跳转到主内容
加入维修社区 - 创建账户
Google Pixel 3 Back Cover Adhesive Installation
你所需要的
    1. Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the frame: 步骤 1 中的图像 1,3 Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the frame: 步骤 1 中的图像 2,3 Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the frame: 步骤 1 中的图像 3,3
      • Pick and scrape away the old adhesive from the frame.
      • Use a spudger to scrape away any lingering adhesive.
      • Don't use metal tools to scrape away adhesive as this will damage the frame.
      • For best results, clean the area underneath the removed adhesive with 90% or greater isopropyl alcohol to prep the surface for the new adhesive.
      询问修复机器人
      添加评论
    2. Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the back cover: 步骤 2 中的图像 1,3 Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the back cover: 步骤 2 中的图像 2,3 Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the back cover: 步骤 2 中的图像 3,3
      • Repeat the previous step for the back cover adhesive.
      • Don't use metal tools to scrape away adhesive as this will damage the back cover coating.
      • Don't use isopropyl alcohol near the rear camera bracket as it will damage its adhesive and foam.
      添加评论
    3. Google Pixel 3 Back Cover Adhesive Installation, Prepare the replacement adhesive: 步骤 3 中的图像 1,1
      • Peel away the clear plastic lining to expose the frame side of the replacement adhesive.
      添加评论
    4. Google Pixel 3 Back Cover Adhesive Installation, Apply the adhesive: 步骤 4 中的图像 1,2 Google Pixel 3 Back Cover Adhesive Installation, Apply the adhesive: 步骤 4 中的图像 2,2
      • Be very careful during this step! The adhesive is very sticky and can't be repositioned once it sticks. Misaligned adhesive can lead to an improper seal.
      • Lower the adhesive onto the frame.
      • Use the rear camera and corners to properly align the adhesive.
      添加评论
    5. Google Pixel 3 Back Cover Adhesive Installation, Secure the adhesive to the frame: 步骤 5 中的图像 1,2 Google Pixel 3 Back Cover Adhesive Installation, Secure the adhesive to the frame: 步骤 5 中的图像 2,2
      • Use the flat end of a spudger or your fingernail to press down on the adhesive.
      • Slide along the perimeter to secure the adhesive to the frame.
      询问修复机器人
      添加评论
    6. Google Pixel 3 Back Cover Adhesive Installation, Peel away the outer plastic lining: 步骤 6 中的图像 1,2 Google Pixel 3 Back Cover Adhesive Installation, Peel away the outer plastic lining: 步骤 6 中的图像 2,2
      • Peel away the blue outer plastic lining on the back cover side of the adhesive.
      询问修复机器人
      添加评论
    7. Google Pixel 3 Back Cover Adhesive Installation, Connect the fingerprint sensor cable: 步骤 7 中的图像 1,2 Google Pixel 3 Back Cover Adhesive Installation, Connect the fingerprint sensor cable: 步骤 7 中的图像 2,2
      在这个步骤中使用的工具:
      • Use tweezers or your fingers to position the fingerprint sensor cable over its connector on the motherboard.
      • Use the flat end of a spudger or your finger to press down on the connector to secure it to the motherboard.
      询问修复机器人
      添加评论
    8. Google Pixel 3 Back Cover Adhesive Installation: 步骤 8 中的图像 1,3 Google Pixel 3 Back Cover Adhesive Installation: 步骤 8 中的图像 2,3 Google Pixel 3 Back Cover Adhesive Installation: 步骤 8 中的图像 3,3
      • Use tweezers or your fingers to place the bracket over the fingerprint sensor cable.
      询问修复机器人
      添加评论
    9. Google Pixel 3 Back Cover Adhesive Installation: 步骤 9 中的图像 1,2 Google Pixel 3 Back Cover Adhesive Installation: 步骤 9 中的图像 2,2
      • Use a Phillips PH00 screwdriver to install the two 4.1 mm screws securing the bracket to the frame.
      询问修复机器人
      添加评论
    10. Google Pixel 3 Back Cover Adhesive Installation, Peel away the remaining plastic lining: 步骤 10 中的图像 1,2 Google Pixel 3 Back Cover Adhesive Installation, Peel away the remaining plastic lining: 步骤 10 中的图像 2,2
      • Peel away the red plastic lining to expose the back cover side of the adhesive.
      添加评论
    11. Google Pixel 3 Back Cover Adhesive Installation, Secure the back cover to the frame: 步骤 11 中的图像 1,2 Google Pixel 3 Back Cover Adhesive Installation, Secure the back cover to the frame: 步骤 11 中的图像 2,2
      • Lower the back cover onto the frame.
      • Press down on all edges of the back cover to secure it to the frame.
      • To help the adhesive bond more securely, heat the perimeter of the back cover and then place the phone face-down under a heavy stack of books for 30 minutes.
      添加评论
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Pixel 3 Answers community for help.
取消:我没有完成这个指南。
11等其他人完成本指南。
Chayton Ritter
于08/21/20注册
27,165 声望
创作了105篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 23
过去 30 天: 80
总计 4,650
