简介
iPhone 8 Plus 的主页“按钮”实际上是一个固态传感器,其中还包括 Touch ID(指纹识别)功能。
大多数更换的 Home 键都不起作用,因此在开始维修之前请仔细检查。您 iPhone 的原始主页按钮在出厂时与逻辑板进行了独特配对——如果没有 Apple 专有的校准过程,即使是另一部 iPhone 的真正替代主页按钮也无法使用。要修复损坏的主页按钮,您应该安装一个特制的通用型Home Button。请注意,这些替换仅用作按钮,触控 ID 将不起作用。
如果您只是更换损坏的屏幕,您可以使用本指南小心地移除您原来的Home键并将其转移到新的屏幕,保留所有功能,包括 Touch ID。
在此过程中,为避免意外拉伤或撕裂显示屏电缆,最好在开始维修 Home/Touch ID 传感器之前完全拆下显示屏组件。但是,如果您愿意这样做,您可以跳过本指南的显示组装部分,直接进入Home键/Touch ID 传感器部分。
你所需要的
将重叠的透明包装胶带条黏在 iPhone 的后玻璃上,直到覆盖整个手机后部。
如果在接下来的几个步骤中无法让吸盘粘在手机上,请将强力胶带(折叠到把手中,然后用它提起后玻璃。
将蓝色手柄拉向铰链以解锁反向钳的手臂。
将反向钳手臂滑过 iPhone 的左边缘或右边缘。
将吸盘放在靠近 iPhone 底部边缘的位置——一个在正面,一个在背面。
向下推吸盘以将吸力施加到所需区域。
加热 iOpener并将其穿过反向钳。
折叠 iOpener,使其位于 iPhone 的底部边缘。
等待一分钟,让粘合剂有机会释放并出现开口间隙。
将撬片插入间隙中。
跳过接下来的三个步骤。
使用吹风机或者准备好的iOpener来加热iPhone的底部大约90秒来软化下方的粘合剂。
6/14/23 I did this repair but used a heat gun on low for 60 seconds. This allowed me to open the case as the instructions say, but in the end the Home button failed. I probably over heated it. I used this "go around" for a virtual Home button. I don't care about touch ID:
将吸盘放置在前面板的下方一半位置,home 键上方。
Using just the single suction cup that is included in the battery replacement kit probably wouldn’t open the device. An iOpener and an iSlack should be the recommended method. However, you can get it open with just the single suction cup and iOpener, but does take a lot of time.
Get an iOpener and iSlack with the battery replacement kit.
I used a flat x-acto (#18) blade knife tool to gently pry back the screen enough to allow me to insert the pick near the bottom corner. I then worked the pick under the screen as mentioned in steps 5 & 6 below then. This worked really well for me.
Kyle Luksa - 回复
I used the suction cup without heating the phone - the adhesive came away quite easily without applying any heat. Maybe due to age of phone (nearly 4 years old). Worth trying.
My screen was very shattered, and was quite hard to get suction, as my tape was very low quality. However, after pulling it up a little bit, I was able to insert a regular razor blade into the very small gap and used that as a lever.
Oh my goodness! Don't do that again. You can definitely damage something in the phone if you use a sharp metal razor blade..
cytur -
用力拉动吸盘,持续的压力将会在前面板和后壳之间创造出一个小的缝隙。
在缝隙里插入撬棒或者其他几毫米的撬动工具
After multiple tries and using a very hot iOpener, it will not open.
In sheer frustration, I pulled out my trusty pocket knife and managed to lift the bottom of the screen slightly, but in the process, cracked the glass from the bottom to the home button. The case is open now.
在您的手机的角落处滑入撬片滑向左上角,朝着音量控制和静音键方向滑动,将固定显示屏的粘合剂分离开来。
在显示屏的左上角附近停下。
Do not go over the top otherwise you can crack the screen. Sadly happened to me :(
The instruction should be:
“Stop near BUT BEFORE REACHING the top left corner of the display”
将您的工具重新插入到iPhone的右下角,并将其划到手机右上角,以划开粘合剂。
I had really good luck using a hairdryer on some of the more stubborn portions of adhesive.
在屏幕的顶部边角处滑入一个撬片来切割最后的粘合剂。
Be very careful at this step. The glass at the top will break very easy when the display is lifted too much.
Gerdschi D - 回复
在这个步骤中使用的工具:Magnetic Project Mat$19.95
移除四颗将显示排线支架与逻辑板相固定的十字(JIS) 螺丝,它们的长度如下:
2颗 1.3mm 螺丝
1颗 1.4mm 螺丝
1颗 2.7mm 螺丝
The Phillips screwdriver bit is the PH000. The measurement refers to the screw length.
Jack Harry - 回复
使用撬棒的尖端来将逻辑板插座上的电池连接插头撬开。
稍微将电池连接插头弯曲,防止在您进行维修操作时意外与插座连接。
When I reassembled the iPhone 8 Plus, I had to plug it into a Lightning cable to wake it up (just pushing power button wasn’t sufficient).
使用撬棒的尖端或者手指甲来直接将插头从插座中撬出来断开大的低显示排线。
I got hold of a iPhone 8 Plus with cracked screen that I am planning to fix.
Here is my problem:
When I tried to take out the screen from my phone, (step 15-18) I was curious about the new screen, so I tried to connect it. It was completely dead! Then I tried the old cracked one, and suddenly that was dead to! This is a phone that some fool has been inside earlier and changed battery, but I suspect he has done some more really stupid things. The Taptic Engine is living its own life and vibrating every time I slightly touch the home button. (I have a new Taptic Engine) The phone is also full of dust and small particles that does not belong there. One tri-point Y000 screw (step 18) is even missing! Now the biggest problem is that both screens are black! I know the phone is on, because I hear voice command speak when I turn on the power. The screen worked before I tried to change it? And one last thing: My new LCD screen came with new flex cables. Is it possible to switch over, so I can use the old ones?
Hi,
Is your problem solved?
Be careful of damaging MOSFETs by the LH side of the large lower display cable. After replacing the battery and turning the device on, the phone showed low charge and didn't have a charging symbol even after plugging into multiple cables and chargers. Turns out I had damaged the logic board attempting to disconnect the connector.
断开另一个低显示排线插头,这个就在你前一步骤断开的插头的后面。
I used the other end of the spudger on this connector and it seemed to work a little better for me. I came in from underneath the top-right edge instead of the bottom right.
移除两个将支架与前面板传感器组件固定的三点Y000螺丝
1颗 1.0mm 螺丝
1颗 1.2mm 螺丝
una vite da 1mm e due viti da 1.2 mm???
Ciao Matteo! Grazie per l’osservazione. Ho appena modificato il testo :) La traduzione è aperta a tutti. Hai quindi la possibilità di fare le tue suggestione direttamente nel testo e sei il benvenuto se vuoi usare di questa possibilità nel futuro. Grazie ancora per la vigilanza! Saluti, Claire
The tool kit does include a 1.0 or1.2mm screwdriver! How am I supposed to remove those screws?
Bought the screwdriver that supposedly fits these screws and it still doesn’t work.
My bracket looks different. Can’t get these screws out.
kit came with wrong bit. i received 2x P02 (penta tips) and no tri point y000.
使用撬棒尖端或者支架来断开插座上的前面板传感器组件插头。
拆掉显示屏总成。
Should there be a step somewhere in here to point out when to remove the blue plastic from the new iFixit screen?
移除 Home 键与 Touch ID 传感器支架上的四颗 Y000 螺丝。
一颗 1.2mm 螺丝
三颗 1.3mm 螺丝
The 1.2mm screw on the home button stripped for me. I ended up bending the bracket on each side in order to remove the home button. I then bent it back as best I could during reassembly and screwing it down.
从右侧向上断开 Home 键排线的连接器。
I accidentally severed the cable, now my sensor is disabled. So far this was the most delicate cable I encountered because it was so small.
用一个塑料撬片轻轻地分离用于固定 Home 键与 Touch ID 传感器的排线与屏幕的粘合胶。
This did not work for me…. ended up breaking the connector from the home button. Most likely messed up the customer’s iPhone… the adhesive would not pry up with just pick… does iFixit offer a home button replacement?
did not work for me either, also ended up breaking the connector, just use the tweezer to separate it. do not use opening pick!!!!! it’s too thick for it!!
Isopropanol and heat will loosen the adhesive and its possible to gently remove with plastic pick, metal tweezers risk damaging the Home button cable and disabling the Touch facility.
Pretty easy to follow instructions if you have patience and careful hands. If you have clumsy hands you will not succeed in fixing any small electronics. There are some small things you should use to help you succeed at fixing small electronics, like some scotch tape or other clear tape to hold some of the cables in place while you work on small electronics items, also a small heavy bottle or object to propped the iPhones cases against to hold them from falling over so that your hands can be free to perform your tasks. Great job you are doing iFixit personel and I am with you all the way with fighting for our rights to fix our electronics equipment.
wogriffith - 回复
Isopropanol in conjunction with the heat really did the trick here. Heat up first, then use plenty of the alcohol to pry it up carefully using the pick.
Heat dryer on high worked for me.
I heated the tip of a thin knife with a hot air gun and slide it under the flexible cable. When I hit resistance I reheated the knife. Keeping it parallel to the board while doing this. After 4 heatings the knife moved the rest of the way and the cable lifted easily off of the iPhone back. This method left enough glue on the cable that it restuck fine when moved to the new iPhone.
Apple loves to make this the most difficult thing. I've been successful many times, and not so on other repairs. I just finished a repair and everything was in tact, but sadly it didn't work. Took a part and put back. So I turned on the assistive touch home button. They will be getting a new phone soon, so not a big issue except Pride.
如果您的更换屏幕没有配备前置摄像头和传感器电缆,按照这些步骤 将它们转移过来。
将您的新更换零件与原始零件进行比较——您可能需要在安装前转移剩余的组件或去除新零件上的背胶。
要重新组装您的设备,请按相反顺序执行上述步骤。
将您的电子垃圾送到 R2 或 e-Stewards 认证回收商。
54等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
7条评论
aiuto mi son cadute e quindi perso
sensore home/Touch ID Una vite da 1,2 mm Tre viti da 1,3 mm
dove le trovo?
Every time I have tried to transfer the home button from the broken screen to the replacement LCD - the home button has not worked. No tears in the cable. The connector is attached. Screw isn’t too tight. What could I be missing?
ATTENTION: Don’t screw in that one screw over the home button too much, or the button breaks! I just found one proper explanation for it in this YouTube video (https://www.youtube.com/watch?v=rDVnp90a...). Basically, that one screw that goes over the Home button should not be tightened too much, so that the metal plate doesn't bend (which it did for me).
This was truely helpful.
Anybody have the issue where the button works when the phone is in 2 pieces, but when you assemble the screen onto the phone body, the button no longer responds after a restart??
Power on phone while in 2 pieces -> home button is working
Attach screen to phone body -> home button is still working
Restart phone with phone assembled -> home button not responding
Hallo Zusammen
Wird bei diesen Mikroschrauben nur das Gewinde gemessen oder die gesammte Schraube inkl. Schraubenkopf? Ich frage, weil mir die Schrauben des Homebutton weggespickt sind 1.2 und 1.3mm...
Danke
LG
Hallo Alex!
We measure the entire screw for our guides.
what do I do about super stripped screws?
Ean Palacios - 回复
I’m sorry, your comment slipped past my radar earlier. For future fixers that might see this and ask the same question, you can check out our stripped screw guide for some detailed advice.
Adam O'Camb -
Do you need a toolkit like the essential toolkit
Adam Palmer - 回复
Hi Adam. Having a tool kit with all of the listed parts above is best. The screw heads are very small and each set of screws needs a very specific type of driver to remove them without stripping any of them.
Kyle Luksa -
