MacBook Pro screen fading out
Hi there!
I found some similar questions, but none specific enough to make sure they were the same problem, and none with detailed solutions.
A video of the symptoms before I explain with words:
My Macbook's screen sometimes starts fading out. First the pixels get wider, meaning the image seems pixelated. Then the colors start changing, until it gets inverted, then it fades to completely dark grey.
There's no correlation of when it does that and when it doesn't. Sometimes I am just working while everything is normal, and all of a sudden it starts. Sometimes it’s in the morning, I am just waking it from sleep, without even touching the screen, and it’s in that state.
If I then try to bend a little bit the upper left corner of the screen, it goes back to normal. Sometimes it’s enough to keep it working without my pressure. Sometimes as soon as I let go, it starts fading again, and I have to push the whole computer against something to exert that pressure while I work.
Sometimes the problem will remain for weeks and months, and at some point go away for weeks and months.
Sometimes I have to press very hard for the screen to come back to normal, sometimes a very gentle touch will suffice.
It’s mostly on the upper left corner that I have to bend. Sometimes it’s on the upper right corner, but rarely.
What I tried
When I plug an external display, it works fine.
I tried opening up the Macbook and disconnecting the screen, vacuuming the cable, socket, and everything.
Sometimes after I put everything back together, the problem goes away for a few weeks. Sometimes it doesn’t change anything.
I also tried opening the case while the laptop is on, and moving a little bit the display cable, to see if it changes anything. It didn’t.
Other things I noticed
I noticed that some kind of shield on the motherboard’s socket is out of position. But it seems unlikely to me to cause the problem:
I also noticed a visual irregularity on the display cable’s outer wrapping, but I don’t know whether that’s damage or not:
I very recently noticed that the top part of my LCD is unglued from its shell. But I don’t know whether it was there before, and thus could be a cause, or whether it’s the consequence of my bending the top left corner of the screen so many times.
How I see things
It seems to me the screen itself is fine.
So I feel like it could be either the socket on the motherboard, or the cable, or the socket on the LCD. Right?
Questions
Does anyone know whether there is a quick fix to this, or how to narrow down the cause?
My partner’s laptop is a 2010 macbook pro, so the same but one year younger. Do you know if I could plug her screen onto my laptop? If so I could rule out the motherboard socket, or conversely incriminate it.
Thanks a lot in advance for the help!
Update after swapping screen
So I tried swapping screen with my partner's laptop.
One important note, is that BEFORE doing so, I couldn't manage to get my screen to fail completely. For some reason it was working fine. I had to bend it a little bit for it to start pixelating and fading out. Basically the opposite of when it's failing. When it's failing, I have to bend it to get it back to normal.
This time it was working, and I had to bend it slightly to get it to fade away.
After swapping it with my partner's screen, here were the results.
On her laptop, with my screen, behaviour was the same: screen was working, but if I bent it slightly, it would exhibit the same symptoms, first pixelating then fading out.
On my laptop, with her screen, it was working flawlessly. I tried to bend it, to change angle etc, it would always keep showing the image perfectly.
After swapping the screens back to their respective owners, the behaviours are back to what they were. My partner's laptop is working flawlessly, and mine is in the same situation: it's working right now, but if I bend the screen slightly, the symptoms show up.
I don't want to make conclusions myself, because I am not an expert, but it seems to me to hint that my motherboard is fine, and the problem lies either in the cable or the LCD's connector or the LCD itself.
What do you think?
It would be kinda pointless to swap the display from your partnerss laptop, instead just swap over the HDD or SSD. @Danj is this the same issue I had with my 2015 model? What happened here with the screen? It has the same effect!
由 livfe 完成的
@livfe - Your issue was a bad T-CON. Here we have a bad logic board connector as it's become damaged. Here the fade-out is the lost of video signal as the T-CON is being starved of the updated screen refresh so the currently drawn screen fades.
The connector interface is not stable! This is similar to a ceiling light bulb getting loose so it flickers as people walk on the floor above or after turning off it magically shuts off as the bulb heats up changing the connection, so you let the bulb cool down and it works to fail once again!
Here the connection is breaking down between the cable and the logic board.
The proof is the stability of the external display image.
由 DanJ 完成的
