跳转到主内容
加入维修社区 - 创建账户
V2 手柄有不同的代次。你现在查看的是第 4 代。
L2 triggers right stick
When I press L2, it triggers my right stick up, and even after I release it it still moves up.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi!
So, the issue is either with the stick, button circuit membrane OR a trace on the motherboard.
Testing will not be easy, I always test with new parts to identify.
First I’ll start with the easy parts. Please open it up and clean the button membrane circuit, also where it connects to on the motherboard and test again. Also clean the joysticks.
If the issue is still there, replace the button membrane circuit.
Guide: DualShock 4 (CUH-ZCT1U) 按键电路膜更换
If that fails, replace the right joystick and try again (you do need to solder and have soldering experience).
Guide: DualShock 4 右模拟摇杆更换
If that fails as well, it’s most likely related to the motherboard and you need to check the traces.
Please let us know how it goes!
DualShock 4 右模拟摇杆图片
指南
DualShock 4 右模拟摇杆更换
难度:
困难
30 minutes - 1 hour
DualShock 4 按键电路膜图片
指南
难度:
中等
1 - 2 hours
这个答案有帮助吗?
得分 1
2条评论:
how do i clean it exactly, like do i just use a cotton swab or something
完成的
Hi!
You need isopropyl alcohol and a cloth. Clean it completely and see how that goes :)!
完成的
添加一条评论
添加你的答案
MUNBF8 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 30
总计 88
