跳转到主内容
Dell Inspiron 13-7352 Battery Replacement
Mikinna Martin
Mikinna Martin6 其他贡献者
最后更新于 September 3, 2020
5 - 10 分钟
非常容易
This guide shows how to remove and replace a worn out battery for the Dell Inspiron 13-7352 laptop.
你所需要的
配件
工具
查看更多...
  1. Dell Inspiron 13-7352 Battery Replacement, Battery: 步骤 1 中的图像 1,3 Dell Inspiron 13-7352 Battery Replacement, Battery: 步骤 1 中的图像 2,3 Dell Inspiron 13-7352 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
    • Use the plastic opening tool to pry up and loosen the back panel.
    • Remove the back panel.
  2. Dell Inspiron 13-7352 Battery Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 13-7352 Battery Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery.
    • Unclip the hard drive wire from the battery.
  3. Dell Inspiron 13-7352 Battery Replacement: 步骤 3 中的图像 1,1
    • Gently remove the battery from the rest of the device.
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
8等其他人完成本指南。
Mikinna Martin
于09/25/15注册
461 声望
创作了2篇指南
团队
3条评论
Last I looked up for a different model there was a video..
pc2053 - 回复
Hello,
My Dell Inspiron 13-7352 won't turn on; I was using it when there was power outage and I totally drained the battery and it went off automatically, after the power came back I charged it the whole night but it still totally doesn't turn on. I tried to long-press the power button but nothing happens. I am 99% sure that the reason was using it on battery until the whole charge was gone. Please help!
jobgondwe - 回复
My Dell did the same thing. I followed the above instructions to remove the battery and then put it right back in. Plugged into power and wa-la...it powered up. So simple. Thanks.
pcoladeb - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 22
总计 25,103
