跳转到主内容
加入维修社区 - 创建账户
Google Pixel 3 Charging Assembly Replacement
你所需要的
  1. Google Pixel 3 Charging Assembly Replacement, Weaken the back cover's adhesive: 步骤 1 中的图像 1,1
  2. Google Pixel 3 Charging Assembly Replacement, Create a gap in the seam: 步骤 2 中的图像 1,3 Google Pixel 3 Charging Assembly Replacement, Create a gap in the seam: 步骤 2 中的图像 2,3 Google Pixel 3 Charging Assembly Replacement, Create a gap in the seam: 步骤 2 中的图像 3,3
    • Apply a suction cup to the heated bottom edge of the back cover.
    • Make sure you did not mistake the screen side for the back cover side.
    • If your back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere.
    • Lift on the suction cup with strong, steady force to create a gap.
    • Depending on how aged your phone is, this may take significant force. If you are having trouble, apply more heat and try again.
    • Insert an opening pick into the gap.
    • Don't use metal tools to pry, or you'll mar or shatter the glass back cover. If the panel won't budge, apply more heat, either with a hair dryer or heat gun.
  3. Google Pixel 3 Charging Assembly Replacement, Fingerprint cable information: 步骤 3 中的图像 1,1
    • When inserting an opening pick above the power button, be careful not to insert the pick too deeply, or you will damage the fingerprint sensor cable.
  4. Google Pixel 3 Charging Assembly Replacement, Cut through the adhesive: 步骤 4 中的图像 1,3 Google Pixel 3 Charging Assembly Replacement, Cut through the adhesive: 步骤 4 中的图像 2,3 Google Pixel 3 Charging Assembly Replacement, Cut through the adhesive: 步骤 4 中的图像 3,3
    • Slice the adhesive along the bottom edge of the phone and around the right corner.
    • Leave a pick in the bottom edge to prevent the adhesive from re-sealing.
  5. Google Pixel 3 Charging Assembly Replacement: 步骤 5 中的图像 1,3 Google Pixel 3 Charging Assembly Replacement: 步骤 5 中的图像 2,3 Google Pixel 3 Charging Assembly Replacement: 步骤 5 中的图像 3,3
    • Heat the right edge with an iOpener and continue slicing the adhesive with an opening pick.
    • The adhesive can be very gummy. Push the pick in and out in a sawing motion to help with slicing.
  6. Google Pixel 3 Charging Assembly Replacement: 步骤 6 中的图像 1,3 Google Pixel 3 Charging Assembly Replacement: 步骤 6 中的图像 2,3 Google Pixel 3 Charging Assembly Replacement: 步骤 6 中的图像 3,3
    • Continue heating and slicing through the rest of the phone perimeter. Leave a pick in each edge to prevent the adhesive from resealing.
    • When slicing above the power button, do not insert the pick more than halfway in to avoid damaging the fingerprint sensor cable.
  7. Google Pixel 3 Charging Assembly Replacement, Lift the left edge of the back cover: 步骤 7 中的图像 1,3 Google Pixel 3 Charging Assembly Replacement, Lift the left edge of the back cover: 步骤 7 中的图像 2,3 Google Pixel 3 Charging Assembly Replacement, Lift the left edge of the back cover: 步骤 7 中的图像 3,3
    • Once you have sliced around the perimeter of the phone, carefully lift the left edge of the back cover.
    • Do not attempt to remove the back cover. It is still attached to the phone by the fingerprint sensor cable.
    • Flip the back cover along its long axis and rest it so that the fingerprint sensor cable is not strained.
  8. Google Pixel 3 Charging Assembly Replacement, Remove the screws: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    • Remove the two 4.1 mm-long Phillips screws securing the fingerprint connector bracket.
    • During reassembly, be careful not to over-tighten these screws, or you may damage your display.
  9. Google Pixel 3 Charging Assembly Replacement, Remove the fingerprint connector bracket: 步骤 9 中的图像 1,3 Google Pixel 3 Charging Assembly Replacement, Remove the fingerprint connector bracket: 步骤 9 中的图像 2,3 Google Pixel 3 Charging Assembly Replacement, Remove the fingerprint connector bracket: 步骤 9 中的图像 3,3
    • Use the point of a spudger to slide the fingerprint connector bracket out from under the NFC coil.
    • Remove the fingerprint connector bracket.
  10. Google Pixel 3 Charging Assembly Replacement, Disconnect the fingerprint connector: 步骤 10 中的图像 1,2 Google Pixel 3 Charging Assembly Replacement, Disconnect the fingerprint connector: 步骤 10 中的图像 2,2
    • Use the point of a spudger to pry up and disconnect the fingerprint connector from its socket.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  11. Google Pixel 3 Charging Assembly Replacement, Remove the back cover: 步骤 11 中的图像 1,3 Google Pixel 3 Charging Assembly Replacement, Remove the back cover: 步骤 11 中的图像 2,3 Google Pixel 3 Charging Assembly Replacement, Remove the back cover: 步骤 11 中的图像 3,3
    • Remove the back cover.
    • Before you install a replacement back cover, be sure to remove all adhesive residue from the phone frame. Use an opening tool to scrape and high concentration isopropyl alcohol to clean the surface.
    • If you are re-using the back cover, be sure to clean off any adhesive, and apply new back cover adhesive.
    • If you are installing a replacement back cover, be sure to compare it with the original part. Transfer any remaining parts (such as the flash diffuser) over to your replacement part.
    • Follow this guide to correctly apply new back cover adhesive.
  12. Google Pixel 3 Charging Assembly Replacement, Remove the screws: 步骤 12 中的图像 1,1
    • Remove the five Phillips screws securing the wireless charging coil:
    • Two 1.9 mm screws
    • Two 4.2 mm screws
    • One 4.3 mm screw
  13. Google Pixel 3 Charging Assembly Replacement, Remove the charging coil: 步骤 13 中的图像 1,1
    • Lift up and remove the wireless charging coil.
  14. Google Pixel 3 Charging Assembly Replacement, Disconnect the battery cable: 步骤 14 中的图像 1,2 Google Pixel 3 Charging Assembly Replacement, Disconnect the battery cable: 步骤 14 中的图像 2,2
    • Use the point of a spudger to pry up and disconnect the battery press connector from its socket near the right edge of the phone.
  15. Google Pixel 3 Charging Assembly Replacement, Disconnect the loudspeaker: 步骤 15 中的图像 1,2 Google Pixel 3 Charging Assembly Replacement, Disconnect the loudspeaker: 步骤 15 中的图像 2,2
    • Use the point of a spudger to pry up and disconnect the loudspeaker connector from its motherboard socket near the right edge of the phone.
    • Be careful not to puncture the battery with the spudger.
  16. Google Pixel 3 Charging Assembly Replacement, Remove the screws: 步骤 16 中的图像 1,3 Google Pixel 3 Charging Assembly Replacement, Remove the screws: 步骤 16 中的图像 2,3 Google Pixel 3 Charging Assembly Replacement, Remove the screws: 步骤 16 中的图像 3,3
    • Remove the following four Phillips screws:
    • One 1.9 mm screw
    • One 4.3 mm screw
    • Two 4.3 mm screws with thinner shanks
    • Remove the tiny grounding clip from the left screw hole. Be careful not to lose it.
    • The grounding clip installs such that the contoured edge faces the left side of the phone.
    • Remove the small plastic insert from the right side of the USB-C port.
    • Be sure to reinstall this insert before you screw down the daughterboard.
  17. Google Pixel 3 Charging Assembly Replacement, Loosen the loudspeaker: 步骤 17 中的图像 1,2 Google Pixel 3 Charging Assembly Replacement, Loosen the loudspeaker: 步骤 17 中的图像 2,2
    • The loudspeaker is still held in place by a strong adhesive gasket. Before attempting to remove it, pry it up in a few different places to break the adhesive seal.
    • Insert the point of a spudger under the bottom right corner of the loudspeaker.
    • Pry up to loosen the loudspeaker from the phone.
  18. Google Pixel 3 Charging Assembly Replacement: 步骤 18 中的图像 1,2 Google Pixel 3 Charging Assembly Replacement: 步骤 18 中的图像 2,2
    • Insert the point of a spudger under the top left corner of the loudspeaker.
    • Pry up to loosen the loudspeaker.
  19. Google Pixel 3 Charging Assembly Replacement: 步骤 19 中的图像 1,2 Google Pixel 3 Charging Assembly Replacement: 步骤 19 中的图像 2,2
    • Insert the flat end of the spudger under the top edge of the loudspeaker, towards the left edge.
  20. Google Pixel 3 Charging Assembly Replacement, Remove the loudspeaker: 步骤 20 中的图像 1,2 Google Pixel 3 Charging Assembly Replacement, Remove the loudspeaker: 步骤 20 中的图像 2,2
    • Remove the loudspeaker.
    • Before you install a replacement loudspeaker, check the adhesive gasket.
    • If it is in good condition, you can re-use the gasket. Make sure that the gasket does not cover the exit hole.
    • If the gasket is pulled out of place, remove it and replace the adhesive with a pre-cut strip or Tesa tape.
  21. Google Pixel 3 Charging Assembly Replacement, Disconnect the blue antenna cable: 步骤 21 中的图像 1,2 Google Pixel 3 Charging Assembly Replacement, Disconnect the blue antenna cable: 步骤 21 中的图像 2,2
    • Use the point of a spudger to pry up and disconnect the blue antenna cable from its socket on the charging assembly.
  22. Google Pixel 3 Charging Assembly Replacement: 步骤 22 中的图像 1,2 Google Pixel 3 Charging Assembly Replacement: 步骤 22 中的图像 2,2
    • Use the point of a spudger to carefully pry up and release the blue antenna cable from its grounding clip.
    • The cable is fragile and prone to breaking. If it feels like the wire is firmly clamped in place, use the point of a spudger to push the clip open slightly, then try again.
  23. Google Pixel 3 Charging Assembly Replacement, Disconnect the black antenna cable: 步骤 23 中的图像 1,2 Google Pixel 3 Charging Assembly Replacement, Disconnect the black antenna cable: 步骤 23 中的图像 2,2
    • Use the point of a spudger to pry up and disconnect the black antenna cable from its socket near the USB-C port.
  24. Google Pixel 3 Charging Assembly Replacement, De-route the antenna cables: 步骤 24 中的图像 1,1
    • Carefully de-route both antenna cables and move them away from the charging assembly.
  25. Google Pixel 3 Charging Assembly Replacement, Disconnect the charging assembly connector: 步骤 25 中的图像 1,3 Google Pixel 3 Charging Assembly Replacement, Disconnect the charging assembly connector: 步骤 25 中的图像 2,3 Google Pixel 3 Charging Assembly Replacement, Disconnect the charging assembly connector: 步骤 25 中的图像 3,3
    • Use the point of a spudger to pry up and disconnect the charging assembly's connector from its motherboard socket, near the right edge of the phone.
    • Carefully peel the flex cable from the top of the SIM card reader.
  26. Google Pixel 3 Charging Assembly Replacement, Remove the screws: 步骤 26 中的图像 1,1
    • Remove the two 1.9 mm Phillips screws securing the charging assembly to the bottom edge of the phone.
  27. Google Pixel 3 Charging Assembly Replacement, Weaken the adhesive: 步骤 27 中的图像 1,1
    • Apply a heated iOpener to the bottom edge of the phone for a minute to loosen the adhesive holding the charging assembly in place.
  28. Google Pixel 3 Charging Assembly Replacement, Loosen the charging assembly cable: 步骤 28 中的图像 1,3 Google Pixel 3 Charging Assembly Replacement, Loosen the charging assembly cable: 步骤 28 中的图像 2,3 Google Pixel 3 Charging Assembly Replacement, Loosen the charging assembly cable: 步骤 28 中的图像 3,3
    • Insert an opening pick underneath the charging assembly's flex cable.
    • Slide the opening pick below the charging assembly to loosen it from the phone.
  29. Google Pixel 3 Charging Assembly Replacement, Remove the charging assembly: 步骤 29 中的图像 1,1
    在这个步骤中使用的工具:
    • Use a pair of tweezers or your fingers to remove the charging assembly.
  30. Google Pixel 3 Charging Assembly Replacement: 步骤 30 中的图像 1,3 Google Pixel 3 Charging Assembly Replacement: 步骤 30 中的图像 2,3 Google Pixel 3 Charging Assembly Replacement: 步骤 30 中的图像 3,3
    • When you are installing a replacement assembly:
    • Be sure to remove all plastic liners from the assembly to expose the adhesive.
    • Line up the assembly's bottom left corner into place.
    • Carefully lay the rest of the assembly in place, making sure that the USB-C port is correctly seated in its respective cutout.
    • Use your fingers to press the assembly onto the frame.
结论
Repair didn’t go as planned? Check out our Google Pixel 3 Answers community for troubleshooting help.
39等其他人完成本指南。
Arthur Shi
于01/03/18注册
317,924 声望
创作了736篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了24,040篇指南
12指南评论
is the adhesive for the back of the phone reusable, or do I need to buy a replacement adhesive for reassembly?
Campbell Wright - 回复
It depends on the age of your phone it seems - the older the phone, the less resuseable the existing adhesive. I used gasket maker to reseal my phone, in part because I did not want to heat my new battery up when trying to reseal the back cover. I would advise getting some additional adhesive if you want a water-tight assembly.
Andrew Williams -
Best to order a new back phone lid, as my back lid shattered when trying to prise it off, despite repeated heating to uncomfortably hot. Also, if you’re replacing the charging logic board because of the ‘unrecognised analogue device’ messsage, I still got the same message AFTER having put everything back together having replaced the logic board. If you shatter the back lid of the phone and have to replace it, the finger print scanner and lens covers are all prisable off and reapplicable to the new cover (with a little heating). But this requires care. Make sure to replace the battery also - because of the ka-fafel of opening this barely user-repairable phone (Cheers Google!). I ended up using gasket maker silicone (yes the stuff I use for reassembling my motorbike engine) to seal everything. Seems to have worked a treat. Good luck - you’ll need it!
Andrew Williams - 回复
I swapped out the USB-C charging port and battery at the same time. Hopefully I can get another two years out of the phone now. If you are just changing this port, then I would recommend changing the battery too. The battery replacement kit comes with new adhesive to reseal the back panel.
Trey Ethridge - 回复
can I do this with a heat gun instead of the iOpener? what do I set the temperature to?
Moya Alhayek - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 71
过去 30 天: 306
总计 34,960
