简介
Follow this guide to replace the adaptive trigger assembly in your Sony DualSense Edge controller.
If your L2 or R2 triggers are stuck, loose, or unresponsive, you may need to replace the adaptive trigger assembly.
你所需要的
Place the controller on a work surface with the joysticks facing down.
Use a spudger or your finger to slide the Release tab to the left. The front trim should fall to the table.
Lift the controller up, leaving the front trim on the table.
Flip the controller over so the joysticks are facing up.
Lift the metal lever that holds the joystick in place until the joystick slides out slightly.
Slide the joystick out from its slot.
Insert the flat edge of an opening pick between the black portion of the rear trim and the top cover, near the joystick lever.
Slide the opening pick towards the bottom of the grip to release the clips.
Slide the pick around to the rear of the controller and flip the controller over so the buttons are facing down.
Slide the opening pick around the edge of the rear trim to release the clips.
Slide the opening along the edge of the trim on the other grip.
Once all clips are released, remove the trim.
Insert the flat end of a spudger in the gap between the L1 and L2 buttons.
Use the spudger to pry out the L1 button.
Repeat this process to remove the R1 button.
Rotate the controller so the grips are pointing towards you.
Use a pair of angled tweezers to lift the right end of the release bar spring off of the white post.
Use a pair of tweezers or your fingers to slide the release bar to the left.
Slide the release bar away from the controller to remove it.
Remove the nine screws securing the rear case:
Seven 6.4 mm‑long screws
Two 10.5 mm‑long screws
Insert the point an opening pick in the gap along the outside edge of one of the controller grips, near the bottom.
Pry with the opening pick to separate the rear case from the front case by releasing the clips that hold them together.
Continue prying along the edge of the controller until one side is separated.
Hold the main body of the controller with one hand.
Lift the rear case with your other hand. It should lift at an angle.
Pushing slightly towards the L and R buttons, lift the rear case off of the controller and remove it.
Use a pair of tweezers or your fingers to lift the cover from the controller.
Slide the flat end of the cover under the plastic tab in the rear case.
Lift the battery and move it to the right, so the connector underneath the battery is accessible.
Use the flat end of a spudger to pry up the low profile connector.
Remove the battery.
Use a pair of tweezers to disconnect the vibration motor cable by lifting the JST connector out of its socket.
Continue lifting until the vibration motor cable is free of the clip on the trigger assembly.
Remove the two 6.4 mm‑long screws securing the trigger assembly.
Lift the trigger assembly away from the controller and hold it so you can access the ribbon cable underneath it.
While holding the trigger assembly above the controller, use a pair of tweezers to disconnect the trigger assembly ribbon cable by gripping the pull tab and pulling away from the connector.
Remove the trigger assembly
另外一个人完成了本指南。
7指南评论
I concour, Where can we purchase a replacement trigger assembly? The replacement is nowhere to be found on the internet. Mine's pulverized from an accidental drop. The controller is gathering dust ever since. Please advice. Thank you.
pc digital - 回复 分享
I know these comments were a while back, but did anybody find out where to purchase the trigger assembly
Nope. Nothing yet.
Rocco Laurie - 回复 分享
