    • Slide your pick to the top left corner to separate the left edge adhesive.
    询问修复机器人
  9. Google Pixel 7a Screen Replacement, Swing open the screen: 步骤 9 中的图像 1,3 Google Pixel 7a Screen Replacement, Swing open the screen: 步骤 9 中的图像 2,3 Google Pixel 7a Screen Replacement, Swing open the screen: 步骤 9 中的图像 3,3
    • Swing the right edge of the screen open, like turning the page of a book.
    • Be careful not to strain the screen cable.
    • Lay the screen over the left edge of the frame.
    • If the front sensor gasket sticks to the screen, place it back onto the sensor in the recess of the frame. Orient the gasket so that the smaller cutout is closest to the front-facing camera.
  10. Google Pixel 7a Screen Replacement, Move the graphite film: 步骤 10 中的图像 1,2 Google Pixel 7a Screen Replacement, Move the graphite film: 步骤 10 中的图像 2,2
    • Move the flap of graphite film away from the screen connector.
    询问修复机器人
  11. Google Pixel 7a Screen Replacement, Remove the screen connector cover: 步骤 11 中的图像 1,3 Google Pixel 7a Screen Replacement, Remove the screen connector cover: 步骤 11 中的图像 2,3 Google Pixel 7a Screen Replacement, Remove the screen connector cover: 步骤 11 中的图像 3,3
    • Use your 3IP Torx Plus driver to remove the single 2 mm screw securing the screen connector cover.
    • While the Pixel 7a uses Torx Plus screws, standard Torx drivers still work. You may use a T3 Torx driver to remove this screw. Make sure to apply constant, downward force to prevent stripping.
    • Remove the cover.
  12. Google Pixel 7a Screen Replacement, Disconnect the screen: 步骤 12 中的图像 1,2 Google Pixel 7a Screen Replacement, Disconnect the screen: 步骤 12 中的图像 2,2
    • Use the point of your spudger or a fingernail to pry up and disconnect the screen press connector.
    • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It might take a few tries to align the connector.
    询问修复机器人
  13. Google Pixel 7a Screen Replacement, Remove the screen: 步骤 13 中的图像 1,2 Google Pixel 7a Screen Replacement, Remove the screen: 步骤 13 中的图像 2,2
    • Remove the screen.
    • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
    • To prevent damaging your screen or replacement screen:
    • When handling your screen, grip it by its edges.
    • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
  14. Google Pixel 7a Screen Replacement, Prepare your frame for reassembly: 步骤 14 中的图像 1,2 Google Pixel 7a Screen Replacement, Prepare your frame for reassembly: 步骤 14 中的图像 2,2
    在这个步骤中使用的工具:
    • The underside of the battery is exposed through a small cutout in the frame—be careful not to damage it with your tool.
    • Use blunt nose tweezers or your fingers to peel and remove the square piece of adhesive near the battery cutout.
  15. Google Pixel 7a Screen Replacement: 步骤 15 中的图像 1,3 Google Pixel 7a Screen Replacement: 步骤 15 中的图像 2,3 Google Pixel 7a Screen Replacement: 步骤 15 中的图像 3,3
    • If you're reusing your original screen, peel and remove the old adhesive from the perimeter of the screen.
    询问修复机器人
  16. Google Pixel 7a Screen Replacement: 步骤 16 中的图像 1,3 Google Pixel 7a Screen Replacement: 步骤 16 中的图像 2,3 Google Pixel 7a Screen Replacement: 步骤 16 中的图像 3,3
    在这个步骤中使用的工具:
    Microfiber Cleaning Cloths
    $3.99
    • Use a pipette or syringe to apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to the perimeter of the frame.
    • Wipe the residue away using a lint-free or microfiber cloth.
    • If you're reusing your screen, repeat this step along its perimeter, as well.
    询问修复机器人
  17. Google Pixel 7a Screen Replacement, Apply new adhesive: 步骤 17 中的图像 1,3 Google Pixel 7a Screen Replacement, Apply new adhesive: 步骤 17 中的图像 2,3 Google Pixel 7a Screen Replacement, Apply new adhesive: 步骤 17 中的图像 3,3
    • Peel the square piece of screen adhesive from its large liner.
    • Apply the adhesive to the frame in the same location as the old adhesive, just below the battery cutout.
  18. Google Pixel 7a Screen Replacement: 步骤 18 中的图像 1,2 Google Pixel 7a Screen Replacement: 步骤 18 中的图像 2,2
    • If your screen already comes with adhesive pre-installed, remove its liner and skip down five steps to continue reassembly.
    • Before removing any liners from the screen adhesive, hold it over the frame to make sure it's oriented correctly.
    • Make sure the blue adhesive liner is facing up and the tab cutout is to the left of the front-facing camera.
  19. Google Pixel 7a Screen Replacement: 步骤 19 中的图像 1,3 Google Pixel 7a Screen Replacement: 步骤 19 中的图像 2,3 Google Pixel 7a Screen Replacement: 步骤 19 中的图像 3,3
    • Take your time aligning the adhesive with the frame—it's very sticky and can't be moved after you apply it.
    • Peel up the right half of the large adhesive liner. Don't remove the whole liner, yet.
    • Hold the adhesive by its short edges, with the right long edge of the liner folded back to expose the adhesive.
    • Lay the right long edge of the adhesive onto the frame.
    询问修复机器人
  20. Google Pixel 7a Screen Replacement: 步骤 20 中的图像 1,3 Google Pixel 7a Screen Replacement: 步骤 20 中的图像 2,3 Google Pixel 7a Screen Replacement: 步骤 20 中的图像 3,3
    • Slowly lay the rest of the adhesive onto the frame, peeling away the large liner as you go.
    询问修复机器人
  21. Google Pixel 7a Screen Replacement: 步骤 21 中的图像 1,2 Google Pixel 7a Screen Replacement: 步骤 21 中的图像 2,2
    • Use the flat end of your spudger to press along the perimeter of the adhesive and secure it to the frame.
    询问修复机器人
  22. Google Pixel 7a Screen Replacement: 步骤 22 中的图像 1,3 Google Pixel 7a Screen Replacement: 步骤 22 中的图像 2,3 Google Pixel 7a Screen Replacement: 步骤 22 中的图像 3,3
    • Grab the blue liner pull tab in the upper left corner.
    • Slowly peel and remove the liner.
    • If the adhesive starts to peel up with the liner, check that you’ve pushed all of it into place with your spudger. If it continues to peel up, hold it down with the point of your spudger as you go.
    询问修复机器人
  23. Google Pixel 7a Screen Replacement, Install the screen: 步骤 23 中的图像 1,2 Google Pixel 7a Screen Replacement, Install the screen: 步骤 23 中的图像 2,2
    • Apply a suction handle to the left side of the replacement screen, with the handle facing left.
    • Prop up your screen on the left side of the frame.
    询问修复机器人
  24. Google Pixel 7a Screen Replacement: 步骤 24 中的图像 1,2 Google Pixel 7a Screen Replacement: 步骤 24 中的图像 2,2
    • Connect the screen cable by aligning it over the socket and pressing on one side until it clicks into place before fully pressing it down.
  25. Google Pixel 7a Screen Replacement: 步骤 25 中的图像 1,3 Google Pixel 7a Screen Replacement: 步骤 25 中的图像 2,3 Google Pixel 7a Screen Replacement: 步骤 25 中的图像 3,3
    • Insert the screen connector cover into its slot in the logic board.
    • Use your T3 Torx driver to install the 2 mm 3IP Torx Plus screw and secure the screen connector cover.
  26. Google Pixel 7a Screen Replacement: 步骤 26 中的图像 1,1
    • Peel and remove the blue liner from the square adhesive on the frame.
    • Your replacement screen may have extra protective liners covering the front camera or sensors. Check the entire screen and remove any remaining liners.
  27. Google Pixel 7a Screen Replacement: 步骤 27 中的图像 1,3 Google Pixel 7a Screen Replacement: 步骤 27 中的图像 2,3 Google Pixel 7a Screen Replacement: 步骤 27 中的图像 3,3
    • Hold the screen just above the frame by the suction handle.
    • Use a spudger to fold the flap of graphite film back over the screen cable.
    • Press the screen into place.
  28. Google Pixel 7a Screen Replacement: 步骤 28 中的图像 1,2 Google Pixel 7a Screen Replacement: 步骤 28 中的图像 2,2
    • Remove the suction handle.
    • For a better seal, lightly warm the screen with a heated iOpener, hair dryer, heat gun, or hot plate before pressing around the perimeter.
    • Firmly press around the perimeter of the screen to secure it to the frame.
结论
To calibrate the display’s fingerprint reader, use Google’s Pixel Update and Software Repair tool.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
92等其他人完成本指南。
Clay Eickemeyer
于09/19/22注册
103,179 声望
创作了476篇指南
团队
Guide Team Guide Team 的会员
Staff
10 名成员
创作了17,783篇指南
32指南评论
This guide worked well for me and I was able to replace my screen despite it being severely cracked - expect a lot of screen breakage and glass pieces if that's the case! I set everything in a tray to minimize glass fragments going all over.
Once the screen was installed, the wrapper for the iFixit provided screen has a label that says "UDFPS calibration required" with a QR code.
This takes you to a Google site that tells you how to set up fingerprints on your phone. I don't think that link is helpful.
I needed to go to https://pixelrepair.withgoogle.com/udfps where Google has a tool that allows easy updating of the fingerprint sensor software on your phone, which is a requirement after a new screen is installed. Open that site on a computer (PC or Mac, no ChromeOS, no tablets) and follow the instructions, which include connecting your phone via USB cable.
Hans Chun - 回复 分享
I had trouble with the calibration step. I ended up having to install the Google USB driver. I downloaded it here and followed this guide, using the Windows 10 instructions for Windows 11
Parker Kincaid - 回复 分享
the link worked for me, thank you so much @hanschun.
I was going to flash my phone, but I just checked this guide again, and I scrolled past the iFixit link, and stumbled at your comment
Thank you again
Emmanuel Damola - 回复 分享
The guide worked very well. Although it was very hard to remove the old display (I have two left hands, all thumbs), I was able to exchange it. Thank you very much!
Martin Kinne - 回复 分享
Just replaced my phone 7a screen using the available kit. It was next to impossible to get the old screen off using the heat and pry tools. Would definitely recommend getting their jimmy tool. I ended up shattering the old screen on purpose using a punch tool and peeling the glass off the digitizer and frame. This was easiest for me without ordering another tool. Would NOT recommend doing it this way! The other deviation from these instructions is that the screen replacement version sent to me (10/2023) had the screen adhesive already applied to the screen. Made it much easier to install since there was no human error applying the screen adhesive to the phone frame first then lining up the screen. Definitely an improvement! Overall, took me way too long to complete, closer to 2+ hours due to the issues getting the old screen off. But certainly manageable by any DIYer. Would definitely buy from iFixIt again in the future if needed.
Harry - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 76
过去 7 天: 533
过去 30 天: 2,467
总计 113,798
