im going crazy help requested
i bought this vacuum https://www.amazon.com/dp/B0DR8NJMCJ?ref... ECOVACS DEEBOT X8 PRO OMNI Robot Vacuum 1 year ago.
recently the main brush motor stopped spinning so i opened it up to replace the motor. i have now bought 3 different replacement motors that say they are for the T8 or 8x. but none of them fit correctly. i have searched like crazy but can not for the life of my find my motor anywhere online. (pictures below) am i crazy? are these no longer in production? is one of the other motors supposed to fit even though the L shape is wrong? your wisdom is appreciated.
Update (06/18/26)
ok so with some inspiration from oldturkey03 i think im close. im going to walk through what i did if anyone else is ballzie enough to try this.
so i decided i was going to transfer the old L drive shaft to the new motor. i started by unclipping the snaps around the perimeter (picture1).
once inside i cleaned all the gears as they were very full of dirty grease (picture2).
i then removed the two screws on the left side of the image (picture3) (this is where the motor attaches) and screwed in the new motor.
but as i put it back together i realized that the gear attached to the new motor was beveled to the left but all the old gears were beveled to the right! so i pried the motor gear off of the old motor and transferred it to the new one. (be careful when prying off it toke a lot of force and mine ended up half way across the room in my white shag carpet. much cussing ensued.)
ive got all the pieces together and clean now i guess the last thing i need is to figure out what kind of lubricant to use on the gears. any ideas?
1条评论
i wanted to add an update. while i was able to replace the motor and get everything back together and working. it did not fix the issue sadly. i am now fairly confident the problem is with the L piece but i have not been able to find a replacement for that part so im at a stand still.
由 kindle 完成的
