跳转到主内容
加入维修社区 - 创建账户
Fujitsu Lifebook E753 于 2013 年发布,是一款 15.6 英寸的商务笔记本电脑。它搭载第三代英特尔酷睿(Ivy Bridge)处理器,支持最高 16GB 的 DDR3 内存,配备带有独立数字小键盘的全尺寸键盘,重量约为 2.1 千克。 其标准 6 芯电池(可选 63Wh 或 72Wh 容量)可提供约 12 小时的运行时间。E753 配备了一个模块化托架,可容纳一块额外的 28Wh 电池。当两块电池同时使用时,该笔记本电脑的电池续航时间总计可达 18 到 21 小时。
Laptop not Powering On
After not charging my laptop for a long while due to Power Outage, When the Power supply was restored, I tried charging it and after charging, It did not switch on. I've tried putting it on AC mode - Plugging it without the battery installed - and it still didn't work.
Please what should I do
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@ujuakuokafor first you want to check your power supply. Make sure it has the proper voltages. Check to make sure that connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Use something like this video to open your laptop up. Post Some good pictures of what your motherboard looks like with your question. That way we can see what you see. 在已经存在的问题里加入图片
Your computer most likely does have a Fujitsu 621881-X1 motherboard and I have not been able to find the schematics for this. You will need to depend on your own troubleshooting skills if the error is with the motherboard.
这个答案有帮助吗?
得分 0
1条评论:
Thanks, I'll try opening my Motherboard, snap the picture and send it back
由完成的
添加一条评论
添加你的答案
Ujuaku Okafor 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 28
总计 76
