跳转到主内容
Dell Inspiron 15-7559 Battery Replacement
Trenton Greevebiester
Trenton Greevebiester3 其他贡献者
最后更新于 January 31, 2022
5 - 20 分钟
中等
This guide will demonstrate how to replace the battery for the Dell Inspiron 15-7559. This may be necessary if you have issues charging or turning on the device.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
你所需要的
配件
工具
查看更多...
  1. Dell Inspiron 15-7559 Battery Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Turn off the computer.
    • Disconnect the charging cable from the computer.
    • Failure to turn off the device and disconnect the cable could lead to personal injury or device damage.
    • Flip the computer upside down.
  2. Dell Inspiron 15-7559 Battery Replacement: 步骤 2 中的图像 1,3 Dell Inspiron 15-7559 Battery Replacement: 步骤 2 中的图像 2,3 Dell Inspiron 15-7559 Battery Replacement: 步骤 2 中的图像 3,3
    • Remove the captive screw located on the top section of the back panel, using a Philips #1 screwdriver.
    • Keep in mind that the screw cannot be fully removed from the panel, even when fully loosened.
  3. Dell Inspiron 15-7559 Battery Replacement: 步骤 3 中的图像 1,3 Dell Inspiron 15-7559 Battery Replacement: 步骤 3 中的图像 2,3 Dell Inspiron 15-7559 Battery Replacement: 步骤 3 中的图像 3,3
    • Use the blue, plastic opening tool to gently pry a section of the back panel open.
    • Next slide the opening tool around the back panel to disconnect the clips holding the panel in place.
    • After the clips have been disconnected, the back panel can then be easily lifted off the computer.
  4. Dell Inspiron 15-7559 Battery Replacement, Battery: 步骤 4 中的图像 1,1
    • Locate the battery on the bottom left side of the laptop.
  5. Dell Inspiron 15-7559 Battery Replacement: 步骤 5 中的图像 1,3 Dell Inspiron 15-7559 Battery Replacement: 步骤 5 中的图像 2,3 Dell Inspiron 15-7559 Battery Replacement: 步骤 5 中的图像 3,3
    • Unscrew the 5 x 2mm x 5mm screws, using the T8 Torx screwdriver.
  6. Dell Inspiron 15-7559 Battery Replacement: 步骤 6 中的图像 1,3 Dell Inspiron 15-7559 Battery Replacement: 步骤 6 中的图像 2,3 Dell Inspiron 15-7559 Battery Replacement: 步骤 6 中的图像 3,3
    • Using the tab above the battery, raise the battery far enough to disconnect the cables attached to it.
    • Using your hand grab the white portion connecting the cables to the battery and disconnect it.
    • Do not pull on the cables directly. This would risk damaging them or tearing them from the device.
  7. Dell Inspiron 15-7559 Battery Replacement: 步骤 7 中的图像 1,1
    • Now lift the battery from the device to remove it.
结论
11等其他人完成本指南。
团队
UW Tacoma, Team S3-G2, Liner Fall 2017 UW Tacoma, Team S3-G2, Liner Fall 2017 的会员
UWT-LINER-F17S3G2
5 名成员
创作了9篇指南
2指南评论
Cool, that’s the easy part. How do you tell the UEFI that it’s okay to charge the new battery?
Stefan Bacon - 回复
is it ok to replace the 11.4V battery with the 11.1V version?
Payton DePietro - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 38
总计 16,983
