简介
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Follow this guide to replace the vibrator motor on a Google Pixel 4a 5G.
The unreinforced display panel on the Pixel 4a 5G is fragile. Pay special attention to the warnings in the opening procedure if you are reusing the screen.
你所需要的
Insert a SIM eject tool, bit, or straightened paper clip into the SIM tray hole.
Press directly into the hole to eject the SIM card tray.
Remove the SIM card tray.
Take note of the two seams on the edge of your phone:
Screen seam: This seam separates the screen from the rest of the phone. This is where you have to pry.
Frame seam: This is where the plastic frame meets the back cover. It is held in place by screws. Do not pry at this seam.
Before you begin, note the following areas on the screen:
Screen flex cable: Do not insert the opening pick deeper than instructed or you risk damaging this cable.
Adhesive perimeter: Prying beyond this narrow perimeter without angling the pick will damage the OLED panel.
Apply a heated iOpener to the right edge of the display for one minute to soften the adhesive.
Place a suction cup as close to the right edge of the screen as possible.
Lift the suction cup with a strong steady force.
Insert the tip of an opening pick into the screen seam no more than 1 mm.
With the pick 1 mm into the gap, pivot the pick upwards to a steep angle.
At a steep angle, carefully push the pick into the gap about 1/4 inch (6 mm). The pick should slide in below the OLED panel.
Slide the pick along the right edge of the screen to cut the adhesive.
Leave the pick in the bottom-right corner to prevent the adhesive from re-sealing.
Insert another opening pick into the right edge of the phone at an angle where a gap has already formed to prevent damage to the OLED panel.
Slide the opening pick around the top of the phone to cut the adhesive.
Leave the pick inserted along the top edge to prevent the adhesive from resealing.
Insert another opening pick into the top edge of your phone at an angle where a gap has already formed to prevent damage to the OLED panel.
Use the pick to slice around the top-left corner where the camera window is.
Leave the pick inserted along the left edge of your phone to prevent the adhesive from re-sealing.
Lift from the top edge and swing the screen over the bottom edge until you can rest it glass-side down.
Use your fingernail or a pair of tweezers to carefully peel off the tape covering the screen connector.
Remove the screen.
Check if your replacement screen has speaker mesh and top edge adhesive pre-installed.
If it does, you won't need the top edge adhesive.
If it doesn't, remove the larger clear liner from the top edge adhesive and apply it to the screen (not the frame). Make sure the larger cutout lines up with the speaker mesh.
Follow this guide to apply the custom-cut adhesive.
在这个步骤中使用的工具:Magnetic Project Mat$19.95
Use a T3 Torx driver to remove the nine 4.4 mm-long screws securing the back cover to the midframe.
Insert an opening pick into the seam between the midframe and the back cover, right above the SIM card slot.
Slide the opening pick along the right edge of your phone to release the plastic clips securing the back cover to the midframe.
Use a T3 Torx screwdriver to remove the seven screws securing the motherboard bracket:
Four 4.0 mm-long screws
Three 2.1 mm-long screws
Use the tip of a spudger to disconnect the battery cable from the motherboard.
Use the tip of a spudger to pry up and disconnect the fingerprint sensor cable.
Use your fingers or a pair of tweezers to peel the tape off of the copper foil.
Use a T3 Torx driver to remove the two 4.2 mm-long screws from the loudspeaker assembly.
Use your fingers or a pair of tweezers to pull the antenna cable out from underneath the tape covering it.
Use the tip of a spudger to disconnect the loudspeaker cable from the motherboard.
Use the tip of a spudger to disconnect the headphone jack cable from the motherboard.
Use a T3 Torx screwdriver to remove the 2.1 mm-long screw securing the charging port.
Insert the tip of a spudger into the gap between the motherboard and the midframe near the front-facing cameras to pop it free from the first clip.
Use the tip of a pair of tweezers to pry the vibration motor straight off of the midframe.
Remove the vibration motor.
