跳转到主内容
加入维修社区 - 创建账户
Framework Laptop 12 Fastener Guide
你所需要的
  1. Framework Laptop 12 Fastener Guide, Fasteners information: 步骤 1 中的图像 1,2 Framework Laptop 12 Fastener Guide, Fasteners information: 步骤 1 中的图像 2,2
    • The Fastener Kit contains the following:
    • Grey screws labeled "M1.6 1.5mm fastener with a 5.5mm diameter 0.6mm thick T5 head"
    • Silver screws labeled "M1.6 2.5mm fastener with a 3.5mm diameter 0.5mm thick T5 head"
    • Black screws labeled "M1.6 3.5mm fastener with a 3.0mm diameter 1.3mm thick T5 head"
    • Gold screws labeled "M2 2.0mm fastener with a 6.0mm diameter 0.5mm thick T5 head"
    • Silver screws labeled "M2 2.8mm fastener with a 4.0mm diameter 0.5mm thick T5 head"
    • Silver screws labeled "M1.6 4.0mm fastener with a 4.6mm diameter 0.6mm thick T5 head"
    • Your Framework Laptop comes with a spare screw of each size, attached to the chassis above the battery. You can use the Fastener Kit to replenish any screws you used there.
    询问修复机器人
    添加评论
  2. Framework Laptop 12 Fastener Guide, Antenna screws: 步骤 2 中的图像 1,3 Framework Laptop 12 Fastener Guide, Antenna screws: 步骤 2 中的图像 2,3 Framework Laptop 12 Fastener Guide, Antenna screws: 步骤 2 中的图像 3,3
    • Use the gold screws labeled "M2 2.0mm fastener with a 6.0mm diameter 0.5mm thick T5 head" to secure the antennas.
    询问修复机器人
    添加评论
  3. Framework Laptop 12 Fastener Guide, Display screws: 步骤 3 中的图像 1,2 Framework Laptop 12 Fastener Guide, Display screws: 步骤 3 中的图像 2,2
    • Use the silver screws labeled "M2 2.8mm fastener with a 4.0mm diameter 0.5mm thick T5 head" to secure the display.
    • Tighten the screws until they're snug. Don't over-tighten them, or you may break the screw tabs.
    询问修复机器人
    添加评论
  4. Framework Laptop 12 Fastener Guide, Expansion Card lock screws: 步骤 4 中的图像 1,3 Framework Laptop 12 Fastener Guide, Expansion Card lock screws: 步骤 4 中的图像 2,3 Framework Laptop 12 Fastener Guide, Expansion Card lock screws: 步骤 4 中的图像 3,3
    • Use the black screws labeled "M1.6 3.5mm fastener with a 3.0mm diameter 1.3mm thick T5 head" to secure the Expansion Card latches.
    • Use the silver screws labeled "M1.6 2.5mm fastener with a 3.5mm diameter 0.5mm thick T5 head" to replace the Expansion Card lock screws.
    询问修复机器人
    添加评论
  5. Framework Laptop 12 Fastener Guide, Hinge screws (bottom): 步骤 5 中的图像 1,3 Framework Laptop 12 Fastener Guide, Hinge screws (bottom): 步骤 5 中的图像 2,3 Framework Laptop 12 Fastener Guide, Hinge screws (bottom): 步骤 5 中的图像 3,3
    • Use the silver screws labeled "M2 4.0mm fastener with a 4.6mm diameter 0.6mm thick T5 head" to secure the hinges to the Bottom Cover.
    询问修复机器人
    添加评论
  6. Framework Laptop 12 Fastener Guide, Hinge screws (top): 步骤 6 中的图像 1,3 Framework Laptop 12 Fastener Guide, Hinge screws (top): 步骤 6 中的图像 2,3 Framework Laptop 12 Fastener Guide, Hinge screws (top): 步骤 6 中的图像 3,3
    • Use the gold screws labeled "M2 2.0mm fastener with a 6.0mm diameter 0.5mm thick T5 head" to secure the hinges to the Top Cover.
    询问修复机器人
    添加评论
  7. Framework Laptop 12 Fastener Guide, Power Button screw: 步骤 7 中的图像 1,2 Framework Laptop 12 Fastener Guide, Power Button screw: 步骤 7 中的图像 2,2
    • Use the grey screw labeled "M1.6 1.5mm fastener with a 5.5mm diameter 0.6mm thick T5 head" to secure the Power Button.
    询问修复机器人
    添加评论
  8. Framework Laptop 12 Fastener Guide, SSD clip screw: 步骤 8 中的图像 1,2 Framework Laptop 12 Fastener Guide, SSD clip screw: 步骤 8 中的图像 2,2
    • Use the black screw labeled "M1.6 3.5mm fastener with a 3.0mm diameter 1.3mm thick T5 head" to secure the SSD clip.
    询问修复机器人
    添加评论
  9. Framework Laptop 12 Fastener Guide, Touchpad screws: 步骤 9 中的图像 1,3 Framework Laptop 12 Fastener Guide, Touchpad screws: 步骤 9 中的图像 2,3 Framework Laptop 12 Fastener Guide, Touchpad screws: 步骤 9 中的图像 3,3
    • Use the grey screws labeled "M1.6 1.5mm fastener with a 5.5mm diameter 0.6mm thick T5 head" to secure the touchpad.
    • Use the gold screws labeled "M2 2.0mm fastener with a 6.0mm diameter 0.5mm thick T5 head" to secure the touchpad pogo connector.
    询问修复机器人
    添加评论
  10. Framework Laptop 12 Fastener Guide, Webcam screws: 步骤 10 中的图像 1,2 Framework Laptop 12 Fastener Guide, Webcam screws: 步骤 10 中的图像 2,2
    • Use the silver screws labeled "M2 2.8mm fastener with a 4.0mm diameter 0.5mm thick T5 head" to secure the webcam.
    询问修复机器人
    添加评论
结论
If you need help, contact Framework support.
取消:我没有完成这个指南。
Arthur Shi
于01/03/18注册
338,159 声望
创作了851篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 44
总计 254
