跳转到主内容
加入维修社区 - 创建账户
Tecno Pop 10 的维修、拆解和故障排除信息,该机型于 2025 年发布。
How to Extend battery life
Extend battery life
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@favouremodi that really is not much of a repair relate question. Here are the most common things to do to make your battery last a bit longer:
Start by dimming the screen. The display uses more power than anything else. Pull down the top menu and lower the brightness as much as you can stand, or turn on Adaptive Brightness so it adjusts automatically.
Next shorten the screen timeout. Go into your display settings and set the screen to turn off after 15 or 30 seconds of inactivity.
Now kill unnecessary radios. If you aren't actively using Bluetooth, GPS, or Wi-Fi, turn them off. They constantly scan for connections and drain your power.
Also turn on Battery Saver in your software. Go to your Settings, find the Battery menu, and turn on Battery Saver. This automatically stops apps from updating in the background and pushes the phone to run more efficiently.
Last but not least, you want to check for battery hogs. In that same Battery menu, look for any that are using the most power. If an app you rarely use is draining the battery, uninstall it or restrict its background usage.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Favour Emodi 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 7
过去 30 天: 7
总计 7
