跳转到主内容
ANKER SoundCore Charging Port Replacement
Briana Kuo
Briana Kuo2 其他贡献者
最后更新于 May 5, 2020
20分钟
中等
If your ANKER SoundCore does not charge, your charging port may be broken. If you wish to replace your device’s charging port, you can follow this step-by-step guide.
Before attempting to replace anything, it is recommended that you look at this device’s troubleshooting guide.
You will need an iFixit opening tool, Phillips #0 screwdriver, metal spludger, and iFixit opening pick. Soldering experience is needed.
你所需要的
工具
查看更多...
  1. ANKER SoundCore Charging Port Replacement, Charging Port: 步骤 1 中的图像 1,3 ANKER SoundCore Charging Port Replacement, Charging Port: 步骤 1 中的图像 2,3 ANKER SoundCore Charging Port Replacement, Charging Port: 步骤 1 中的图像 3,3
    • Use the plastic opening tool to pry off the screen.
    • Remove the screen from the device.
  2. ANKER SoundCore Charging Port Replacement: 步骤 2 中的图像 1,1
    • Remove the eight 10 mm Phillips #0 screws from the speaker mount.
  3. ANKER SoundCore Charging Port Replacement: 步骤 3 中的图像 1,2 ANKER SoundCore Charging Port Replacement: 步骤 3 中的图像 2,2
    • Use the metal spludger to pry off speaker mount.
  4. ANKER SoundCore Charging Port Replacement: 步骤 4 中的图像 1,1
    • Remove the two 8mm Phillips #0 screws from the circuit board.
  5. ANKER SoundCore Charging Port Replacement: 步骤 5 中的图像 1,2 ANKER SoundCore Charging Port Replacement: 步骤 5 中的图像 2,2
    • Carefully remove the circuit board from the speaker body.
  6. ANKER SoundCore Charging Port Replacement: 步骤 6 中的图像 1,2 ANKER SoundCore Charging Port Replacement: 步骤 6 中的图像 2,2
    • Use the iFixit Opening Pick to pry off the charging port cover.
    • Remove the charging port cover.
  7. ANKER SoundCore Charging Port Replacement: 步骤 7 中的图像 1,2 ANKER SoundCore Charging Port Replacement: 步骤 7 中的图像 2,2
    • Desolder the charging port from the circuit board.
    • Solder a new charging port in place of the old one.
    • For help soldering and desoldering, follow this guide.
结论
3等其他人完成本指南。
Briana Kuo
于02/10/20注册
311 声望
撰写一个指南
团队
Cal Poly, Team S22-G1, Regan Winter 2020 Cal Poly, Team S22-G1, Regan Winter 2020 的会员
CPSU-REGAN-W20S22G1
5 名成员
创作了7篇指南
4指南评论
Where can I find a replacement port that is compatible?
tommy2197 - 回复
Mike - 回复
The Charging port is an USB Mirco Port. To find right part search for JBL FLIP 3 on ebay or other platforms. It is the same part as used for the Anker SoundCore.
Agi -
Hi I have a Anker soundcore motion plus, the charging port is loose and not charging, it's a usb c, where can I buy that replacement part
.thanks
Justin - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 25
过去 30 天: 164
总计 11,789
