跳转到主内容
加入维修社区 - 创建账户
更大尺寸的 Nintendo DSi,北美市场于2010年3月开售。大多数维修只需要螺丝刀和维修工具即可完成。
Is it possible to fix this?
I was trying to do a USB-C mod for my Dsi-xl and when I pulled off the charge port I pulled two pads I managed to get it on, but when I turned it on I got blinking light turns out I blown the fuse on the power board. I thought the exposed copper by the via caused the short so I removed the Usb-c and tore a third pad I dont know if I can now do the mod can it fixed ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@christophe89153 Yes, it can be fixed :-) IMG #1 and #2 looks like you have some copper on the vias that you could use to run jumpers to the new connector or even rebuild the solder pads by using epoxy-bonded replacement patterns. #3 would just require you to run a jumper from point 1 of F1 (which indicates a fuse :-) to the proper contact of the new connector.
这个答案有帮助吗?
得分 1
3条评论:
Thanks I'll give a shot
由完成的
So i have to connect a jumper from positive vcc of the usb-c port to the right side of the fuse correct?
由完成的
@christophe89153 yes. Kind of like I tried to show with the blue line :-) Have you ever tried to attach solder pads and rebuild traces by using some solder mask and repair pads? You would just need a small grinder ( or a scalpel) and a steady hand. I use the solder mask to "glue" the pad/traces to the board then grind some of the solder mask off to solder to the pads. It'll take a bit of practice but seems like you work a lot with failed pads etc. See if you have some old boards to practice rebuilding pads. It just has more structural strength then just jumper wires. I think there might even be some Youtube videos about this.
由完成的
添加一条评论
添加你的答案
Christopher D 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 37
总计 117
