简介
您的手机没有检测到充电线吗? 充电端口是否松动? 麦克风“变聋”了吗? 可能是时候更换Lightning连接器组件了。 使用本指南更换包括手机下部的麦克风,天线电缆和Lightning连接器的Lightning连接器组件。
请注意,此维修需要进行大量拆解工作,并且需要你格外小心和细心。
你所需要的
视频概述
在这个步骤中使用的工具:Tri-point Y000 Screwdriver$5.99
从下侧连接器支架上拆下以下长度的四颗三点式 Y000 螺丝 :
三个1.2mm螺丝
一个2.4 mm螺丝
维修过程中,使用磁性垫来记住每颗螺丝所对应的位置,避免重新安装的过程中螺丝安装错位损伤您的手机。
These screws just spin for me. They don't back out, but the heads aren't stripped either. I've tried applying backpressure to help lift the screws, but no luck
Jeff Hurst - 回复
What driver do I need to remove these screws i’m stuck
i cant use, the Y000 it isnt working.
What if I stripped a screw what do I do??
Yep, only the 2.4mm came out, other 3 won’t budge, and worried I’ve stripped the heads. Anyone got any ideas?
It’s the screwdriver bit that is the problem. I had the same issue with 2 Y000 bits not grabbing the screw properly. I fixed it by using a small 3 sided file to slightly grind the groves in the Y000 bit just a bit deeper. Then the bit worked like a charm on these screws.
Use Y000 on all 4. U have to be very sensitive on the 1.2mm screws. Put the bit in the screw, put the left pointing finger on top of the screwdriver and turn the driver carefully to the right until you feel a “bump”, thats the trick :-), then you are able to screw the screw out.
For me the key here was a LOT of downward pressure to ensure the Y000 bit caught in the screw. Not sure i can describe how much exactly, but is was significant. Otherwise the bit would not catch.
What do I do if I Stripped one of them?
Can’t get them removed what to do ?
Managed to get the central one out. The upper one won't move, the lower one I've popped out with some force. This allows you to rotate the cover enough to unplug the various bits. Not ideal, but works. I've tried applying a lot of pressure, using the tighten/ loosen method, but the heads have just got mashed… no wonder Samsung are now No1, sigh…
You need to be careful when just rotating the cover as you can accidentally slice through the two black antennas! You only need to nip them…As you can tell I have done this in the past :/
Filing down the bit worked for me. The tip about putting an index finger on the end of the screwdriver handles and then turning gently until it clicks into place was very helpful! Using these 2 tips I didn't need much downward pressure. Screws are out in a few turns.
Mine came out easily. I placed the screws in the area where the bit goes in my kit so I can keep track.
I use a 28 day pill box and keep every screw separate and reburn to exact slot because they all vary in length, width and can really damage u phone if too long and nt secure if to small. use a magnetised screwdriver, or make the cheap freebees magnetic for a short period by rubbing it up an a magnet. lol
Absolutely ridiculous had to go get a different one just stupid
Was able to get the outer bracket screws out using fine needle nose pliers 90 degrees straight down for the outer ones by pressing down a little and using medium gripping force. Had to take these out first before i could use tweezers on the middle one, for which I had to use tweezers to hold the screw, then rotating the bracket (not the screw) counter clockwise a few mm many times over to slowly unscrew it 1/32th of a turn at a time, repeat. (this loosened middle screw). Think ‘rotating bracket 3minutes/degrees counterclockwise at a time while holding screw in place.) You are gonna need really small/fine pliers and tweezers for this because the heads are countersunk into the bracket.
To help tell if the screw is turning, put a small dot from a marker on the head of the screws. This helped me to know I wasn't just stripping the head.
try heating the iPhone with a hairdryer or a bag of rice or about 60 degrees in an oven for 3 minutes . It has worked for me. If the screws don’t come out while hot the will come out as the iPhone cools.
卸下下侧连接器支架。
my battery cable connector was stuck to the bottom of this metal bracket plate so be careful when you lift it off
This may have been intentionally done by Apple to make sure the battery gets disconnected before any other connector is disconnected. So always make sure to disconnect the battery before disconnecting and reconnecting the connectors for the display.
So…I forgot to put this bracket back on when reassembling. Now I’ve adhered the display to the case and don’t have another adhesive strip…so I’m wondering: what purpose does this bracket serve? The phone is powering on and seems to work okay.
Am I going to run into trouble with this bracket missing?
Well, that didn’t last long. The phone shuts down without warning. So I guess that plate is important…
I also forgot to put the battery shield in, and adhered the display. I’m tempted to leave it like that. However, your negative experience is a good data point telling me to not be cheap.
Ordered a new adhesive , under $2 shipped from eBay.
Thanks, Josh Martin! Mine was stuck too, so I lifted carefully.
使用撬棒尖端将电池连接器从逻辑主板上的插座中翘起。
Was kann passieren wenn man diesses Kabel vergessen hat zu entfernen `?
Reconnecting the battery poorly can cause the iPhone to appear to be properly powered and functional, but then suffer a reboot loop.
I had difficulty after a screen replacement, and the Console app on my Mac showed that the ‘thermalmonitord’ process was throwing lots of errors from not getting any sensor readings from the battery. It would never charge past 1% and just kept rebooting.
The contacts on this conector looked fine so even though I had reseated this connector several times already, I reconnected it very firmly using my thumb and a spudger to really press all the corners and middle and really gave it a good massage and then finally it showed the normal dead battery screen and started properly charging and eventually booted back up to normal functionality.
It seems the battery has to be able to transmit data to the phone to say it’s not overheating or iOS will not allow any current into the battery to recharge it, and the kernel will panic from the null readings and just reboot over and over again.
In my case, the battery connector was attached to the bracket. We just left it connected bracket when we pryed it up.
Reconnecting the battery connector was a bit difficult in my case. The cable that comes out of the battery was a tiny bit too long, or that I placed the battery a bit too high (i.e., too close to the top of the phone). It took me several frustrating minutes of fiddling with the connector for it to sit right into the socket. I was not sure if that was connected correctly but, alas, the phone came back to life when it was turned back on.
VERY IMPORTANT NOTE: Please READ the reply here by jason.
It is very easy to knock off or nudge the little pins near the battery socket, see https://guide-images.cdn.ifixit.com/igi/... and https://guide-images.cdn.ifixit.com/igi/....
Those pins are the data lines to extract battery info: temperature, charge, etc. If you accidentally nudge/knock off them the phone could appear to work normally, even for a few days. But then you will start getting wrong battery reads and then after that it may suffer a reboot loop. If you enter settings > privacy > analytics & improvements and you scroll down you will find panic errors from thermalmonitord that there are missing sensors (TG0B or TGXXX) and you will have to micro solder them. DO NOT NUDGE THEM and double check the socket connector when reconnecting the battery.
after installing new ifixit battery kit, note the foam on the new battery is thicker than old apple one, managed to remove the old foam and swap to new battery connector, sheild plate now level
Neil Mills - 回复
使用撬棒或者指甲来将两条显示排线从逻辑板上的插座中撬出。
To be honest you don’t really need to disconnect the display cables in step 15 or 16 to get the battery out. Just keep the suction cup on the screen to keep it propped up and to give the cables some slack. The only reason to take these cables off is that it’s a pain to apply the replacement display adhesive with those cables in the way. If you’re not re-waterproofing your phone just leave these attached.
minimalist - 回复
MAKE SURE you hold the top screen when dislodging the cable connections. I let the screen lie flat down and ended up tearing one of the cable connections, now my touch ID does not work at all! I’m going to have to order a whole new screen.
Don’t miss that SECOND CONNECTOR like I did. It will break very easily if not disconnected :(
I replaced the screen and have ended up with a blank screen. Touch control seem to work (touch button works and I can shut down the phone by pressing power button for some seconds and then swipe left to right in the upper part of the screen). But the screen is blank. I’ve tried to disconnect and connect the two connectors in step 16 but with the same result (blank screen). What do I need to do?
Thanks for advice!
this point is the most important in the whole manual.
Please pay attention not to strain the flex cables or they will end up breaking
I should have been more careful - the second cable tore off.
My own fault after having done this replacement about four times previously without any issues, I clearly got cocky and didn’t pay enough attention.
Be VERY CAREFUL and remember to unplug those cables. Don’t skip steps.
I’ve now had to order a replacement screen.
If you replace the screen and there is no display apply io propyl alcohol 99.9 & purse to both connectors on the screen and on the iPhone with a clean toothbrush and let them dry for 45 minutes and then fit the screen and reassemble the iPhone..
It works for me . when I get a new screen I do t5his before fitting it.
I tried to save time by not removing the screen during battery replacement as some comment here, HOWEVER, I ended up having to use a little force to remove the battery and in the process broke the second, lower smaller cable, resulting in loss of home button function and needing to get a new screen. Next time I will follow these steps and completely remove the screen during a battery replacement
chrislacey - 回复
I removed the screen and cable still got ripped during reassembling :(
Viktoria -
There is a critical fact missing from the steps here, for reassembly: That bottom (underlying) cable is longer than it should be. Loads of people are reporting that the Home button is dead after this repair, but the cables aren't torn. I'm pretty sure this is why. Here is a picture of the problem.
When reassembling the phone, you must poke this cable back into the body of the phone while you bring the halves together, or you will crush, crimp, and destroy the cable.
I’m only reading your very useful comment now, after the exact thing happened to me and my cable got ripped during reassembling phone. Would you be able helping me naming this part, so I can look for a new one? Thank you very much!
Viktoria -
thanks gavin. ifixit should have included this piece of info.
拧下将支架固定在前面板传感器组合件连接器上的两颗1.3毫米Phillips#000螺丝。
有些电话可能是Y000。苹果在产品生命周期的某个阶段开始将Y000用于这些产品。
Has anyone had trouble getting these two screws off? I’ve been working on these for about 10 minutes and the LEFT screw wont spin. It seems like the little PH000 screwdriver bit won’t even grip it. (The one of the right comes off, no problem)
It looks like I’ll have to pick this project up again with a screwdriver that will actually take off this piece.
If you’re having trouble removing these screws;
the screw on the right goes into a standoff screw that is screwed into the frame.The left one goes into the logicboard.
If your phone is used most likely it has been repaired in the past and the person that repaired it put the screws in way too tight.
If your phone is brand new And you know 100% it is then the problem is your screwdriver.Stop before you strip it completely and buy a better screwdriver (EBAY).
If you already stripped the screw head take the phone to a shop before you break it.
there are ways to get them out but truthfully it’s extremely dangerous and sometimes your better off quitting while you are ahead.
I used a #1 flat head tip to loosen.
I couldn’t get the two screws out either—used the correct screw tip and everything. Stripped the screw. Will now attempt to just keep the cable attached…..
Use the PH000 and apply a little more force before spinning, should come right out!
^To anyone having trouble, this is the correct answer. Put the phone on a firm surface, align your driver carefully, press down hard, and twist. As long as your driver is approximately the right size, it’ll come out.
the two screw i have are stripped and i have n way of getting either screws off whats my next bet
The PH000 bit is to large. I can’t get the screws out either which really sucks…now I have to put everything back together, find another bit that will work and try this again another day. Not impressed with IFIXIT’s attention to detail so far :-(
Using iFixit’s driver kit, I prefer a PH00 for this, which is larger than the PH000. If you think the PH000 is too big, something is wrong.
I think part of the issue with the iFixit PH000 is that it is slightly too pointy. The PH00 fits better because the splines engage the slots of the screw before the point bottoms out. The PH000 tip bottoms out in the screw’s center point and the splines don’t engage as well. I have other PH000 tips that are more blunt nose and they work better than the iFixit bit.
PH000 screwdriver didn’t work for any of these screws, or the barometric vent, or the taptic engine. It was too big. I had to use a different screwdriver from another kit I had.
minimalist - 回复
the cable tore. is that it i need a new phone?
You don’t need a new phone, but your selfie camera and phone speaker will not work. You can get replacements for that about $10.
jack jones - 回复
Reconnecting this cable and coverplate took a good 20 minutes. O_O
I also had issues to loosen up the screws, in two parts the right side up and the left side down, i think the PH000 is to pointy or something or its too hard for the srews of the iphone, i cannot take it off and know im regreting i bought i order all the way from Paraguay in south america and know so angry it doesnt work
I skipped this step. Just be really careful not to pull on the screen.
The guide says they changed these to the Y000 “at some point in the t middle of the product’s lifecycle”…
That can’t be true, I have a *day one*, preordered iPhone 7, and mine had, unmistakably, Y000 screws!
and also, I’m just faithfully following the guide here, but can anyone clarify *why* is is necessary to entirely remove the display AND the Taptic Engine at all? The battery seems accessible just fine… oh well
PS- I’m doing this on an older backup iPhone 7. My iPhone 12 Pro just went berserk and stopped working completely a little over a year after I got it day one of its release… since the iPhone X I’ve only had easily breakable, overly sensitive phones. I’ve had every numbered iPhone except for the 8 (I got the X released at the same date) and the 11, and man, are these newer iPhones post X fragile!
从主板的插座上断开前面板传感器组件排线插头。
Das ist sehr mutig, das Kabel dort so zu strapazieren.
Mich würde das Display daneben stellen und mit irgendetwas stützen, dass es nicht umkippen kann um Beschädigungen an dem Kabel zu vermeiden. Das reißt sehr schnell ein.
Is this the connector for the earpiece, as well? I did the screen replacement and everything worked, except now I can’t use my earpiece… I’m afraid I didn’t fully connect this particular portion.
Victor Bui - 回复
@victorbui714 Correct, this is also the connector for the earpiece speaker. Check the flex cable carefully and make sure it wasn’t pinched or torn. Make sure the connector socket is clean (give it a blast with some compressed air if needed) and try reseating it. If that doesn’t help, you may want to remove the earpiece speaker and inspect the four springs on the back, and check that they’re intact and making good contact with the four circular pads on the flex cable. Give the pads a wipe with some IPA and try not to leave any skin oils on them. If none of that works, try replacing the entire flex cable/sensor assembly. Good luck!
This is the only connector that is quite easily possible to put back in the wrong way. If you do so, the phone will just get into a continuous loop where it shows the boot screen, goes blank and then shows the boot screen again and again. If this happens, do not despair-just put it back in the right way.
Roy Mathew - 回复
After putting together, I had a continuous loop boot up (as noted above). I saw articles where this (front panel sensor connection) was the reason. I disconnected this connection and the boot up loop stopped. I tried reconnecting several times but had the same problem (boot up loop). However, it turns out that I needed to apply extra pressure when installing until a heard a (faint) second click when pressing down. Note - before I was using the spudger to press the connection together, which didn’t do the job. I ended up using my finger to press harder to get it to click in. Solved that issue.
The ribbon cable on this step is torn. Is this something that can be replaced? Is this only to the earpiece?
John Daily - 回复
移除显示屏部件。
When removing the screen, be aware of the two tiny square black rubber grommets on the Penelope screw brackets that secure the screen. They can fall off very easily and be lost without even knowing it (it happened to me, but was lucky enough to find them).
Guy Cooley - 回复
Sorry, I’m so unclear about when to replace the Adhesive tape. Should I put the iPhone 7 Display Assembly Adhesive at this step, or after I’ve replaced the battery?
Victor Bui - 回复
@victorbui714 Battery first, then adhesive during reassembly, as it says in the instructions. ;)
This is the 3rd screen iv put in my phone and everyone them bust at the top by the camera every time iv bought one of these screen idk if it’s the manufactures fault or what?
trent bost - 回复
@trentb28922 Ouch! That’s not normal. Is your phone’s frame bent? Are you having to use a lot of force when you install the display?
If the instructions are followed step by step, then adding the adhesive comes before changing the battery.
If I had to do it all over again, I'd skip adding the adhesive, because you have to disconnect the battery, plus the two lower display connecters and the front panel sensor assembly connector. It was a nightmare trying to marry the components back together without disturbing the wire prongs, and I don't even want to talk about reinserting the tiny screws that kept twirling around on the tip of the screwdriver as well. It wasn't worth the time or aggravation!!
If you decide to skip this step, just avoid using your iPhone near water.
卸下两颗将气压计固定到后壳的1.9mm P000 十字螺丝。
I didn't see the necessity, so I didn't remove the Barometric Vent since I decided I wasn't going to uplug the Taptic Engine, although I did remove screws for the Taptic Engine, but I didn't unplug it. I believe the point of removing the Taptic Engine is to gain access and space to pull the adhesive strips off the battery. If you attempt and are able to remove the adhesive off the battery, then I believe it's NOT necessary to remove the Barometric Vent nor the Taptic Engine.
使用撬棒(Spudger)的平端从主板的插座上断开Taptic Engine的连接器。
卸下三颗将Taptic Engine固定到后壳的 1.6mm P000十字螺丝。
My screws are stripped here. Please help, I don’t know what to do!
Hey Salva and Kyle, sorry to hear about all these stripped screws! For help with removing them, check out our guide.
I had my 7 battery replaced by an Apple Authorized dealer. Around 2 weeks after the taptic engine started to make a !&&* of a noise when it was activated (sounded as if it was loose)… then 1 month after that… it stopped working completely. fast forward 8-9 months later, the battery they had replaced just wasn’t holding its charge anymore (phone was spending more time plugged in charging and depleting very quickly = full charge lasted about 1-2 hours). Having bought the ifixit battery and have gotten as far as this step, I could see that all three of the 1.6mm screws were just floating around in the compartment and the taptic engine was just being held on via it’s ribbon lead. WTF?! Screws aren’t stripped and I managed to fix it in again. Why would these screws be floating around like this??
another person checking in here to assure you that, if you find a stripped screw (or more) at this step, you’re not crazy. I have one as well! I’m in dis-effing-belief. This phone has NEVER been serviced by anyone, and was allegedly brand new when purchased.
To the person suggesting a dremel tool to remedy this…. *blink**Blink*. Are you kidding me right now? *slap*. Vibrating the !&&* out of all those sensitive parts - not to mention what one slip could end in your phone being effectively sawed in half.
使用撬棒的尖端挑开连接在主板上的天线线缆插头。
Hey may i ask…what is the use of both of the antenna cables?i just opened my iphone 7 plus and i found both of the cables are broken.if both of the cables are broken,what does it effect on my iphone?
Speaker and antenna?
Keah Smith - 回复
I'm missing the black thing from my antenna and I have no signal, could this be the reason why? Is the black thing insulation?
Keah Smith - 回复
I am having the worst time imaginable trying to reconnect the antenna cable coming from the lightening connector assembly to the logic board. It’s barely long enough and will not snap into place. There’s a minature gold pin sticking up from a circular gold ring on the logic board and I must have spent an hour on this one step. The antenna end has the female end. Everything else went well. The antenna connector from the old lightening assembly will connect relatively quickly. I’m beginning to think the new antenna connector female end might be defective. I’m ready to cut the black antenna wire and try to solder in a longer piece using the old connector assembly. Any ideas? HELP !!!
These can be tricky to reconnect. I found the best way is to hold the connector with tweezers and use the point of a spudger on top of the connector in the other hand. Slowly moving the connector with the tweezers while applying gentle pressure with the spudger, you will eventually feel the connector and its seat line up and you can snap into place. Don’t force it, when it is lined up it is easy so you have to patiently work on aligning it.
please say which antenna is which, impossible to know now
Tip that helped me: remove the standoff screw next to the clip before derouting (or, upon reassembly, rerouting) the cables. This gives you a lot more space to work with! (Note: I only did this on reassembly, so I don’t know if there are any gotchas on disassembly.)
T Murrills - 回复
用镊子从扬声器上的金属扣上拆下天线电缆。
This was an oddly challenging step, lifting the speaker slightly from the top end allowed me to slide the tips of one side of the tweezers in between the cable and the speaker, prying it out rather than grabbing and pulling which feels dangerous.
They break very easily
Josh Brito - 回复
One cable seems to stay attached to the speaker. Don’t try to pry it off the speaker! This is shown in the video but not in these photos.
去除扬声器组件。
Reassembly tip: after aligning the speaker with the bottom edge, instead of lowering the speaker into place, keep the speaker raised slightly and push the cables back into the clip (which were removed in step 28) with the flat end of a spudger. In doing so, though, make sure that the cable from the lightning connector piece remains above the flat metal piece protruding out the left side of the speaker.
T Murrills - 回复
将SIM卡弹出工具或回形针插入SIM卡托盘的小孔中。
将工具向里按压(捅)以弹出托盘。
从手机上卸下SIM卡托。
Received a sim card tray from IFIXIT for my iphone 7. I can’t seem to get it to close flush no matter how hard I try. Any suggestions?
AJ Dereume - 回复
Why would it require a significant amount of force? Is it because the iPhone 7 is water resistant? When I removed my tray it was like it was stuck in goop inside the phone and the tray had a glue like sticky substance on it? It did not ‘click’ back in smoothly like my other iPhones, I had to push it against the ‘goop’. Is this normal for iPhone 7??
I used the tip of the super pointy tweezers, and it worked well.
使用撬棒的尖端撬起并断开后摄像头模块左侧的天线总线连接器。
There is one Step missing before removing the flash light cable: Remove Camera cable, right?
I broke this and can’t find it on amazon. Is it part of the volume control flash connector? If not, can you send me a link on where to find this connector,…and possible instructions on how to replace?
卸下2颗固定上部线缆支架的 1.2mm Y000 三点螺丝。
these are too tight cant get rid off them from y000
Had to push down to get the Y000 in place
使用撬棒的平端断开上部线缆的连接器。
拧下用于固定Wi-Fi天线的四颗十字螺丝:
三颗1.2mm螺丝
一颗1.7mm螺丝
I lost one of these 1.2 mm screws. Will that affect the signal reception?
How do you open the 1.7mm screw? LOL
Yes : 4 screws and not 3 !!
卸下以下两种 P000 十字螺丝:
一颗1.3mm螺丝
一颗2.2mm螺丝
在这个步骤中使用的工具:Standoff Screwdriver for iPhones$5.49
从接地支架上卸下2.2毫米的定位螺丝。
What bit is this? The link doesn’t use the same name.
Mike Moran - 回复
I hate getting the deep into a repair to find there’s a tool missing. This bit should be part of the toolkit!
Its in the toolkit now. Looks like a Philips head but up close the end is squared off with a point in the middle.
I received two boxes - one box contained the repair part, the other was the tool kit. I only opened the tool kit before disassembling the phone. The standoff screwdriver bit was not in there. Neither was the guitar pick. I used a real guitar pick and a small standard screwdriver from my toolbox. When I was ready to reassemble, I opened the repair part box and guess what was in there - the standoff screwdriver bit and guitar pick. So, I guess if you just order the part it will come with (at least) those two tools. The tool kit contains tweezers, suction cup, three screwdriver bits (tri-point, pentalobe, and phillips) and screwdriver handle, a long black spudger with a flat end and a pointy end, and a smaller, thicker spudger with a wide, flat ends.
The flat end of the spudger works a treat too.
Thank you, bronyar. Since there is a box labeled “Repair Tools”, I never would have looked in the parts box for tools. I was able to use the standoff tool to takie the phone apart, not just to put it back together.
使用镊子轻轻地弯曲分离主板边缘支架。
I accidentally broke the grounding bracket, is it very important to get a new one to replace? as I can't seem to find them for sale anywhere
I also broke it. Did your phone work after?
Did you find a replacement?
Ben Schorr - 回复
Did your phone work ?
Emin -
I broke mine while doing this step. A bit confusing. You’re just supposed to bend it out the way, not pull on it entirely. Will the phone still work without this?
I just didnt bend this one.. Ill tell you how it went
使用撬棒的尖端断开下部排线插头。
This is ‘hinged’ on the battery side.
卸下以下两种螺丝:
一颗 1.4mm 十字螺丝
三颗 2.2mm 子母螺丝
简单说来,一个小的平头螺丝刀可以做到——但是需要额外的小心,来保证不损坏周围的部件。
The lowest standoff screw is different than others, so be careful when reinstaling them
使用撬棒的平端轻轻地撬起主板末端的电池连接器
Assurez-vous à cette étape (au moment du remontage) que le connecteur de l'antenne (que vous voyez à l’étape 35) est bien par dessus votre carte mère et qu’l n’est pas passé dessous !!!
向上撬起电池连接器主板的末端并向上拉以从后壳卸下。
Remember to remove the SIM card eject plunger (see step 47) or you may loose it seeing as there is no longer anything to stop it dropping out.
Reassembly note:
Peel up a couple centimeters of the lightening port and plug it in to the logic board *before* seating the logic board. Doing this, you can perfectly line up the connector and hold it to the board as you jimmy everything in to place. This makes the hardest part of the job a no-brainer.
从 Lightning 接口上卸下 2.9mm P000十字螺丝。
Haven’t had any issues with any of the screws so far. Nothing stuck or even threatening to strip. Could it be that people are using the wrong driver bit and getting into trouble that way? You regularly have to swap between tri and normal 4 blade Phillips heads, best to double check each time.
从Lightning连接器上卸下弹性触点。
移除两个覆盖在螺丝上的贴纸。该螺丝将 Lightning 接口固定在后壳底部。
This step makes the whole guide invaluable! Those sneaky devils hide the screws perfectly!
I just ripped one.Never did a regular 7 thee only iPhone I’ve never done.Im pissd.Not sure if I should just pull another from a good phone or hook it up and see if it still works it looks like there grounding screws smh it’s only because for 2 years I had a used 7 housing I always bump into when going through my parts and whoever had that before me also ripped it but in both spots.So when the charge port wouldn’t come up I broke it smh
从后壳卸下两颗 1.3mm P000十字螺丝。
What are these connectors 4? I noticed a tiny chip next to the one on the right if you're looking at the phone face-to-face and on the backside of the charging port is some heavy circuitry for the left side... If the one on the right is broken what can a person expect their phone to do differently? Is this connector on the right hand side of the charging port attributed to anything specifically? Will my phone operate as normal without this?
It should be noted that these two 1.3 mm Phillips screws are different from the other 1.3 mm Philips screws removed in steps 16, 25, 33, and 41. All those screws are identical, but these two have a slightly wider shank so they won’t fit in the others’ bores.
I'm not able to remove these screws with the screwdriver Phillips that was used throughout the rest of this repair. How do I remove them safely?
使用撬棒的尖端从后壳底部分开两个麦克风。
When reassembling, the right microphone (the one on the left in the above picture) has a metal back that has two alignment tabs. One is on the bottom left, and if you just try to push the microphone down into position it will be held up by the tab. The tab is black plastic and not real apparent unless you have some decent light on it.
Everything popped out when I disassembled mine. I was able to get the spacers apart after the lightning connector was out. My kit came with new ones, but I just used the old ones. As the above comment states, there are alignment tabs on each one that are hard to see. Be sure to use the adhesive strips that come in the kit.
May I suggest not bothering to separate the microphone , and thus avoid dmage, ..juts release the rectangular foam as a complete assembly, its just stuck to the bottom of the case each side. less risky than trying to prize off the micro phones.
issues so far
Ive had one small glitch so far …one the anntenas, the one nearest the battery, came off its base. Im hoping to just reconnect to base to make a contact and secure after with a spot of glue each side…
This step was surprisingly hard - the plastic guitar pick was a bit finer and made it easier. Perhaps some heating helped as well?
I agree with Andrew - just taken the foam bits out and either replace with the new ones that come with the kit or swap over. My tip would be don’t reinsert them until you’ve got the lightning connector in place when reversing steps, as they get caught otherwise.
继续在 Lightning 接口排线下方滑动撬片。
滑过电池后停止。
移除 Lightning 接口总成。
使用撬棒将任何残留在后壳上的粘胶清理干净。
确保将 Lightning 接口排线上的两个圆孔对准后壳上的两个小白点。如果没对准的话,排线会错位,插头将无法重新对准连接到主板的插座上。
I'd go so far as to say line the holes up first before you secure the rest of that part. There is no room for error here!
Totally agree, it is absolutely paramount that it has to be perfect, as my three attempts at re-assembly can attest to!
It would be nice to have tips for the best way to actually apply the adheasives on the lightning assembly to beat maintain proper positioning. Otherwise, great guide!
So.. my new lightning assembly had a yellow piece of plastic over the right microphone. Wasn’t sure if it was blocking the opening, so I removed it. Found a small hole in the plastic. Anyone else get one like that?
doubt it will affect it’s function, and since the old one was bad…. can’t be worse than it was before.
i’ll double back once it’s back together.
Plastic liners—yellow or otherwise—should definitely be peeled off and discarded before installing any new parts. You done good. ;)
The gasket is a pain. I’m not even convinced I did it right. The guide stops here and lets you figure out the installation on your own. You can screw yourself if the new connector isn’t placed just right as the connector won’t align. Use the old adhesive areas as guides. I had to take my new part out and install it a second time to get the cable connected. I imagine the usual error is it is too high. The connector ribbon should bend down toward the case just above the connector. Seriously, millimeters count here.
It would be good to have some additional steps explaining how to install the Speaker and Microphone Mesh Set that comes with the kit. I did appreciate that it was included but it took some fiddling around (and almost ruining the seals) before I figured out where the parts needed to go and still I ended up with 2 tiny black gaskets, that looked similar to the microphone gakets, that I couldn’t place and ended up not using. If they were important, I’ll find out soon I guess :D.
all this is great and all, but how do I reinstall all the stuff I took out of the phone. Am I seposed to scroll backward step for step from 64 to 1?
Amazing guide thanks so much! It would be great to show how to reattach the new lightning connector including the mesh bits etc as this is very hard to work backwards through particularly as it looks a bit different to the original
E muito demorado, mas pelo guia da para fazer direitinho.
Waste of two days, the new lightning connector was not recognized by the phone - it did not charge, but the speakers and mic worked fine. I then took it apart again and made sure everything was installed correctly.
Only now, the touch screen no longer works.
So I am back where I was was with a brick.
Awesome guide - my iphone 7 is like new again. BUT reassembly is definitely not simply disassembly in reverse. I found it very necessary to first connect the new lightning connector assembly to the logic board (Step 49) and then place and attach the logic board (Step 50) with the new assembly underneath before sticking the lightning connector assembly into place. If you first adhere the lightning connector assembly, there is zero chance that the logic board connector will be in the right place for connection to the logic board, which is screwed into place and has no freedom of movement. Also reassembly is twice as hard and takes much longer than disassembly.
Followed this great tutorial today to replace the lightning connector (my microphone was greyed and disabled) and installed a new battery as well. Fantastic guide and everything installed and fit well. However, there are 2 issues:
1. Microphone is still disabled so can;t talk to anyone. Bluetooth works fine for calls though. So maybe that replacement was a waste of sorts.
2. Now I get the error that my Touch ID is not activated and greyed out. Can't use the Home button. Is this something Apple/iOS does if you install a 3rd party battery and lightning connector?
要重新组装设备,请按照相反的顺序进行操作。 不要忘记在重新安装显示器之前 重新涂抹显示器粘合剂。
将您的电子垃圾带到R2或e-Stewards认证的回收商。
维修没有按计划进行吗? 尝试一些基本的疑难解答操作,或者向我们的[https://www.ifixit.com/Answers/Device/iP...|iPhone 7 问答社区 寻求故障排除帮助。
273等其他人完成本指南。
由衷感谢以下译者:
91%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
53条评论
The old ones were so easy! Why did Apple have to put the thing under the board!!!???
Prob to discourage people from replacing it themselves instead of sending to apple
I dunno. It was a pain, but surprisingly I got mine fixed. When I took it to the apple store they flat out told me that they wouldn’t fix it at all. I couldn’t even send it in to them. Something about no communication with the logic board and they refused to touch it. Thankfully the guides are detailed enough for goofs like me to be successful.
Ho un problema dopo aver installato il nuovo connettore. Quando l’iphone e scarico, inserendo il cavo, appare sul display il simbolo batteria. Una volta acceso il cavo non viene più segnalato e la ricarica non continua. Cosa può essere?
Salve ho lo stesso problema,qual è il problema?
Can I use this one for the Iphone 8 too ? I havent found one for the Iphone 8.
@manulkamul Not sure if you mean the guide or the part, but in both cases the answer is, unfortunately, no—the 8 is a different animal.
broke the logic board grounding bracket on step44.. any way to replace the whole thing or fix it? the end part what you have to lift came off. thanks!!
I followed this guide and the microphone is still not working. Is it possible I have a bad part?
This is not my first technology fix, although first through here, and first iPhone 7.
Great guide, thanks for posting. Successfully changed out my lightning connector/microphone assembly.
Separate issue, the replacement part charging and microphone functions work OK, but taptic engine no longer works. (cheap eBay purchase),
Small trade off to actually be able to talk on phone calls now.
Thanks again!
Replaced it and now the charging port and mic don’t appear to be working. However, WiFi is working. Go figure. Any suggestions?
Same problem
hi there! first of all i want to say thank you, i do all my repairs through you guys, it truly helps! however, i do have an issue. after replacing the port and re assembled, my phone says unable to activate cause it needs an update, i restored it through itunes and it said unable to update because the update information could not be obtained. Im now sure if this was a problem before i replaced the port or not cause the iphone was not working. any information would be great! thanks so much!
I have an iPhone 7 and a 7 plus, does anyone know if it would be possible to take the connector from my 7 and put it into my 7 plus? I don’t want to start the process just to find out it doesn’t fit or something like it’s too small for the 7 plus?
Hi Mekai,
The parts are slightly different, and the iPhone 7 connector will most likely be too small to fit in your 7 plus. Here are some product links (with pictures) for the iPhone 7 and iPhone 7 Plus assemblies.
Hello Mr.Harvard,
I recently replaced a lightning assembly on a iphone 7 plus and although I didn't feel to have run into any incidents, when I finished assembling everything, my phone stayed on “searching" for a good while and than just stayed saying ,”no service" when in fact it had no connection issues before the lightning port was replaced. What can I try to do to resolve this?
Hello Amador,
It sounds like an antenna issue. Make sure the antenna cables are properly connected in Step 26. Also check to make sure all connectors are seated.
Arthur,
Thank you very much for the response. After more troubleshooting, I was able to determine that the replacement batch I received of lightning port replacements was the issue. Once I used a part from a different batch, the network issues were resolved. Thank you!
hi, after performing the procedure when the phone is switched on, it remains stuck on the apple. I thought it was a problem of the replacement taken on ebay, so I reassembled the old connector but does the same thing! Help me
This is probs because there is a connector not connectie properly, I had the same problem. When I made sure I connector everything properly it worked again. There is a chance the connector on the logicboard is broken.
Your guide was thorough and got me through the difficult process of replacing an IPhone 7 charging port. I used labeled ziplock baggies for each step; attempting this complicated of a repair without labeled baggies would not have ended well. The whole effort took me about 4 hours, but the phone is back from the junk pile and works perfectly!
Jim Taksum - 回复
Dopo aver rimontato tutto su un iPhone 7 tutto funziona perfettamente ma il telefono nn riesce ad agganciare la rete dal info generali riesce cmq a darmi tutte le info incluso IMEI e operatore della SIM a questo punto può essere il componente sostituito difettoso o devo pensare alla scheda madre guasta?
for all who’ve done these repairs, we have to All Hate & Love Apple at the same time, Hate because they do this $@$* on purpose just to be dicks, and love because they keep us in business. Sometimes I think I’d rather not be in business just because it makes people have to pay for something that can be made to be an easy fix for people… This is ALL Steve Jobs Fault Visionary and Dick to boot oh and pirate not the good kind.
Awesome guide as usual from ifixit .. Love you guys :)
Ok… so this guide is incomplete based on the repair kit I purchased. There is a bag of seals that comes with the lightning connector assembly, and most are not show in the instructions.
I’m trying to figure out where they all go…. and I’ll try and update this as I do.
@land08033 If you’re referring to these, it looks like they were added to the kit more recently, after the guide was published. None of them are necessary for the iPhone to function, but if installed correctly they may help maintain a higher level of dust and/or water resistance after the repair. Thanks for your comment!
Spot on
Great guide! This task is difficult but doable if you are careful and patient.
Thanks for the great write up, my phone is working again now!
Bonjour,
J’ai bien suivi le tutoriel et mon soucis est que quand le iPhone est en charge, je peux prendre une petite châtaigne électrique en touchant légère ment le iPhone.
D’ou pourrais venir ce problème de terre ?
Merci
my connector seems too short to connect to connect to the reciever. as seen on step 45. Ive tried to slide the board but it doesnt seem to help.
cooldudefj - 回复
First iPhone repair. Excellent instructions! Took me about 2 hours and everything works great!
Jacob Seay - 回复
Phew, took a while to do this, and I am pretty sure I did it correctly, but the phone is now stuck on the apple screen… any ideas?
Hey James,
Try these basic troubleshooting steps, and see if that would do it. If that doesn’t work out, please post a question on our iPhone 7 Answers forum.
What does new antenna connect to, the on that comes from charger connector
It looks like it should connect to the antenna connectors here. I can’t tell for sure which one it is supposed to connect to—there are two antenna cables. It looks as though one cable has one silver grounding clip, and another has two. Whichever has one silver grounding clip should connect to the top connector (closer to the top of the phone).
Perfect!! only had trouble finding the right place for all the new patches in the bottom, thanks!!
Followed the detailed instructions. Did the battery at the same time. Worked like a champ! Thx.
It’s the first time I have used ifixit to repair a phone. The steps were very clear and my phone even worked when I was finished! I was repairing a faulty microphone.
Thank you very much.
when I reassemble the two antennas, should the speaker one be put in the hole above or in the hole below?
Hi, I had my charging port replaced and the tech reprogrammed my phone (he said he needed to to make the phone work). I’m super stressed bc I lost photos from my dad’s funeral (two weeks ago) . Anyone know of a way to recover data if I didn’t have a chance to back it up? I’m really heartbroken right now.
It took me 5 hrs to replace the lightning assembly. But… I took my time, carefully marking screw size and location(s). Where I ran into the greatest time consumption was rerouting the 2 antenna cables back onto the Logic board and getting the assembly to properly seat into its proper location. When I lined up the two white dots with the holes on the assembly , I could not get the port to properly seat,. When I tried the opposite direction-seating the port end of the assembly then laying it down to line up the holes with the white dots, it would not line up, it was like 2 mm too long.In order to get it to fit, I seated the port end, then lifted up the middle of the assembly and made like a “hill” , got the two holes to line up perfectly with the two white dots. then very gently pressed down on the middle to secure it to the case. The phone is now charging properly and could not be more satisfied with the results.
Wow! Thank you Scott.
That was maximum difficulty. It actually took me 3 hours hahaha.
So much fun. It didn't solve my non-functioning mic problem unfortunately.
My 7 is running perfectly except that. And it stopped functioning after the iOS 15 update.
Best
iLex
Hi, I followed the guide as stated and also did a battery replacement, now the phone won't start up anymore. I tried connecting the original parts back and the old battery worked for a minute and than ran out of battery. No neither the old charging port nor the new one is charging neither of the two batteries. What can I check and are there any parts on the logicboard potentially broken?
Cheers Konrad
Can anyone confirm 7/7P's pentalobe screws have a ring of seal near the screw head?
Cooper Chase - 回复
Confirmed, the screws have a black ring seal around the head.
rcheing - 回复
Can’t get the display front
Bernadette Pfeifer - 回复
From personal experience, I highly recommend before doing this procedure or any other, that you do a backup of your phone (preferably local) in case your procedure goes south.
ballina5ny - 回复
I purchased the repair tools with the replacement battery from iFixit. The tools include a screw driver and three heads none were labeled 3.4 mm. I think the one that fit the pentalobe screws was labeled Y000. The guide should identify the screw driver head supplied by the kit not 3.4mm.
Mark Lieberman - 回复
in the iphone 7 replacement battery kit from iFixit, the screwdriver that fits the 3.4 mm pentalobe screws is labeled P2 (and not Y000)
Jan-Tijn Oppermann -
3.4 mm is the height of the screw and is not related to the screw driver code.
Ahmad Vaziri -
the screwdriver PH000 does not work i wasted two screws and now they dont have the 4 cross mark they are now a circle, i buyed it all from Paraguay and it doesnt work, had to assembly back the parts because i got stuck like i mention with some screws, well im just going to send to a professional to install, thanks
Martin Frutos, Nuñez - 回复
The bottom screws are Pentalobe, not Phillips.
Bram Driesen -
Before starting, I would recommend backing up your Iphone’s data just in case.
Jon Moylan - 回复
If you managed to make it to this section, just send the phone into apple for 50 + 6 dollars shipping. The ribbon cables on the screen are designed to break. I can literally twist on the rest of the cable and it won’t fall apart but there is a diagonal section where it snaps. This is the fault of apple and the fault of ifixit for misrepresenting the fragility of the cables.
Ryan Huebert - 回复
Had to reheat it a few times for a minute each with a hairdryer to get the seal to break after pulling and rocking the suction
Cynthia Lamb - 回复
I’m technically challenged. Is there a premier national service who can professionally install a replacement battery got my 7 +?
Richard - 回复
Do the screws come out in total?
YVES THEUGELS - 回复
They may come out or may not. If you loosen as much as you can and they don't come out you should still be able to pry open the bottom. Once you get the screen off you can then push the screws out from the inside.
Anthony Falabella -
Is it the P2 you should use for the bottom??
YVES THEUGELS - 回复
I heated the bottom of the phone with a hairdryer and then used a syringe to put a couple of drops of acetone directly into the bottom two screw holes. I GENTLY pulled on the screen with the suction cup and used the pry tool to GENTLY separate the screen. The sealant is applied around the entire display so be very careful pulling it off so you don’t break the fragile display cables.
Anthony Scaminaci - 回复
At first it was very difficult to open, per instructions. I used a heat/ice pack and nuked it for 1 minute. The pry tool wasn’t working so I carefully used my pocket knife to wedge the cover open. The rest of the procedure went well until I cracked the glass while trying to get the top right corner to pop off. Other than that mistake, all went well. Tip: before setting the new battery, attach the battery connector first and leave enough room for the taptic engine, or better yet, place the taptic engine before adhering the replacement battery. This way you’ll have a small gap between the two, whereas mine barely fit. Good job on hosting the video, Gwendyl.
Klaus Preiss - 回复
I love the fact that the screw bit and shaft are magnetic! I almost lost a screw and found it attached to the magnet.
I used a heat/ice pack and nuked it for 1 minute. At first the display cover was very difficult to open with the pry tool, per instructions. The pry tool wasn’t working so I carefully used the blade of my pocket knife to wedge the cover open. The rest of the procedure went well until I cracked the glass while trying to get the top right corner to pop off. Other than that mistake, all went well. Tip: before setting the new battery, attach the battery connector first and leave enough room for the taptic engine, or better yet, see the taptic engine in place before adhering the replacement battery. This way you’ll have a small gap between the two, whereas mine barely fit because I placed it almost too low.
Klaus Preiss - 回复
I replaced the lightning connector assembly and reassembled. The old one did not 'click' into the cable and had corrosion inside, it needed the cable to be placed in a specific way to charge. The new part - does not recognize that a charger is plugged in at all.
I backtracked the assembly - took it apart, put it back again - and find that every thing on the part works - the mic, speakers, taptic engine.
The original problem with the cable still persists. Any ideas?
H K - 回复
