Not switching my phone
When iam doing charging it just vibrate it will not will not on the phone and I remove from charging and try to switch on it will just vibrate and not showing anything
@saimashaikh "it just vibrate it will not will not on" what you are describing are the symptoms of a failed screen. Replace the display and re-evaluate.
Use something like this video as your guide. Of course you can also use the guide from here. It is written in French. Use a browser that does the translation for you, if needed. Replacement displays are readily available. Just do an online search and select a vendor that appeals to you.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem with their device as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 21
总计 21
