简介
本维修指南由 iFixit 员工撰写,未经 Google 认可。了解有关我们维修指南的更多信息 here.
请按照本指南更换 Google Pixel 4a 5G 的屏幕。
你所需要的
将镐头插入缝隙'1 毫米'时,将镐头向上旋转至陡峭的角度。
以陡峭的角度,小心地将镊子推入约 1/4 英寸(6 毫米)的缝隙中。拾取器应滑入 OLED 面板"''''下方"。
取下屏幕
将更换后的屏幕与原屏幕进行比较。您可能需要将其他部件(如扬声器网罩)转移到新部件上。
Follow this guide 如果要使用定制切割粘合剂,请使用本指南。如果您使用的是定制切割粘合剂。
如果使用 Tesa 胶带等双面胶带,follow this guide。
将新更换部件与原部件进行比较--安装前可能需要转移剩余部件或去除新部件上的背胶。
***要重新组装设备,请按照相反的顺序执行上述步骤。
将您的电子垃圾送到R2 或 e-Stewards 认证的回收商]。
52等其他人完成本指南。
由衷感谢以下译者:
96%
Yanqi Wang正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
28条评论
Where is the best place to purchase a replacement screen?
I was just wondering the same thing and it seems everywhere is sold out, only place I can find it is on eBay…
This was an excellent tutorial. One thing I would add here that caught me in reassembly: the proximity sensor is built into the inner lip on the top of the screen about 3mm to the right of the speaker grill (if you shine a bright light in that location, you will see a little blue dot where this is locate through the screen). If you are putting new adhesive on make sure not to block this proximity sensor with the adhesive.
Great tutorial. I just used the new original google pixel parts and this guide worked great! Only thing i wish was that there was a bit more clarity on how to apply the adhesives
Same! I needed to order another set of adhesive because at first time I ruined. Specifically that part where speaker goes. We need to attach it on screen. and all other on Phone case itself.
Also noticed that after some time, screen bends and we see gaps. I need to press time to time so it stick again. Not sure why this is so.
