此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
简介
这里有一个双模拟摇杆都出现漂移问题的 DualShock 4 控制器。更换摇杆的过程非常直接,解决了这个问题。
摇杆焊接在控制器主板上。你需要一台焊台来完成这项维修。
你所需要的
这些是需要拆除的焊接连接。由于电路板现在是倒置的,左右方向会发生反转。
使用吸锡线和助焊剂熔化并吸走焊锡。
这可能需要练习一下,因为必须清除所有焊锡。在熔化焊锡并使用吸锡线的同时,轻轻拉动摇杆会很有帮助。
要重新组装设备,请按相反顺序执行这些说明。
41等其他人完成本指南。
15指南评论
I just tried to remove both joystick and replaced them but unfortunately only one joystick works and that one that works it's stuck on and only moves in one direction.
I've not been able to actually get the solder out, would love any suggestions or tips.
James Napoli - 回复 分享
send me a couple of pictures on what your repair looks like thus far. Send them to my email. Click on my username and my email address is on my profile. Let's see what you got so far.
oldturkey03 - 回复 分享
This is a very difficult repair, what this guy didn't mention is you need a very expensive solder station with an electric solder sucker. The solder needs removing and it's nearly impossible without damaging the tracking.
Dave bolton - 回复 分享
You definitely need some soldering experience but the repairability is not that difficult. The soldering points are big enough for any cheap ($40) soldering iron can get too. As for removing them, it helps to use flux and also a soldering wick to absorb all the old solder. It is not easy but not the most difficult repair. P.S you do not need the expensive soldering stating with hot air etcetera. This works perfectly as it get hot beyond the required point to melt the solder
Eyob Grainge - 回复 分享
