跳转到主内容
DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement
Theodore Tan
Theodore Tan2 其他贡献者
最后更新于 April 16, 2023
10 - 15 分钟
中等
动态照片拍摄
不正确的工具
缺少的步骤
步骤精简
Is your input jack broken in your chromatic tuner? Instead of buying a new one you can just buy the input part itself and replace it. This method works for similar tuners but this guide is specifically for the DeltaLab CT-40 Chromatic Tuner.
你所需要的
工具
查看更多...
  1. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement, Input Jack Port: 步骤 1 中的图像 1,2 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement, Input Jack Port: 步骤 1 中的图像 2,2
    • First, open the metal stand to access the screws without damaging the body.
  2. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: 步骤 2 中的图像 1,2 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: 步骤 2 中的图像 2,2
    • Remove the 3 outer 1.2 mm Phillips #1 screws using a small head screwdriver.
  3. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: 步骤 3 中的图像 1,2 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: 步骤 3 中的图像 2,2
    • Remove the back casing to reveal the inner circuitry.
  4. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: 步骤 4 中的图像 1,1
    • Locate the different parts of your tuner, finding the broken input jack port.
  5. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: 步骤 5 中的图像 1,2 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: 步骤 5 中的图像 2,2
    • Snip the wires attached to the input jack port using the wire cutter as close to the input jack port as possible.
  6. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: 步骤 6 中的图像 1,2 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: 步骤 6 中的图像 2,2
    • Take your new input jack port and solder the wires to the corresponding connection areas on the new port.
    • Learn how to solder (here).
  7. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: 步骤 7 中的图像 1,2 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: 步骤 7 中的图像 2,2
    • Fold the wires back and put the new input port into the slot where it belongs on the tuner.
  8. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: 步骤 8 中的图像 1,3 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: 步骤 8 中的图像 2,3 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: 步骤 8 中的图像 3,3
    • Replace the casing and 3 1.2 mm Phillips #1 screws using the screwdriver.
终点
另外一个人完成了本指南。
Theodore Tan
于02/24/15注册
137 声望
撰写一个指南
团队
Cal Poly, Team 23-4, Green Winter 2015 Cal Poly, Team 23-4, Green Winter 2015 的会员
CPSU-GREEN-W15S23G4
7 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 576
