超薄版PS3光驱置换
简介
转到步骤 1此指南包含如何拆开PS3并置换新光驱。
如果你光驱无法读盘或者光驱已经损坏,跟随此指南来换掉它。
开始之前,确保你有所需的工具、自由不被打扰的时间和宽敞干净的维修环境,并坚信大力不会出奇迹,只会让你PS3变成你的回忆。
最后,慢慢来并祝你好运。
按压右侧并向左推动可以移除后面板
This tip and photo made me break this panel lmao there's a button top right of the disk tray you're supposed to push that not a "tab on the right side of the device" the mechanism to unlock the panel safely is in the top right of the inside of the disk tray
You cannot really even see the bottom in this photograph but it is clearly visible in step seven please before trying to remove this panel look at step seven to see the button I have described lol
向旁边移开光驱可以看见一颗长度为8.8毫米的银色螺丝
使用十字螺丝刀拧下它
be careful, the fiber-optic cables come out easily and are a pain to put back in
拔出白色的插头
卸下电源组件。(竖直向上提起电源,可能需要一点点力气)
The left side of the PSU sits on two long metal prongs so you may need to pull a little to get it lose but you should be able to pull the whole unit in an upward motion
倒序观看此指南,便可组装回你的设备
倒序观看此指南,便可组装回你的设备
17等其他人完成本指南。
由衷感谢以下译者:
100%
James HJH正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
7 Guide Comments
Hi i have a Question
I change the Optical Drive on my PS 3 Super Slim Named KEM850 PHA KES850 .But the new drive only play DVD not Blueray Game or Movie
An update was made without drive on board connected .can be this the problem. how can i fix them
Please Help
s
I am replacing the optical drive in my console. But didn't note where the drive ribbon was positioned!? Every video I have found, they just pop right in...my original and replacement drives, have larger receptacles than the ribbon it self. There are at least 5 pins, that don't have (potentially) anything connecting them, to the ribbon. I don't want to randomly place the ribbon in one of the possible (7?) positions and fry something in the process...so where do I connect the smaller ribbon?!
Just wanted to add: the HDD bay cover isn't on the right all the time, it varies with each unit. The side without the rubber PS logo is the bay cover.
Yash - 回复
I just wanted to add that the above is not correct either
My PS3 Super Slim Mdel No. CECH-4004A has the removable PS logo rubber seal on the left side while the HDD is housed behind the right side (with no rubber PS logo seal)
Eoin - 回复
My p3 just went off it goes on but then it just shut down
Chadley Abrahams - 回复
