跳转到主内容
Google Pixel 3 XL Back Cover Adhesive Installation
Chayton Ritter
Chayton Ritter 另一个贡献者
最后更新于 May 7, 2024
30 - 45 分钟
中等
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Follow this guide to correctly apply replacement back cover adhesive to your Pixel 3 XL after a repair.
Before you begin, you should have already removed your Pixel’s back cover and set it aside. Detailed instructions for this can be found here.
你所需要的
配件
工具
查看更多...
  1. Google Pixel 3 XL Back Cover Adhesive Installation, Remove adhesive residue from the frame: 步骤 1 中的图像 1,3 Google Pixel 3 XL Back Cover Adhesive Installation, Remove adhesive residue from the frame: 步骤 1 中的图像 2,3 Google Pixel 3 XL Back Cover Adhesive Installation, Remove adhesive residue from the frame: 步骤 1 中的图像 3,3
    • Pick and scrape away the old adhesive from the frame.
    • Use a spudger to scrape away any lingering adhesive.
    • Don't use metal tools to scrape away adhesive as this will damage the frame.
    • For best results, clean the area underneath the removed adhesive with 90% or greater isopropyl alcohol to prep the surface for the new adhesive.
  2. Google Pixel 3 XL Back Cover Adhesive Installation, Remove adhesive residue from the back cover: 步骤 2 中的图像 1,3 Google Pixel 3 XL Back Cover Adhesive Installation, Remove adhesive residue from the back cover: 步骤 2 中的图像 2,3 Google Pixel 3 XL Back Cover Adhesive Installation, Remove adhesive residue from the back cover: 步骤 2 中的图像 3,3
    • Repeat the previous step for the back cover adhesive.
    • Don't use metal tools to scrape away adhesive as this will damage the back cover coating.
    • Don't use isopropyl alcohol near the rear camera bracket as it will damage its adhesive and foam.
  3. Google Pixel 3 XL Back Cover Adhesive Installation, Prepare the replacement adhesive: 步骤 3 中的图像 1,1
    • Peel away the plastic lining to expose the frame side of the replacement adhesive.
  4. Google Pixel 3 XL Back Cover Adhesive Installation, Apply the adhesive: 步骤 4 中的图像 1,3 Google Pixel 3 XL Back Cover Adhesive Installation, Apply the adhesive: 步骤 4 中的图像 2,3 Google Pixel 3 XL Back Cover Adhesive Installation, Apply the adhesive: 步骤 4 中的图像 3,3
    • Be very careful during this step! The adhesive is very sticky and can't be repositioned once it sticks. Misaligned adhesive can lead to an improper seal.
    • Lower the adhesive onto the frame.
    • Use the holes in the frame to properly align the adhesive.
  5. Google Pixel 3 XL Back Cover Adhesive Installation, Secure the adhesive to the frame: 步骤 5 中的图像 1,3 Google Pixel 3 XL Back Cover Adhesive Installation, Secure the adhesive to the frame: 步骤 5 中的图像 2,3 Google Pixel 3 XL Back Cover Adhesive Installation, Secure the adhesive to the frame: 步骤 5 中的图像 3,3
    • Use the flat end of a spudger or your fingernail to press down on the adhesive.
    • Slide along the perimeter to secure the adhesive to the frame.
  6. Google Pixel 3 XL Back Cover Adhesive Installation, Connect the fingerprint sensor: 步骤 6 中的图像 1,3 Google Pixel 3 XL Back Cover Adhesive Installation, Connect the fingerprint sensor: 步骤 6 中的图像 2,3 Google Pixel 3 XL Back Cover Adhesive Installation, Connect the fingerprint sensor: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    • Use tweezers to guide the fingerprint sensor cable into its socket.
    • Press down on the latch to secure it.
  7. Google Pixel 3 XL Back Cover Adhesive Installation, Peel away the remaining plastic lining: 步骤 7 中的图像 1,2 Google Pixel 3 XL Back Cover Adhesive Installation, Peel away the remaining plastic lining: 步骤 7 中的图像 2,2
    • Peel away the plastic lining to expose the back cover side of the adhesive.
  8. Google Pixel 3 XL Back Cover Adhesive Installation, Secure the back cover to the frame: 步骤 8 中的图像 1,2 Google Pixel 3 XL Back Cover Adhesive Installation, Secure the back cover to the frame: 步骤 8 中的图像 2,2
    • Lower the back cover onto the frame.
    • Press down on all edges of the back cover to secure it to the frame.
    • To help the adhesive bond more securely, heat the perimeter of the back cover and then place the phone face-down under a heavy stack of books for 30 minutes.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Pixel 3 XL Answers community for help.
5等其他人完成本指南。
Chayton Ritter
于08/21/20注册
22,506 声望
创作了105篇指南
团队
Guide Team Guide Team 的会员
Staff
9 名成员
创作了11,379篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 12
过去 30 天: 42
总计 1,912
