跳转到主内容
加入维修社区 - 创建账户
2009 年 2 月发布的一款紧凑型数码相机。配备 2.5 英寸显示屏、1000 万像素数码传感器,以及具备面部检测功能的 3 倍光学影像稳定变焦镜头。提供银色、深灰色、橙色、绿色、粉色和蓝色可选。
Canon Lens Will Not Retract
For context, my friend gave me this ixus 95 (Sd1200) camera to keep, and it said to replace the battery so i charged it up, and it worked fine. When i tried to use the autofocus function, since it was still blurry, it wouldn't work, so i kept trying and eventually the camera effectively crashed, leaving the lens extended, now every time i power it on, it does a couple clicking noises then hands me a lens error. I was looking at the lens and the gap between the lens itself and the casing it a little uneven. I want to know if there is anyway to fix it. (for added context, my friend had it in their room for a while and its been a while since they tried turning it on.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@propanepropane sadly enough this is a common error with any digital camera that utilizes a telescopic lens. Look through the suggestion on here Fix#4 might work for you.
if it can't be corrected you will have to repair/replace the lens. For that use this guide Canon PowerShot SD1200 IS 镜头组件更换
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Propane (Propane) 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 34
总计 141
