跳转到主内容
加入维修社区 - 创建账户
Battery Disconnection
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Battery Disconnection, Heat the edge: 步骤 1 中的图像 1,1
    • Discharge your battery to 25% or lower and power off your phone before you begin.
    • Heat an iOpener and apply it to the edge of the back cover with the SIM card slot for two minutes.
    • A hair dryer or heat gun may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Battery Disconnection, Insert an opening pick: 步骤 2 中的图像 1,3 Battery Disconnection, Insert an opening pick: 步骤 2 中的图像 2,3 Battery Disconnection, Insert an opening pick: 步骤 2 中的图像 3,3
    • Apply a suction cup to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the cover and the frame.
    • Insert an opening pick into the gap.
  3. Battery Disconnection, Slice the right adhesive: 步骤 3 中的图像 1,3 Battery Disconnection, Slice the right adhesive: 步骤 3 中的图像 2,3 Battery Disconnection, Slice the right adhesive: 步骤 3 中的图像 3,3
    • Slide your opening pick back and forth along the right edge to slice through the adhesive.
    • Leave the pick in at the bottom right corner to prevent the adhesive from resealing.
  4. Battery Disconnection, Slice the bottom adhesive: 步骤 4 中的图像 1,2 Battery Disconnection, Slice the bottom adhesive: 步骤 4 中的图像 2,2
    • Insert a second opening pick into the bottom right corner.
    • Slide this opening pick along the bottom edge to the bottom left corner to slice through the adhesive.
    • Leave the pick inserted to prevent the bottom edge from resealing.
  5. Battery Disconnection, Slice the left adhesive: 步骤 5 中的图像 1,3 Battery Disconnection, Slice the left adhesive: 步骤 5 中的图像 2,3 Battery Disconnection, Slice the left adhesive: 步骤 5 中的图像 3,3
    • Insert a third opening pick into the bottom right corner.
    • Slide this opening pick along the left edge to slice the adhesive.
    • Don't worry about slicing under the camera bezel. It's separate from the back cover and will be removed later.
    • Leave the pick inserted in the top left corner to prevent the left edge from resealing.
  6. Battery Disconnection, Slice the top adhesive: 步骤 6 中的图像 1,2 Battery Disconnection, Slice the top adhesive: 步骤 6 中的图像 2,2
    • Insert a fourth pick into the top left corner.
    • Slide the pick to the top right corner to slice the top adhesive.
  7. Battery Disconnection, Slice around the camera bezel: 步骤 7 中的图像 1,1
    • Slide an opening pick between the camera bezel and the back cover.
    • The back cover's adhesive is particularly strong around the camera bezel.
    • Slide the opening pick around the camera bezel to separate the back cover from the frame.
  8. Battery Disconnection, Remove the back cover: 步骤 8 中的图像 1,3 Battery Disconnection, Remove the back cover: 步骤 8 中的图像 2,3 Battery Disconnection, Remove the back cover: 步骤 8 中的图像 3,3
    • Grab and remove the back cover by lifting it away from the phone.
    • If your back cover is still sticking to the frame, slide the pick around the edges of the phone to slice through any remaining adhesive.
    • Reassembly notes:
    • To adhere the back cover with custom-cut adhesives, follow this guide.
    • To adhere the back cover with tape, follow this guide.
  9. Battery Disconnection, Heat the camera bezel: 步骤 9 中的图像 1,1
    • Heat an iOpener and apply it to the camera bezel for two minutes.
  10. Battery Disconnection, Slice the adhesive: 步骤 10 中的图像 1,3 Battery Disconnection, Slice the adhesive: 步骤 10 中的图像 2,3 Battery Disconnection, Slice the adhesive: 步骤 10 中的图像 3,3
    • Insert an opening pick under the camera bezel.
    • Slide the pick around the perimeter of the bezel to slice the adhesive.
    • If it feels stuck, apply more heat to further loosen the adhesive.
  11. Battery Disconnection, Remove the camera bezel: 步骤 11 中的图像 1,3 Battery Disconnection, Remove the camera bezel: 步骤 11 中的图像 2,3 Battery Disconnection, Remove the camera bezel: 步骤 11 中的图像 3,3
    • Grab and remove the camera bezel.
    • Reassembly notes:
    • This is a good point to test your phone before sealing it up. Follow this guide to perform a hardware test. Be sure to power your phone back down completely before you continue working.
    • To adhere the camera bezel with custom-cut adhesives, follow this guide.
    • To adhere the camera bezel with tape, follow this guide.
  12. Battery Disconnection, Unfasten the motherboard cover: 步骤 12 中的图像 1,1
    • Use a Phillips screwdriver to remove the eleven 4.1 mm-long screws securing the motherboard cover.
    • If you can't find all the screws, check under any leftover adhesive residue.
  13. Battery Disconnection, Unclip the right edge: 步骤 13 中的图像 1,3 Battery Disconnection, Unclip the right edge: 步骤 13 中的图像 2,3 Battery Disconnection, Unclip the right edge: 步骤 13 中的图像 3,3
    • Insert a spudger between the bottom right corner of the cover and the frame.
    • Pry up to release the clips securing the cover.
    • Slide the spudger toward the top of the cover and pry to release the right edge.
  14. Battery Disconnection, Remove the motherboard cover: 步骤 14 中的图像 1,2 Battery Disconnection, Remove the motherboard cover: 步骤 14 中的图像 2,2
    • Grip the right edge of the cover and pull it off the motherboard.
  15. Battery Disconnection, Disconnect the battery: 步骤 15 中的图像 1,2 Battery Disconnection, Disconnect the battery: 步骤 15 中的图像 2,2
    • Use the point of a spudger to pry up the battery's press connector.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
结论
Clay Eickemeyer
于09/19/22注册
97,481 声望
创作了470篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 91
