跳转到主内容
Acer Aspire One ZG5 Internal Wireless Card Replacement
Doug Gallatin
Doug Gallatin7 其他贡献者
最后更新于 February 9, 2024
10分钟
中等
更好的介绍
After removing the top case, it is easy to get to the internal wireless card.
你所需要的
工具
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
查看更多...
  1. Acer Aspire One ZG5 Internal Wireless Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the netbook upside down with the battery at the top, facing away from you.
  2. Acer Aspire One ZG5 Internal Wireless Card Replacement: 步骤 2 中的图像 1,1
    • Unlock the battery by sliding the switch located near the left hinge to the left "unlocked" position.
  3. Acer Aspire One ZG5 Internal Wireless Card Replacement: 步骤 3 中的图像 1,1
    • Slide the latch located on the opposite hinge from the lock while pushing the battery up.
  4. Acer Aspire One ZG5 Internal Wireless Card Replacement, Wireless Card: 步骤 4 中的图像 1,1
    • Gently loosen the two Phillips #0 screws in the small panel that covers the wireless card.
    • These screws are built into the panel and aren't meant to be completely removed.
  5. Acer Aspire One ZG5 Internal Wireless Card Replacement: 步骤 5 中的图像 1,1
    • Lift up the panel and remove it from the case.
  6. Acer Aspire One ZG5 Internal Wireless Card Replacement: 步骤 6 中的图像 1,1
    • Disconnect the two antenna cables from the left side of the wireless card.
  7. Acer Aspire One ZG5 Internal Wireless Card Replacement: 步骤 7 中的图像 1,1
    • Remove the single 3.9 mm Phillips #1 screw from the bottom left of the wireless card.
  8. Acer Aspire One ZG5 Internal Wireless Card Replacement: 步骤 8 中的图像 1,1
    • Gently lift up the left side of the wireless card and slide the card out of its socket.
    mi lap NO tiene wireless card
    gustavo cordova - 回复
  9. Acer Aspire One ZG5 Internal Wireless Card Replacement, Keyboard: 步骤 9 中的图像 1,1
    • Turn the netbook over and open the display so that the keyboard is facing you.
  10. Acer Aspire One ZG5 Internal Wireless Card Replacement: 步骤 10 中的图像 1,3 Acer Aspire One ZG5 Internal Wireless Card Replacement: 步骤 10 中的图像 2,3 Acer Aspire One ZG5 Internal Wireless Card Replacement: 步骤 10 中的图像 3,3
    • There are three tabs located on the top of the keyboard.
    • Start with the spudger pointing towards the display and pry up to push each tab off the keyboard.
    • As you move to the next tab, ensure the previous tab doesn't reset itself.
  11. Acer Aspire One ZG5 Internal Wireless Card Replacement: 步骤 11 中的图像 1,2 Acer Aspire One ZG5 Internal Wireless Card Replacement: 步骤 11 中的图像 2,2
    • Lift top of keyboard up. If it doesn't lift easily, there may be tabs on the sides - use the tool to ease them aside and/or shift the keyboard from side to side.
    • There is a short ribbon cable connecting the keyboard to the netbook.
  12. Acer Aspire One ZG5 Internal Wireless Card Replacement: 步骤 12 中的图像 1,2 Acer Aspire One ZG5 Internal Wireless Card Replacement: 步骤 12 中的图像 2,2
    • Disconnect the ribbon by lifting the black plastic hinge and removing the clear blue cable.
    my keyboard ribbon face damaged. how to repair?
    musa musa - 回复
  13. Acer Aspire One ZG5 Internal Wireless Card Replacement, Top Case: 步骤 13 中的图像 1,1
    • Close the display and turn the ZG5 over so that the battery compartment faces away from you.
  14. Acer Aspire One ZG5 Internal Wireless Card Replacement: 步骤 14 中的图像 1,2 Acer Aspire One ZG5 Internal Wireless Card Replacement: 步骤 14 中的图像 2,2
    • Remove three 5.8 mm Phillips #0 screws from the bottom of the case
    • Remove three 3.9 mm Phillips #1 screws from the battery compartment.
    • Remove two 5.8 mm Phillips #0 screws from underneath the feet near the hinges.
  15. Acer Aspire One ZG5 Internal Wireless Card Replacement: 步骤 15 中的图像 1,1
    • Turn the netbook back over and open the display with the keyboard cavity facing you.
  16. Acer Aspire One ZG5 Internal Wireless Card Replacement: 步骤 16 中的图像 1,3 Acer Aspire One ZG5 Internal Wireless Card Replacement: 步骤 16 中的图像 2,3 Acer Aspire One ZG5 Internal Wireless Card Replacement: 步骤 16 中的图像 3,3
    • Flip up the retaining flap on the trackpad ribbon cable ZIF connector.
    • Using the blue tab, pull the trackpad ribbon cable from its socket on the motherboard.
  17. Acer Aspire One ZG5 Internal Wireless Card Replacement: 步骤 17 中的图像 1,2 Acer Aspire One ZG5 Internal Wireless Card Replacement: 步骤 17 中的图像 2,2
    • Remove the five black 4.7 mm Phillips #0 screws from the metal casing.
    • Remove the single silver 4.3 mm Phillips #00 screw from the right side of the metal casing.
  18. Acer Aspire One ZG5 Internal Wireless Card Replacement: 步骤 18 中的图像 1,2 Acer Aspire One ZG5 Internal Wireless Card Replacement: 步骤 18 中的图像 2,2
    • Starting at the red rings along the hinge, insert a spudger or plastic opening tool into the seam between the two halves of the case.
    • Slide the spudger toward the front of the device, releasing the small clips that hold down the top case.
    • Gently lift off the top case.
  19. Acer Aspire One ZG5 Internal Wireless Card Replacement, Internal Wireless Card: 步骤 19 中的图像 1,1
    • Disconnect the two antenna cables from the right side of the wireless card.
  20. Acer Aspire One ZG5 Internal Wireless Card Replacement: 步骤 20 中的图像 1,1
    • Remove the single 3.9 mm Phillips #1 screw from the wireless card.
  21. Acer Aspire One ZG5 Internal Wireless Card Replacement: 步骤 21 中的图像 1,1
    • Gently pull the wireless card to the right and slide it out of its socket.
结论
5等其他人完成本指南。
Doug Gallatin
于10/05/10注册
6,337 声望
创作了10篇指南
团队
Cal Poly, Team 7-49, Amido Fall 2010 Cal Poly, Team 7-49, Amido Fall 2010 的会员
CPSU-AMIDO-F10S7G49
5 名成员
创作了27篇指南
1指南评论
Este modelo tiene dos tarjeta de red? Es que adentro tiene una y esa donde se quita la tapita es otra?
marvoly - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 18
总计 24,750
