跳转到主内容
加入维修社区 - 创建账户
HP 14-cf2112wm 是惠普中端消费级笔记本电脑系列的一员,通常面向需要进行网页浏览、文档编辑、多媒体消费和轻度游戏等基础计算任务的日常用户。可通过产品编号 5T9T7UA 进行识别。
Computer blinking 3 time long 5 short
My computer suddenly shut off and wouldn't come on and the caps lock is blinking 3 long blinks and 5 short and the light is white.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@tiahanuman that blink code is fairly generic but commonly indicates that you are having issues with either the CPU or the motherboard. It is also possible that this is a BIOS issue. Try a hard reset first
Power off your laptop.
  • Remove the A/C adapter, disconnect the main battery and everything else that is attached to your laptop,
  • Hold the 'POWER' button down on your laptop for about 10 seconds.
  • Plug in the A/C adapter only and try to power on.
If that did not work you may have to attempt to recover your BIOS:
  • Turn off the laptop.
  • Press and hold Windows Key + B (or V on some models) simultaneously.
  • While holding those keys, press and hold the Power button for 3 to 5 seconds, then release the power button while continuing to hold the Windows/B keys until a BIOS update screen appears
as always, you also want to check your RAM sticks. So remove the RAM, clean the contacts with a pencil eraser. Do it gentle so as to not destroy the module. Replace it and restart. If you have more than one module, remove it and just leave one connected.
To work on your computer, use the guides from here HP 14-cf2112wm
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tia Hanuman 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 21
过去 30 天: 38
总计 38
