跳转到主内容
加入维修社区 - 创建账户
Sony WH-1000XM4 無線降噪耳罩式耳機維修拆解資訊。
No light when charging
Unit sat for along time and now it won't charge
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@alantordoff possibly an issue with the battery having discharged below it's charging threshold. That basically means that the battery has discharged to a point where it no longer accepts a charge. I would start of with a new battery. Use this guide Sony WH-1000XM4 電池更換 for that.
A new battery will also give you a known well starting point should it become necessary to troubleshoot further. If the new battery doesn't fix this, you will need to check the charging port and charging circuit.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Alan Tordoff (Schnarf) 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 35
总计 103
