跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
如何维修烟雾器?
如何维修烟雾器?
rjay
rjay7 其他贡献者
最后更新于 April 30, 2022
10分钟
中等
语法警察
需要更多图片
社区贡献指南
便宜的烟雾器因为质量差常常容易损坏。多数故障可以轻松修复。这份指南可用于维修这类烟雾器最常见的毛病。
我修的烟雾器名字叫做 'eurolite n-19',但也可能以别的名字出售。
你所需要的
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. 如何维修烟雾器?, 打开烟雾器: 步骤 1 中的图像 1,1
    • 打开烟雾器之前需要用螺丝刀拆掉图中的螺钉。
    • 拆掉烟雾器的外壳。
  2. 如何维修烟雾器?, 问题评估: 步骤 2 中的图像 1,1
    Link is spam. (As you may have guessed after reading this far, the author isn't actually trying to help you fix your machine.) Don't click the link to the guide.
    Daniel Jackson - 回复
  3. 如何维修烟雾器?, 烟雾器维修: 步骤 3 中的图像 1,1
    • 备齐必要的维修工具
    • 本例中,仅需要一根新的加热电阻丝和一个新的铲形接头。
    • 拆下加热电阻丝
    • 拆下铲形接头
    • 把新的加热电阻丝和铲形接头连接到它们各自应在的位置。
    • 加热电阻丝位于双金属器件的下方(图中看不清楚)
    Is heat fuse has on ampere rating? for a 900W fog machine what will be the rating of the heat fuse?
    Julio Pelino - 回复
    If you divide the power in Watts by the connection voltage in Volts, you get the current consumption in Amperes.
    For example: 900 Watt divided by 230 Volt gives 3.9 Amperes.
    The thermal fuse will probably be printed with voltage and/or current values.
    Toon Konings - 回复
  4. 如何维修烟雾器?, 重新组装烟雾器: 步骤 4 中的图像 1,1
    • 简单按逆序操作上述步骤以重组烟雾器。
    Where did you find the parts? (Heat fuse)
    Todd Maxwell - 回复
结论
重新组装你的设备,请反转以下步骤的操作顺序。
7等其他人完成本指南。
由衷感谢以下译者:
en zh
45%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
rjay
于09/29/12注册
233 声望
撰写一个指南
23指南评论
My fogger heater is jam how can I clean it?
vishal_kishor777 - 回复
hmm… I think I could have written a better guide myself. Okay so I have a 3 pin XLR for phase does anyone know how this works also I noted that the fuse was melted into its holster and the pump seems dead. My Fogger also has some kind of potentiometer which controls the heating element which is like a ceramic sandwich and two spark plugs… I also was wondering if glycerin fog juice can be made with vegetable glycerin or the glycol type or if this is what cloggs the machine. Also will clr work or be dangerous fume wise? Can you market glycerine as fog juice thickener like STP fuel additives for cars?? g0pg.xyz is my website you can learn how to force push graphite if you look for the post with yoda!
Ember Leona - 回复
Where can I buy a fuse like this? Have looked over the net, but could not find any shops that would sell CH-15 fuse, used in this fog machine. If anyone knows about this, please share info. Thanks! By the way, I’m based in EU.
Giedrius Stasiulis - 回复
I would make a post on Halloweenform.com
Mad_as_a_hatter -
My fog machine is not pumping out smoke
Ohwaga Kerry - 回复
Have you cleaned your machine?
Mad_as_a_hatter -
No power to my fog machine ?
David McCartie - 回复
Thw machine doesn't power on at all? Dose it get hot ? If it not getting hot. Check the fuse. If you hear the pump trying to work and nothing comes out. You would need to use fog cleaner or water and white vinegar.
Mad_as_a_hatter -
My FM400-1 fog machine pumps out fog for 1 minute then stops, cools and then pumps out fog for another minute then stops again. Is this normal or is the safety device wearing out?
Paul Houle - 回复
Yeah that would be normal for a 400 watt fog machine. The heating element has to be 200 to 250 degrees. When pumping fog it will cool it down. The heating element needs to reheat up again. Before it will pump more fog.
Mad_as_a_hatter -
My fumigation machine is not fuming out smoke
MANMEET KHALSA - 回复
Have you cleaned your machine? You can fog cleaner or you can use water and white vinegar.
Mad_as_a_hatter -
Can we use 900W coil instead of 1500W coil in a machine
Rajendra Katote - 回复
Just guessing I would say not. Depends on the model and the watts you would want to find a similar replacement. You could even find a broken fog machine to use as parts
Mad_as_a_hatter -
Heating fuse was hidden why didn’t you take a photo of it since you replaced it. This is the only info I could find and it’s incomplete! Im going to a corner to cry now
traceelauren - 回复
Hallo,
bei meiner N-19 musste die defekte Pumpe getauscht werden. Leider habe ich es versäumt mir zu notieren wohin die beiden Kabel der Pumpe angeschlossen werden. Wer kann mir helfen und es mir erklären ? ?
HajoPianoMan - 回复
I am not sure that what is being replaced is a heat fuse. It rather looks like a temperature switch. The difference is that the temperature switch is supposed to work on a regular basis, while the fuse can usually not be reset and just breaks in case of overheat. I entirely dismantled such a machine and it does not seem to contain an heat fuse. Lack of actual heat fuse might be a security issue, because the temperature switch may fail (I have no knowledge of “failure modes” of theses switches, but notes that in coffee machines, it is common to have both a thermostat (acting as the temperature switch here) and a heat fuse (which would activate if the switch fails and temperature reaches levels beyond which it could be dangerous). Conclusion : always keep an eye on these potentially unsafe machines.
pmarbaix - 回复
No power 2 mg fog machine, no heat no Pump I have an s2500 beamz or a 1700w its a stage fog machine help me please
Mel - 回复
I have a second hand beams s500 that only works for about 10 seconds then cuts out then 10 seconds again when it green lights again and so on. I'm assuming there is a fault. Any ideas please?
mcpeorange - 回复
Dobrý den, mám dotaz, vlastním výrobník mlhy eurolite N19 . Momentálně byl dva roky mimo provoz,koupil sem čistící roztok, vyčistil a profoukl i kompresorem, vše funguje, topné tělísko hřeje, čerpadlo pracuje,ale mlha se vytlačí pouze třeba jen na 6-7 sepnutí a pak třeba další dvě hodiny nereaguje myslíte,že je chyba v čerpadle nebo stále někde zanesena tryska?
lukasvrastil - 回复
Is er een stroomkringschema beschikbaar?
Christiaan Klompstra - 回复
Anyone have a source/link on inexpensive replacement heater blocks? The cheapest ones I found were on Aliexpress & they were around $50
Micah Woloschuk - 回复
My fog machine is not pushing out any fog just liquid is spraying out
avinash ramkissoon - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 34
过去 30 天: 138
总计 65,681
