跳转到主内容
加入维修社区 - 创建账户
也以 GMC Sierra 和 VIA Vtrux 之名销售,在美国、加拿大、墨西哥及全球其他国家均有发售。
How to adjust headlights
Adjusting low beam and high beam head lights
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
What is the year and specific model of your truck? More info needed.
由完成的 分享
添加一条评论
1个答案
@manueladronen here is the 1999 2006 Silverado Chassis Electrical System Chapter Opti and page 14 deals with the headlight adjustments. Great description about the actual adjustment for the DIY'er is: Point the truck at a wall on a level surface at 20' away from the front of the headlight to the wall. At night with the low beams on. With at least a 1/2 a tank of gas. On your headlight is a small dimple that is used for measuring the height of the center of the low beam. Find it, measure it to the ground. Now go to the wall the headlights are projecting on. Mark the measurement and if the low beam center line is any more than 1 1/2" to 2" above that mark turn the hex head above your headlight CLOCKWISE to lower them until the beam is nearly 2" lower (from here)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Manuela Dronen 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 59
总计 234
