跳转到主内容
加入维修社区 - 创建账户
HP Envy x360 is a line of laptops made by the company since 2014. They feature a touchscreen and a fully rotating display.
How much does it cost to replace just the screen?
My HP Envy x360 2-in-1 14-fc0xxx.
Has a little crack on the upper right hand side of the touch screen - barely a crack, however my laptop seems to think I am touching the screen so it keeps pressing random stuff making it hard to use my laptop.
Will I only need to replace the screen and how much would it cost?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi @coop61311
The touch panel is integrated with the LCD panel as a complete module
Here's the maintenance and service guide for the laptop.
Go to p.46 (53 of 103 pdf) to view the procedure to remove/replace the display assembly.
On p.50 (57 of 103 pdf) it shows the HP part numbers for the two panels that are used with the model..
Search online using the part number only e.g. N91014-001 or N91013-001 to find suppliers that suit you best.
Usually the part number is located somewhere on the back of the LCD panel if you wish to verify which one you need.
这个答案有帮助吗?
得分 1
添加一条评论
@coop61311 iFixit doesn’t actually fix things for people. The site is a place for people to learn repair for themselves—the “i” in iFixit is you! For this repair, I’d start with the Maintenance And Service Guide HP ENVY X360 14 Inch 2 In 1 14 Fc0xxx. Check page 20 to determine which panel (different models) you will need to replace. Then use the part number to source the panel.
Use the step-by-step instruction (page46) from the same manual to replace the panel. The cost for the repair will be the price you pay for the panel.
If this task seems to be above your level of confidence, you will need to do an online search for a service that can replace it for you. The cost will of course be considerably higher.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
COOP 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 34
总计 34
