跳转到主内容
Analogue Pocket Main Board Replacement
Spencer Day
Spencer Day
最后更新于 June 21, 2024
30 - 45 分钟
中等
Use this guide to replace the main board in your Analogue Pocket.
你所需要的
工具
查看更多...
  1. Analogue Pocket Main Board Replacement, Prepare your device for disassembly: 步骤 1 中的图像 1,3 Analogue Pocket Main Board Replacement, Prepare your device for disassembly: 步骤 1 中的图像 2,3 Analogue Pocket Main Board Replacement, Prepare your device for disassembly: 步骤 1 中的图像 3,3
    • Unplug all cables and fully power off your device.
    • Working on your device requires laying it screen-side down. To prevent damage, lay it on a soft surface such as a towel.
    • If you have an SD card installed, remove it.
  2. Analogue Pocket Main Board Replacement, Unfasten the battery shell: 步骤 2 中的图像 1,2 Analogue Pocket Main Board Replacement, Unfasten the battery shell: 步骤 2 中的图像 2,2
    • Use a T6 Torx screwdriver to remove the four 13.4 mm‑long screws securing the battery shell.
  3. Analogue Pocket Main Board Replacement, Remove the battery shell: 步骤 3 中的图像 1,3 Analogue Pocket Main Board Replacement, Remove the battery shell: 步骤 3 中的图像 2,3 Analogue Pocket Main Board Replacement, Remove the battery shell: 步骤 3 中的图像 3,3
  4. Analogue Pocket Main Board Replacement, Disconnect the battery: 步骤 4 中的图像 1,2 Analogue Pocket Main Board Replacement, Disconnect the battery: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    • Use blunt nose tweezers to pull the battery connector out of its socket on the bottom right corner of your device.
    • If you're having trouble, try rocking the connector side-to-side to help loosen it.
    • During reassembly, use the flat end of a spudger to push down on the edges of the connector until it's secure in the socket.
  5. Analogue Pocket Main Board Replacement, Remove the battery: 步骤 5 中的图像 1,3 Analogue Pocket Main Board Replacement, Remove the battery: 步骤 5 中的图像 2,3 Analogue Pocket Main Board Replacement, Remove the battery: 步骤 5 中的图像 3,3
    • Lift one of the battery's short edges until the clips release.
    • Remove the battery.
    • During reassembly, push the battery into its recess until the clips engage.
  6. Analogue Pocket Main Board Replacement, Unclip the button board: 步骤 6 中的图像 1,3 Analogue Pocket Main Board Replacement, Unclip the button board: 步骤 6 中的图像 2,3 Analogue Pocket Main Board Replacement, Unclip the button board: 步骤 6 中的图像 3,3
    • A plastic clip secures the center of the button board.
    • Use the point of a spudger to push the clip out and release the board.
    • Don't try to remove the board—a delicate ribbon cable secures it to the device.
  7. Analogue Pocket Main Board Replacement, Reposition the button board: 步骤 7 中的图像 1,3 Analogue Pocket Main Board Replacement, Reposition the button board: 步骤 7 中的图像 2,3 Analogue Pocket Main Board Replacement, Reposition the button board: 步骤 7 中的图像 3,3
    • Swing the bottom edge of the button board up and over the cartridge reader.
    • Set the board on top of the cartridge reader so the cable's connector is facing the bottom of the device.
    • During reassembly:
    • Put the top edges of the board under their tabs on the rear shell.
    • Lay the board onto the rear shell so the alignment posts go into their circular cutouts on the board.
    • Press the board down until the plastic clip engages.
  8. Analogue Pocket Main Board Replacement, Disconnect the button board: 步骤 8 中的图像 1,3 Analogue Pocket Main Board Replacement, Disconnect the button board: 步骤 8 中的图像 2,3 Analogue Pocket Main Board Replacement, Disconnect the button board: 步骤 8 中的图像 3,3
    • Use the tip of a spudger or a clean fingernail to flip up the hinged locking flap on the board cable ZIF connector located on the board itself.
    • Use blunt nose tweezers to pull the cable straight out of its socket.
  9. Analogue Pocket Main Board Replacement, Remove the board: 步骤 9 中的图像 1,2 Analogue Pocket Main Board Replacement, Remove the board: 步骤 9 中的图像 2,2
    • Remove the board.
  10. Analogue Pocket Main Board Replacement, Unclip the rear shell: 步骤 10 中的图像 1,3 Analogue Pocket Main Board Replacement, Unclip the rear shell: 步骤 10 中的图像 2,3 Analogue Pocket Main Board Replacement, Unclip the rear shell: 步骤 10 中的图像 3,3
    • Sliding tabs secure the perimeter of the rear shell.
    • Firmly grip your device with one hand.
    • With your free hand, lift the bottom edge of the rear shell until it clears the front shell.
    • Pull the rear shell down until the sliding tabs disengage.
  11. Analogue Pocket Main Board Replacement, Remove the rear shell: 步骤 11 中的图像 1,3 Analogue Pocket Main Board Replacement, Remove the rear shell: 步骤 11 中的图像 2,3 Analogue Pocket Main Board Replacement, Remove the rear shell: 步骤 11 中的图像 3,3
    • Remove the rear shell.
    • Thread the button board cable through its slot in the rear shell.
    • Lay the rear shell on the front shell so its bottom edge slightly overhangs.
    • This allows the tabs to slide into place. If the rear shell is perfectly flush with the front shell, the tabs won't slide.
    • Push the rear shell in and slide it up to engage the sliding tabs.
  12. Analogue Pocket Main Board Replacement, Disconnect the main board: 步骤 12 中的图像 1,3 Analogue Pocket Main Board Replacement, Disconnect the main board: 步骤 12 中的图像 2,3 Analogue Pocket Main Board Replacement, Disconnect the main board: 步骤 12 中的图像 3,3
    • Use the tip of a spudger or a clean fingernail to flip up the hinged locking flap on the right speaker cable ZIF connector.
  13. Analogue Pocket Main Board Replacement: 步骤 13 中的图像 1,3 Analogue Pocket Main Board Replacement: 步骤 13 中的图像 2,3 Analogue Pocket Main Board Replacement: 步骤 13 中的图像 3,3
    • Repeat the process to disconnect the left speaker and power/volume button cables from their ZIF connectors.
  14. Analogue Pocket Main Board Replacement, Unfasten the main board: 步骤 14 中的图像 1,2 Analogue Pocket Main Board Replacement, Unfasten the main board: 步骤 14 中的图像 2,2
    • Use a T6 Torx screwdriver to remove the 7.4 mm‑long screw securing the main board.
  15. Analogue Pocket Main Board Replacement, Raise the main board: 步骤 15 中的图像 1,3 Analogue Pocket Main Board Replacement, Raise the main board: 步骤 15 中的图像 2,3 Analogue Pocket Main Board Replacement, Raise the main board: 步骤 15 中的图像 3,3
    • Don't try to fully remove the board—a delicate ribbon cable connects it to the screen.
    • Before lifting the board, double-check that you removed the SD card.
    • Grip the outer edges of the cartridge reader and gently lift the bottom edge of the main board until you can access the screen cable.
    • Keep the main board raised for the next step.
    • During reassembly, make sure none of the three main board cables get stuck under the board when lowering it into place.
  16. Analogue Pocket Main Board Replacement, Disconnect the screen: 步骤 16 中的图像 1,2 Analogue Pocket Main Board Replacement, Disconnect the screen: 步骤 16 中的图像 2,2
    • Be very careful not to scrape off or damage any surface mounted components during this step.
    • Insert the flat end of a spudger under the top right corner of the screen cable press connector.
    • Twist the spudger to disconnect the screen cable.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  17. Analogue Pocket Main Board Replacement, Remove the main board: 步骤 17 中的图像 1,3 Analogue Pocket Main Board Replacement, Remove the main board: 步骤 17 中的图像 2,3 Analogue Pocket Main Board Replacement, Remove the main board: 步骤 17 中的图像 3,3
    • Lift and remove the main board from the front shell.
    • To prevent damaging any surface mounted components, lay the board on your workspace cartridge reader side down.
  18. Analogue Pocket Main Board Replacement, Reassembly information: 步骤 18 中的图像 1,3 Analogue Pocket Main Board Replacement, Reassembly information: 步骤 18 中的图像 2,3 Analogue Pocket Main Board Replacement, Reassembly information: 步骤 18 中的图像 3,3
    • Before installing your new board, make sure it has a thermal pad. If the board doesn't come with a pad, follow this step to transfer the old one.
    • Use the flat end of a spudger to gently lift the thermal pad until you can grab it with your fingers.
    • If the pad breaks, don't worry. Just transfer each piece to the new board.
    • Use your fingers to transfer the pad to the new board.
    • Use the flat end of a spudger to press the edges of the thermal pad until it's centered.
结论
Spencer Day
于09/14/22注册
104,762 声望
创作了740篇指南
团队
iFixit iFixit 的会员
Staff
121 名成员
创作了19,866篇指南
1指南评论
Where can I get a replacement ribbon cable for the shoulder buttons? Looks like I was careless with my handling of it and now my R button no longer works.
James D. - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 36
总计 1,563
