跳转到主内容
加入维修社区 - 创建账户
Anker Soundcore Space One Battery Replacement
你所需要的
    1. Anker Soundcore Space One Battery Replacement, Battery: 步骤 1 中的图像 1,1
      • Flip over the device so you can see the Soundcore symbol on the back two ear pieces.
      询问修复机器人
      添加评论
    2. Anker Soundcore Space One Battery Replacement: 步骤 2 中的图像 1,2 Anker Soundcore Space One Battery Replacement: 步骤 2 中的图像 2,2
      • Take a strong spudger (metal or plastic) and carefully insert it into the lining between the two back ear pieces.
      • Using a metal spudger (like the one pictured) can cut you if not used correctly. Please be mindful of where you insert it if you choose to use one
      • Removing the cover can take a couple of minutes. However, don't be aggressive while removing it, as you could damage the interior components under the back earpiece
      询问修复机器人
      添加评论
    3. Anker Soundcore Space One Battery Replacement: 步骤 3 中的图像 1,3 Anker Soundcore Space One Battery Replacement: 步骤 3 中的图像 2,3 Anker Soundcore Space One Battery Replacement: 步骤 3 中的图像 3,3
      • Carefully remove the cover to reveal the battery.
      • Take a spudger and carefully lift the battery from the interior components.
      • Take care not to warp, bend, or puncture the battery.
      • The battery has a layer of adhesive under it. If necessary, use a hairdryer to lightly heat the battery to loosen the battery adhesive.
      询问修复机器人
      添加评论
    4. Anker Soundcore Space One Battery Replacement: 步骤 4 中的图像 1,1
      • Lift out the battery.
      询问修复机器人
      添加评论
    5. Anker Soundcore Space One Battery Replacement: 步骤 5 中的图像 1,1
      • Desolder the battery connections.
      询问修复机器人
      添加评论
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
取消:我没有完成这个指南。
Malcolm Hewlett
于03/21/25注册
433 声望
创作了4篇指南
团队
UMass Dartmouth, Team 2-3, Botvin Spring 2025 UMass Dartmouth, Team 2-3, Botvin Spring 2025 的会员
UMASSD-BOTVIN-S25S2G3
3 名成员
创作了19篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 34
过去 30 天: 196
总计 2,095
