跳转到主内容
加入维修社区 - 创建账户
此页面将帮助你维修 Dell Vostro 2520。其中包含了电池、硬盘、键盘等部件的维修指南!
Turns on but only white screen
Laptop turns on but there is only white screen. If I connect another monitor then it works fine. I want to fix it so screen of laptops works fine and make the portability possible.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
10条评论
@amitkg Try to open up the laptop and reconnect the plug for the built-in screen!
完成的
Hi Theo, thank you for ur message. i did exactly as u mentioned unfortunately it doesn't work. It still 99.99% white all over the screen except 1mm upper part (that much part is good). Is there any other way to fix it without changing the screen ?
完成的
@amitstark let's see this "over the screen except 1mm upper part (that much part is good)" by posting a picture with your Question of what your screen shows. 在已经存在的问题里加入图片
完成的
Sorry, and I added a small video. Please check it out.
完成的
@amitstark so it does show more than just white. This actually looks like a bad LCD panel.
完成的
显示更多的5条评论
添加一条评论
1个答案
已选择的解决方案
@amitkg a white display indicates that the LCD backlight is turning on and thus receiving the proper voltage of 19V from its power rail. The issues that your laptop shows is commonly caused by a loose LVDS display cable,a damaged display connector, a damaged LCD panel, For now, check the connector and check the cable. This error looks more like a bad LCD. Use the Dell Vostro 2520 Owner's Manual which includes a service manual, to work on your computer.
For anything odd that you may see while working on it post some pictures of that so we can see what you see and help you further if needed. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Amit K.G. 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 66
总计 66
